E46 Xi Forum
Old 06-04-2010, 04:42 PM   #81
MileHiXi
Banned
My Ride: '02 330xi
Originally Posted by Kubica View Post
MileHiXi-
Do you have experience with any other setups for the xi? If so, how do they compare to your Dinan setup?
Nope. I've never had any other setups. But before I purchased I had searched for threads on the topic and I remember one in particular where the guy had gone from stock, to slamming the car then to Dinan and had found Dinan less harsh than his previous aftermarket setup.
EDIT: here it is:
http://forum.e46fanatics.com/showthr...light=dinan+xi
Originally Posted by bmwstephen View Post
Dinan stage 1 suspension.
go Big! so you don't end up going back and spending more $$$.
I seriously went from bavauto springs (dont lower) --> HR springs (too stiff) --> Dinan springs + Dinan Shocks (just perfect)
if you get Dinan, make sure to get the koni shocks from them as they are custom dampened and differ from the shocks Koni sells for the XI seperately
looks like you and I participated in that thread!
MileHiXi is offline   Reply With Quote
Old 07-13-2010, 01:22 AM   #82
skybmw
My Ride: 330XI 2003
I finally loving my setup with Koni struts / bavarian lowering springs. Ride comfort like or close to riding a stock M3.
I tried a few different suspension set up for my XI, bilstein HD with Bavarian springs, they are very stiff, you won't like it at least I don't because I am living in NYC, the road condition is increditable bad / rough...even on highway, I also try bilstein sport with bavarian srpings, same as HD there is no different when riding on it, only the piston on the strut is shorter.
Then I finally try with koni because I found a set in very good price lucky...
It's prefect for me..., ride very smooth when accelerating. Espeically when going on a bump, it's not bouncy at all plus it is very comfortable. I highly recommended it.
If you have more money for the springs, I think Koni with eibach pro kit might be even better because my friend's 330I are using this combination and they feel more like stock to me...very comfort as well.
2003 330XI
Koni Sport w/Bavarian springs
Tinted yellow fogs
Tinted Red taillights
Painted black on the stock rims
25mm spacers front & 20mm spacers rear
Black front strut tower bar (Can last closed to 3 yrs & still in good shape before I changed to OEM one)
M3 OEM front strut bar (broken in a month)
Adjustable camber plate
skybmw is offline   Reply With Quote
Old 07-13-2010, 03:11 AM   #83
xi_ter
My Ride: 2003 325xi
Koni Sports adjusted to 20% stiffer with Eibach ProKit springs and new Conti tires. With the alignment I had the whole front end retorqued to factory tightness. Now I'd say the ride is perfect and very quiet.
Old 07-13-2010, 07:19 PM   #84
Kubica
My Ride: 2003 325xi
Originally Posted by KYC View Post
Here's my personal experience on different setups.
Bilstein shock with stock springs: Ya... this is only temporary because the undercarriage is rubbing when entering an indoor parking. Terrible ride so far, bad comfort, bad handling... I need to swap those out FAST.
Bilstein Sport. I'm actually not too sure the difference between that and HD
Gotcha. I run Bilstein HD with stock springs and its a great setup. Bilstein Sport is definitely a no-go with stock springs.
Nice.
I'm curious what the Eibach's would be like with Bilstein HD's now.
I thought about the Koni's (and almost got a slightly used set for next to nothing). But if you've been around for a while, you've no doubt heard the quality issues Koni had. They seem to have most of those problems solved recently, but the reason the used set was available to me was because the guy kept blowing them out in the rear. That said, everyone blows out bilsteins now, so who knows anymore. I'm pretty sure BavAuto had a bad batch of rear xi shocks too. EVERYBODY was blowing out rear bilsteins on their xi around here.
Old 07-13-2010, 11:09 PM   #85
xi_ter
My Ride: 2003 325xi
... you've been around for a while, you've no doubt heard the quality issues Koni had. They seem to have most of those problems solved recently, but the reason the used set was available to me was because the guy kept blowing them out in the rear. That said, everyone blows out bilsteins now, so who knows anymore. I'm pretty sure BavAuto had a bad batch of rear xi shocks too. EVERYBODY was blowing out rear bilsteins on their xi around here.
Bilstein claimed these failures were due to installers roughing the surface of the chromed piston with Vice-grips when torquing the top bolt. I'd say there is truth to this. I was very careful clamping the vice -grips only at the very top and mine are not failing.
This could have been happening on Koni installs as well. The shock mfrs should really put a flat surface on top so the installers clamp there instead of lower down.
