Old 05-30-2010, 10:32 PM   #1
SDKmann
My Ride: 01 Cherokee
Quick Exhaust Size Question
I could not find the answer to this to save my life, Ive been looking for about an hour and a half now, Im sure you can imagine how many exhaust threads there are on this site. It has recently come to my attention that my 325i has two pipes leading into the muffler, I am looking at the Vibrant stealth muffler that has a single inlet, so obviously I need a Y pipe. What size are the stock 325i exhaust pipes, are the 2.5 in.? Thanks in advance for your help, Im ordering my exhaust components as soon as I have the information.
Second question, Im trying to find Y pipes on Ebay, would it be cheaper to have one made? If my mechanic has a functional welder at his shop (recent flood) I would take it to him but I doubt he has the correct sized pipe just laying around. Could I potentially pick some piping up at a hardware store or something and have it be cheaper yet non-restrictive?
SDKmann is offline   Reply With Quote
Old 05-30-2010, 10:43 PM   #2
lllSupra
My Ride: E46 330i
do a 2.75 y to a 3" single
lllSupra is offline   Reply With Quote
Old 05-30-2010, 10:53 PM   #3
SDKmann
Is 2.75 the correct size of the stock 325i pipes or is that a different size you suggest I go with?
Old 05-30-2010, 11:32 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Go to http://drgas.mybisi.com/product/stra...rge-collectors
get the 2.25 to 3 inch Y pipe. The actual pipes on the 325 are about 2inches (actually a little less) and will slip to fit in the Y pipe.
Old 05-30-2010, 11:58 PM   #5
SDKmann
$110 for the Y pipe?! Thats almost as much as the muffler Im buying, I think Ill stick with the ebay magnaflow options that are about $30. Thanks for the help on the size though.
Old 05-31-2010, 09:06 AM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
You'll get what you pay for with a Y collector. They can make or break you on power.
Old 06-01-2010, 12:32 PM   #7
SDKmann
Will it really matter at the very end right at the muffler? And would the straight through design of the muffler cancel out any of the restrictions of a cheaper Y pipe? I have a 325i and the only engine modification I have is a K&N SRI from the previous owner. Im just having the shop make one for me now anyways. Im just doing the exhaust for the sound, I wasn't aware that there could be performance changes, positive or negative, from it.
Old 06-01-2010, 03:50 PM   #8
Iceman00
Banned User
My Ride: E90 6MT
Make sure you have it convert to a single pipe about 6-12 inches from the header. A good amount of torque and some peak power can be gained.
Old 06-02-2010, 07:36 PM   #9
SDKmann
Im assuming that you mean that I should have my entire exhaust system, from 6-12 in. from the header, converted to a single pipe correct? Ill eventually move to this but at the moment Im just adding the axel-back unit. Eventually Id like to do a single 3in. from the cat with a single resonator and the muffler. Right now though I just have a little extra money to spend and would like to give my car a little extra bark without being too loud.
Old 04-03-2013, 12:29 AM   #10
martiwil
My Ride: 2001 325i
Did you end up putting this exhaust? I'm looking into buying this and I also have a stock 325i. Thanks :-)
martiwil is offline   Reply With Quote
