Sponsored by BimmerWorld
Old 05-22-2010, 03:23 PM   #1
sataraid
My Ride: 2001 BMW 330ci
Looseness in the rear?? RTABs??
I get the feeling in the seat like both tires are really low on air or driving an overloaded pick up. Of course I am exaggerating just trying to convey the symptoms.
RTABs need to be replaced??
sataraid is offline   Reply With Quote
Old 05-22-2010, 03:33 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I'd check your tire pressure first. But yeah, if your RTABs are older than 60k, they might need replacing.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-22-2010, 03:46 PM   #3
SalM
My Ride: Shhh
^+1 Better off checking tire pressure first if not they RTAB's might need to be changed
SalMPhotography
SalM is offline   Reply With Quote
Old 05-22-2010, 05:04 PM   #4
sataraid
Tire pressure is fine.
I was simply trying to explain the symptoms.
Old 05-22-2010, 05:53 PM   #5
hummer
My Ride: 2001 330CI
When the RTABs are gone, the trailing arms move around which changes the toe and the rear will feel loose like you say. Rear wheel steer! Some HD RTABs and limiters will fix you up!
Old 05-22-2010, 06:27 PM   #6
sataraid
Thanks for the replies guys. Yeah I dropped the rear end today. Every bushing under there needs changing.
Old 05-29-2010, 07:52 AM   #7
ASSAIL
My Ride: E46 328, Jza80 Supra
definately rtabs. mine both totally separated recently, its an absolute b1tch trying to keep the car in its lane on non flat roads.
ASSAIL is offline   Reply With Quote
