Old 05-28-2010, 03:04 PM   #1
gageweakley
My Ride: car
328i Engine knocking sound
Hey guys i got a 00 328i with 120k, Recently i started hearing a knocking sound coming from what sounds like under my valve cover or just to the left of it when looking at the engine in front of the car. It seems like it only happens when the engine is warmed up. I recently did the valve cover gasket along with the vanos seals and spark plugs, the whole coolants system except for the radiator, the power steering pump, fuel filter, belts and pulleys and intake and exhaust side camshaft position sensors. I am not getting any codes, but the car is running rough and the power feels choppy.
please guys help, i'm 19 i do all this work myself and i'm trying so hard to keep from taking this shop!!!!!!!
gageweakley is offline   Reply With Quote
Old 05-28-2010, 03:07 PM   #2
Bondga
My Ride: 328Ci
Is it random. Kinda soft knock knock kncok. Comes and goes. sometimes when you rev it goes away kinda knock?
Bondga is offline   Reply With Quote
Old 05-28-2010, 03:26 PM   #3
gageweakley
My Ride: car
well its pretty constant at idle, when i rev it it defenitely seems to be muffled by the sound of the engine and stuff, why you have any ideas??
p.s sick car ha
Old 05-28-2010, 03:28 PM   #4
Bondga
My Ride: 328Ci
nope thats just what mine does... not really sure where mine comes from but i'll figure it out one of these days.
I would think something is loose or valve tap (i dont think we get that though)
Old 05-28-2010, 03:33 PM   #5
Toad21
My Ride: 00' 328CI
I have the same engine and I have a slight knocking as well. Most likely the lifter heads, and I wouldnt worry to much about it.
If your power is choppy, have you cleaned your throttle body yet? Mine performed alot better after I cleaned the throttle body, which takes about 1 hour and $5 in carb cleaner and towels.
Toad21 is offline   Reply With Quote
Old 05-28-2010, 03:57 PM   #6
gageweakley
My Ride: car
i'm learning as i go along haha any good diy's out there for the throttle body?
Old 05-28-2010, 04:16 PM   #7
dstreet6
My Ride: 99 323i
Is it a loud knocking or ticking noise and was it intermittent? It happened to me a week ago and came to find out it was my AC compressor. I thought and even in the first video it was coming from valve cover but it's actually below when the AC engages.
Here's my post and how I actually found the issue:
http://forum.e46fanatics.com/showthr...ht=engine+tick
I hope this helps and good luck buddy. It doesn't explain the choppiness though in your case.
dstreet6 is offline   Reply With Quote
Old 05-28-2010, 04:43 PM   #8
gageweakley
My Ride: car
i will look into both things, thanks. I first noticed the choppiness when i had my car in cruise control, i swapped out my diff for the 3.46 and just to be easy on the motor i go 60 on the highway and it felt like i was tapping the break or something! it happens when the car has been running for a while, they are probably unrelated problem i guess i was just hoping for one fix for a couple of problems.
Old 05-28-2010, 09:27 PM   #9
ASD123187
My Ride: /!\
Send a message via AIM to ASD123187
Most likely one of your spark plugs. Just pop off the coils and make sure that the spark plugs are tightened correctly. AND REMEMBER, TORQUE TO SPEC.
ASD123187 is offline   Reply With Quote
Old 05-30-2010, 09:13 AM   #10
gageweakley
My Ride: car
i made sure to torque everything to spec when i did the spark plugs a while back and for what its worth is used high end plugs but i am getting desperate so i guess thats what i i will do this morning, thank you for the advice!
Old 10-11-2010, 07:30 PM   #11
blown330ci
My Ride: 330ci
I get a random knocking at idle that sounds like something bouncing around inside the intake manifold.
blown330ci is offline   Reply With Quote
