Old 10-17-2012, 09:58 PM   #21
dknightd
My Ride: 2002 330 cic
Belt slips (maybe due to bad idler or tensioner), charge light flashes. Next step would be belt breaks, car overheats. You should be able to hear that though. Still, belts are a possibility. Doesn't matter - old thread.
edit: too bad the OP did not come back and tell people what the solution was.
dknightd is offline   Reply With Quote
Old 10-17-2012, 10:42 PM   #22
curca
My Ride: 2002 325i
check your belt routing, I had same problem when I changed my belts, I dont know how but I installed belt on top of alternator instead from bottom, it was running fine but it would slip in higher rpm like in highways and I would drain my battery
curca is offline   Reply With Quote
Old 10-17-2012, 10:55 PM   #23
scarede46er
My Ride: 2001 BMW 325i ZSP
The belt could be slipping. Happened tome once on a Fiat I used to own
