Old 05-29-2010, 10:09 AM   #1
madonion48
My Ride: e46 320i 2171cmc
Torque drops too much e46 2.2i
Hello, I hope I posted in the right section.
Having more time to spend driving, I noticed something bad going on. Car lost its punch at low revs(up to 3k rpm) and around 4200 rpm looses torque very fast, like an air gap, for a fraction of a second, then continues accelerating.
So I went to a dyno to see the graphics. The guy there told me the AFR(air to fuel mixture) is too high(too little fuel) and it should be under 12. In the 3rd run, he tested the car in 4th gear, the others were in 3rd.
Monday I am going to a tester to see if there are any fault codes. I have no "check engine" on the dashboard, no warnings.
What could cause the torque drop? Could be the Vanos system? The engine doesnt rattle, no weird noises, nothing.
Name:	cj 82 pov_1_2.jpg
ID:	362127   Click image for larger version
Name:	cj 82 pov_1_2_afr.jpg
ID:	362128   Click image for larger version
Name:	cj 82 pov_3.jpg
ID:	362129   Click image for larger version
Name:	cj 82 pov_3_afr.jpg
madonion48 is offline   Reply With Quote
Old 05-29-2010, 12:56 PM   #2
paraklas
My Ride: ESS TS2 320ci
Have you checked/replaced the DISA ?
Old 05-29-2010, 01:56 PM   #3
madonion48
Where is DISA valve situated? And how can I check it?
eventually a realoem code
Old 05-29-2010, 04:46 PM   #4
madonion48
Found it. You think it could be it? Because there isnt any rattle ...
Old 05-30-2010, 11:34 PM   #5
Iceman00
Banned User
My Ride: E90 6MT
Looks like a normal power curve to me. How is the MAF? Running an intake? Do you have any vacuum leaks? And when is the last time the car was serviced?
Old 05-31-2010, 02:59 AM   #6
madonion48
Well, it needs its service done. I mean, oil and filters. But I'm concerned about the torque drop which happens always at the same rpm. If it was to be filters, wouldnt accelerate badly after an rpm point? Mine hesitates at 4200 and after, it continues to accelerate well.
The engine is stock, no modified intake. About vacuum leaks .. I dont think so, I think they are good.
Old 06-02-2010, 01:39 AM   #7
Iceman00
Banned User
My Ride: E90 6MT
vanos seals perhaps?
Old 06-02-2010, 06:28 AM   #8
kai-
My Ride: three two slow
I have the same problem, around 3000+ rpm, always in third gear.
I've checked camshaft sensors, DISA and had codes read... nothing.
I had a battery replaced and the issue seemed to go away, only for a day or so :\
kai- is offline   Reply With Quote
Old 06-02-2010, 07:27 AM   #9
paraklas
as mentioned, Check/Clean the MAF
Old 06-02-2010, 08:38 PM   #10
kai-
Also been done, as well as vanos seals. let me know how you go (op)
Old 06-02-2010, 08:47 PM   #11
Iceman00
Banned User
My Ride: E90 6MT
Knock sensor becoming old, and pickup up excess noise, and could cut back the timing and kill power, or pre cat O2 sensors could be old, or or or or. You really need to have some sort of scan tool hooked up to the sensors to see what the problem could be. Also check to see if the DISA is leaking or rattling.
