Sponsored by BimmerWorld
Old 05-30-2010, 12:53 AM   #1
Diazz
My Ride: Bmw 325Ci -01
Front wheels move back and forth?
Hey! i hope this is a good place for this question.
My front wheels are moving back and forth, while the car is completely still!
But, i am pretty sure its a beararm bushing (Spelling?) problem, i took of the wheel and tried to feel around with a short bit of pipe i used to bend the beararm a little bit, but now to the biggest questrion, what do you recommend to change? I found different setups with the whole beararms and then bushings mounted on, or ready to install bushings for the beararm.
I hope you guys understand what i mean, i really want to get this fixed, but im not used to having 1500000000000000000000 different solutions to one problem
Thanks in advance.
Diazz is offline   Reply With Quote
Old 05-30-2010, 09:08 AM   #2
ktmdrz400
My Ride: 330i and 540i
LCAB (Lower Control Arm Bushings) are bad.
ktmdrz400 is offline   Reply With Quote
Old 05-30-2010, 11:08 AM   #3
jpr
My Ride: '99 323i
concur - most likely culprit is a worn control arm bushing (piece 6) for which you either replace just the bushing or the whole assembly. Your additional choice is to use a polyurethane bushing (such as powerflex) instead of the rubber OEM type.
There is also a possibility that worn ball joints in the control arm itself (piece 5) are also contributing to the problem.
http://www.realoem.com/bmw/showparts...53&hg=31&fg=05
jpr is offline   Reply With Quote
Old 05-30-2010, 11:17 AM   #4
alwaysbored786
My Ride: M3
fcabs, also check your ball joints as well. My fcabs were going so i replaced them, only to find out my ball joints are also slightly bad. Now i gotta replace controls and fcabs
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 05-30-2010, 01:23 PM   #5
Diazz
Thanks alot guys, i guess i can change all the bushings on the beararm? I was thinking of going powerflex! I have to do this soon, a week ago, i could barely move the wheel, now its moving a whole inch...
Old 05-30-2010, 02:13 PM   #6
jpr
My Ride: '99 323i
Just what part are you refering to as the "beararm"? Is that what you are calling piece #5?
Old 05-30-2010, 05:56 PM   #7
Diazz
Exactly Sorry!
Old 06-05-2010, 08:18 PM   #8
DontWriteGraff
My Ride: E36///M.TchnoHrdtop
Where can i see what piece is what #?
DontWriteGraff is offline   Reply With Quote
Old 06-06-2010, 02:16 PM   #9
I_Miss_My_///M
My Ride: 325i-RIP, '03 330Ci
The link to realoem.com in post #3.
I_Miss_My_///M is offline   Reply With Quote
