Sponsored by BimmerWorld
Old 05-25-2010, 06:15 PM   #1
TitaniumSedan
My Ride: is my portfolio
Rear 1.5" lower than front
The rear of my 01 325i Sedan w/ sport package is noticeably lower than the front. I've only had the car a couple of months so I'm not sure what could be causing it. Measurements from the ground to the fender: 26" in front 24.5" in the rear. The tires are size 225/45/17 in the front and 245/40/17 in the rear. Anybody have any ideas?
TiAg, Grey/Black Interior, HK, ZSP/ZPP/ZCW, 5MT
Carbon Fiber Trim (DIY), M68 Wheels, LED AE's, Interior LED's
Smoked Depo's all around w/ stealth bulbs, Black Grill,
35% Tint, BMW Perf CF Strut Bar
My 3D Design Portfolio: briansteere.carbonmade.com
My YouTube channel - Cars and Guns
TitaniumSedan is offline   Reply With Quote
Old 05-25-2010, 09:30 PM   #2
snitzl3
My Ride: e60 LCI
Send a message via AIM to snitzl3
check your rear shocks you could have a blown shock, i read earlier about a guy that came out and his car was lower in the back and there was fluid on the ground and the shock was blown. It could also be a broken spring? im not sure just get it all looked at.
snitzl3 is offline   Reply With Quote
Old 05-25-2010, 09:42 PM   #3
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Check to see if ur spring are not broken.
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 05-26-2010, 08:08 AM   #4
geko29
My Ride: 2000 323i
Your springs are broken. 1.5" suggests that the break is roughly two coils up from the bottom. This is a VERY common problem (especially in northern states). Take this as an opportunity to replace the shocks and springs with something better, since you shocks are likely blown as well.
geko29 is offline   Reply With Quote
Old 05-26-2010, 11:55 AM   #5
tinkwithanr
My Ride: '00 323i + '75 2002
Like everyone else said, broken rear spring. Depending on how long it's been like that it has probably caused the rear shock to become blown. Time to upgrade!
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 05-26-2010, 12:02 PM   #6
BruceWayne
BruceWayne's Avatar
My Ride: 03 LSB ///M3
if your springs are broken I have a set of stock sport springs that you can have for cheap, PM me of you want them
AST 4200 | Vorshlag camber plates | Power Flex rtab & fcab | AFE stg. 2 | Auto Solutions SSK | Macht Schnell Studs | Stoptech stg. 2
BruceWayne is offline   Reply With Quote
Old 05-26-2010, 12:03 PM   #7
TitaniumSedan
Any of you guys running the H&R Cup Kit or FK Highsport? I plan on doing a few autocross events but it is my daily driver. I want something under $1000 with a drop of no more than 1.6". Any other suggestions?
Old 05-26-2010, 04:45 PM   #8
BMW_Matt
My Ride: 135
Then the cup kit will do find for you.
BMW_Matt is offline   Reply With Quote
Old 05-26-2010, 05:40 PM   #9
DangerousMind
My Ride: Sierra 1500 SLT
The rear fenders are cut lower than the fronts by design to allow more room for the fronts to turn.
Specs the Bentley Manual:
Measured from the bottom center of wheel to the bottom of the wheel arch
17 inch
Standard Suspension Sport
F - 604mm 23.77 inches F - 589mm 23.19 inches
R - 570mm 22.44 inches R - 554mm 21.81 inches
You add in ~ 3- 3.5 inches for tires and you are spec on.
DangerousMind is offline   Reply With Quote
Old 05-27-2010, 03:23 AM   #10
snortdavis
My Ride: 2006 M3, 6mt TiAg/Bk
+1... just what I was thinking.
SNORT
///M3 '06 COUPE 6MT, SCHWARZ/GRAUR.I.P.
///M3 '06 COUPE 6MT, TITAN SILBER/SCHWARZ -- NO SUNROOF
snortdavis is offline   Reply With Quote
