Old 05-31-2010, 10:08 AM   #1
niko084
My Ride: '02 330ci
Need some down force I'm guessing on my '02 330ci
It's my DD but I do some track days with it and on the long straight I'm getting up around 140 and the car gets a bit uneasy feeling, to me I think it needs some down force, in the front and back and I'm just kinda trying to find out what functions well and what's for show..
I don't want to spend a ton of money as I said before it's my DD, so it spends most it's life around 75mph, but I would like it to be a bit more stable on that straight.
It's a pretty near stock suspension '02 330ci with the sport package.
Only thing is it has new bilstien shocks, I am planning on a strut bar and sway bars this summer, can't really lower it any further and drive it around here without having to be really careful.
niko084 is offline   Reply With Quote
Old 05-31-2010, 10:16 AM   #2
ChasCan
My Ride: 2001 330xi
I would have suggested H&R or Eibach Sport lowering springs, but you said you'd rather not do that. However, I gotta say that getting your car lower to the ground is the #1 thing to do for tracking. Other than that, you're looking at a front & rear spoiler at the very least, and the body mods can easily run up the $$$ real quickly. Chas
ChasCan is offline   Reply With Quote
Old 05-31-2010, 10:20 AM   #3
niko084
My Ride: '02 330ci
I know and that's what makes me depressed...
If I move to Austin Texas it will get dropped!
Old 05-31-2010, 10:24 AM   #4
ChasCan
My Ride: 2001 330xi
Also nik, lowering your ride will automatically give you more down force. Not as much air under the car & more over the top. Chas
Old 05-31-2010, 10:33 AM   #5
snowcatxx87
My Ride: 04 330CI
Don't put a wing on it for god's sake.
snowcatxx87 is offline   Reply With Quote
Old 05-31-2010, 10:37 AM   #6
niko084
My Ride: '02 330ci
Ya, I know, that's why I mentioned it.
I would rather not but I want more stability.
Are the lip spoilers worth anything at all? I think they look clean but have heavy doubts about any noticeable difference.
I considered the CSL, but I don't think it would look very good without compliment from other extensive expensive body mods/
Old 05-31-2010, 07:03 PM   #7
snortdavis
My Ride: 2006 M3, 6mt TiAg/Bk
What are your alignment specs?
SNORT
///M3 '06 COUPE 6MT, SCHWARZ/GRAUR.I.P.
///M3 '06 COUPE 6MT, TITAN SILBER/SCHWARZ -- NO SUNROOF
snortdavis is offline   Reply With Quote
Old 05-31-2010, 07:35 PM   #8
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
What kind of tires are you running? I hit 140mph on my A/S tires which felt very floaty. I've hit 150mph on my summer tires and it felt planted.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-31-2010, 10:07 PM   #9
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Putting down force on a car with stock springs is ridiculous.
If you are willing to put a wing on the car then you're clearly willing to make some compromises. Instead of going through the trouble of adding a wing, just accept that springs are the #1 thing you need to do to make the car feel more stable and then drive more cautiously around town. It is not hard to drive a lowered car, even on horrible roads if you just keep your head screwed on straight.
With your Bilsteins you should consider going with some H&R Sport springs if you want to make a minimal compromise and if you're willing to go a step further then order up some Ground Control coilover retrofits so that you can use linear spring rates in the front and rear. I'd think that 350# front and 450# rear would work out well (I don't think that I'd go higher than that with the way your Billies are currently valved).
SpeedDemon is offline   Reply With Quote
Old 06-01-2010, 09:02 AM   #10
teamdfl
Slow in, slower out
My Ride: 325it
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 06-01-2010, 11:22 AM   #11
FTWeisse
My Ride: has no hip-hop rimz
Tee hee
Old 06-01-2010, 02:45 PM   #12
niko084
My Ride: '02 330ci
Alignment I'm running stock numbers still.
Tires, I didn't think about that...
But I was running AS tires... Waiting for some more cash to get my other wheels/tires for summer/track use.
I'll get a tape measure but seriously... ..
My Camaro SS was dropped 1.5" and was impossible to get into a lot of parking lots without bottoming out in the center, I believe it sits higher than my 330.
Bumps in the road are the least of my worries, at least those I can steer around.
Old 06-02-2010, 08:19 AM   #13
snortdavis
The Camaro probably stuck out way farther in the front with the pointy nose.
Just Sayin'
SNORT
Old 06-03-2010, 01:32 AM   #14
SpeedDemon
Just take the driveways and ramps slowly and at an angle and you'll almost never have a problem.
My car is really low and I have never touched bottom with it.
Old 06-03-2010, 02:56 AM   #15
bigjae1976
bigjae1976's Avatar
I would try some good tires first before anything. AS tires aren't made for grip. Aren't BMWs engineered to travel at Autobahn speeds? I would think that our cars, if well maintained, wouldn't have any issues safely going 150mph.
Old 06-03-2010, 03:25 PM   #16
FTWeisse
If you have the sport suspension it would be fine - even the non-sport would be ok, but I wouldn't do it.
