Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#241 |
#242 | |
My Ride: M3 & 323Ci (sold)
According to what you posted that means your car is putting down 380 HP and 357 lb-ft of Torque according to ESS Stage 2 Specs. "Correction factor for drivetrain loss is 15% above RWHP as seen in dynograph (RWHP/0.85) (E46 330) Boost pressure: 8 PSI Horsepower: 345 SAE/350 DIN Manual Torque: 317 lb-ft/430 Nm Manual what Octane gas did you run? |
#243 |
I'm actually running stage 2+ (8.5 PSI) without the modified cams. That is rated at 370 or 375hp.
It's also overboosting to 9.5 at the top. The gas is 94 octane. I only have a baseline run with the old engine (M54B25) with Dinan chip. It pulled 172/162. The chart is on the second page of my build thread (in the sig).
Because sleeper.
#244 |
Car/Engine: e46 coupe / M54B30 140,000 miles Mods:BMW Performance intake, bimmer brakes gen 1 headers,muffler delete w/factory resonators, rouge pulley's,1 step colder spark plugs, uuc lightweight flywheel, custom brentuning tune Peak numbers: 260.9 hp /242 tq at flywheel 221hp/206tq to the wheels given 15% drivetrain loss Dyno type: Dyno Dynamics shootout6 the 238 hp was before tune ![]() air fuel ratio graph
![]() Last edited by DarkJoker; 02-26-2012 at 06:12 PM. Reason: information/air fuel graph |
#245 |
There's no way you're making 300 crank (assuming 15% drivetrain loss)
![]() 330i ZHP 6MT | H&R Sport Cup | BMW Performance Intake & SSK | OEM Clears | WeissLicht Angel Eyes | Coby Wheel |
#246 |
ive been reading dyno dynamics dynos are weird with there Numbers and theres different modes for everything
http://www.xspeed.com.au/tech_features.php?tech_id=19
![]() Last edited by DarkJoker; 02-25-2012 at 08:16 PM. |
#247 |
Maybe they measured w/ crank power.
15% loss of 260 is 221whp. Which would be a more appropriate for your modifications.
#248 |
i think you maybe right on that one because on the side of the graph(which you cant see in my first picture) it says flywheel hp
i havent got the actual files just printouts at them moment thats the tuner's picture(the first picture)
#249 |
#251 |
Unless you're buying an engine and want to compare one to another.
Or if you're engine tuning, you want to know exactly what each mod will do at the output. |
#252 |
Modded ///Member
Car/Engine: e46 sedan / M52TUB28 148,500 miles Mods: resonator delete, AA muffler Peak numbers: 178.86 hp 192.48 ft-lbs Dyno type: Dynojet Last edited by mestupmonkydude; 05-25-2012 at 12:20 AM. |
#253 |
Awesome numbers man, you should start modding!
#254 |
Car: 2004 330ci ZHP Mods: None Dyno: Dynojet, SAE- 1.01 Correction factor, 85 degrees, 30% humidity Last edited by Grande D; 05-24-2012 at 08:51 PM. |
#255 |
Modded ///Member
#256 |
I just saw it, I can't wait to see what you end up doing.
#257 |
Car/Engine: E46/M54B30 Mods:ZHP, Active headers, Highline tuning exhaust, Shark injector, Sprint booster, 3.46 differential Dyno type:Dynojet Peak numbers:227whp/219wtq Graph: |
#258 |
Modded ///Member
Well I've got headers I have still yet to install. That may be one diy I may take to the shop. Then after that really not much I can do but a better exhaust. I should probably set aside some money every month for a supercharger. Or pay techniquetuning lots of money for a turbo setup for the 328i. It shouldn't be too hard since they have a kit for the e36 328i, which is basically the same engine but with single vanos.
#259 |
120,000 miles 2003 325i
Schrick 264/248 cams Ebay headers AA custom tune 185 whp, cant remember torque or find the chart
![]() Schrick 264/248 | Ebay Headers | AA dyno tune | SSR GT2 18x9 | 3.46 | Full OEM Mtech 2 |
#260 |
Car/Engine: E46/M54B25 Mods:Schrick 264/248 cams, Ebay headers, AA custom tune, stock intake and exhaust Dyno type:Mustang Peak numbers:185whp/158wtq Graph:
| Tags |
| dyno, dynoed |
