Old 05-25-2010, 10:54 AM   #1
driverf
My Ride: 2000 328i
low coolant prevented engine start?
I just wanted to put this out there in case anyone finds him/herself in the same situation as i couldnt find anything similar through a search.
For the last 3-4 days my low coolant light would come on for about a minute then go away. I figured it must be barely below the threshold to trip the light since it went away after a bit. Also the temperature never went above normal. I figured I'd get some more coolant next time i went to the store. Went to go to work one morning & the car wouldnt start. The gauge cluster lit up and all electronics came on but the the motor would not turn over and there was no ticking sound. I did notice the red (far right) segment of the temp gauge light up when i tried to start it though. Searched the forums & found recommended fixes including need of new key (bad transmitter), bad starter, & bad fuses. I decided to see if topping the coolant would fix the problem. It did. Car now starts fine & everything is back to normal.
The moral of the story is dont be an idiot like me, take care of basic maintenance ASAP.
driverf is offline   Reply With Quote
coolant, start
