Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.63 average. Display Modes
Old 11-07-2012, 06:24 PM   #301
Andy2108
My Ride: SpecE46 & E46 M3
Originally Posted by stosh1 View Post
Hmmm, yeah, your numbers do seem a bit on the low side w/those mods...as I would expect somewhere around 290ish w/o software. Your AFR #'s look decent as well, although the scaling makes it a little difficult to read, and certainly not off enough to cause any serious reduction in power. I'm sure that your car would still respond to software though w/more optimized ignition and cam timing values. Could also be a very low reading Dynojet...yes, they are out there!
Also, you might want to do a full compression/leakdown test just to confirm the general health of the motor.
Yeah, that's next. I guess I should do it before the software.
Originally Posted by Iceman00 View Post
It's probably a combination of the engine pulling timing and needing a valve adjustment (espcially if you drive it a bit harder than most)
The previous owner did a valve adjustment, then I had one done not long ago and only a few of them needed adjusting. I do drive hard though. It's had probably 5 full track days since the adjustment.
Meh, could be, but the graph will usually spike a little bit (or a lot in some cases) when timing is being pulled and his curve looks pretty smooth. I believe that he also said that the temps were on the cool side, which would help fight off detonation/prevent timing from being pulled.
Yes, ambient temp was plenty cool. My fuel was all fresh 93 octane from BP.
Old 11-13-2012, 08:29 AM   #302
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Ice Man you got a PM. Need your help with my dyno runfiles
Car/Engine E46 323i w/ M54B30 ZHP Engine running on MS42 328 Tune (90,000 miles). ZF Automatic Transmission
Mods: Shark, AFE CAI, Technik Gen2 Headers, Rogue Engineering Under Drive Pullies, UUC TSE3 exhaust, Plasma Ignition Coils, Shark Injector
Dyno type: Dyno Jet
Peak numbers: 199HP /197 Ft/Lbs
Old 11-13-2012, 09:48 AM   #303
jared_wiesner
My Ride: 1999 328i (M54b30)
Very healthy numbers for an M54 on a M42 DME with an automatic.
The curve of the graph doesn't look like the computer is getting too screwed up and pulling crazy timing in places or anything like that either.
jared_wiesner is offline   Reply With Quote
Old 11-13-2012, 11:53 AM   #304
Steven747
My Ride: 05 330ci
flashtwosix if you had a 3.0l tune imagine how much hp you would pick up, or is is not supported on ms42?
Old 11-13-2012, 11:55 AM   #305
flashmeow
Banned User
I know huh? I can't flash my ms42 for the 330 tune. However, updating my entire car to ms43 is a long term goal of mine though
sent from my dahc-6900 using Bimmer App
Old 11-13-2012, 12:48 PM   #306
Iceman00
Banned User
My Ride: E90 6MT
Did you get my PM?
Old 11-13-2012, 03:11 PM   #307
flashmeow
Banned User
Did you get my PM?
Yes sir. I will send them to u after work
Old 11-13-2012, 08:29 PM   #308
flashmeow
Banned User
thank you for the assurance. my biggest concern was timing issue also.
Did you get my PM?
e-mail sent. Feel free to keep and use the run files for your archives
Old 11-15-2012, 01:05 PM   #309
Iceman00
Banned User
My Ride: E90 6MT
I did the math, the numbers on the screen are incorrect and are likely do to the spike at the beginning of the dyno. Torque = (5252*hp) / RPM.
Old 11-15-2012, 01:07 PM   #310
Iceman00
Banned User
My Ride: E90 6MT
FYI, those numbers are EXTREMELY healthy, and about 20whp down on a manual counterpart. I don't think there is too much to be gained by changing the software, the biggest losses are do to drivetrain.
Old 11-15-2012, 01:59 PM   #311
flashmeow
Banned User
Iceman, that is why u t the expert. Thanks
Old 11-27-2012, 03:52 PM   #312
Andy2108
Iceman, do you see a consistent drop in power between summer and winter blended fuel? I may have dynoed with winter fuel and that could partially explain my numbers.
Old 11-27-2012, 04:25 PM   #313
Iceman00
Banned User
My Ride: E90 6MT
I've never heard seen anything of the sort. Do we know the dates when the blends are specifically changed? I've taken dynos year round, and it has been fairly consistant.
Old 11-27-2012, 04:51 PM   #314
Andy2108
If you live in Florida then I doubt you run a winter fuel...
I asked my buddy at the gas station and he said that they switched a few months ago. He mentioned something about switching between 7lb and 9lb fuel (per gallon).
I live in Kansas.
Old 11-27-2012, 04:58 PM   #315
jared_wiesner
As someone who lives in Canada, yes, winter fuel will hurt power output. Most winter fuels are "winter fuel" because their ethanol content has been bumped up close to the maximum allowable. This is to help prevent freezing in the gas line. Iceman likely hasn't had to deal with this living in Florida, I'm talking -5 F and colder temps being a concern. I deal all winter with people coming into our dealership complaining of poor mileage compared to their summer mileage. Between the slush on the roads and the fuel it's to be expected. That being said, you'd might still make more ultimate power on a dyno because you won't have to worry about heat soak. I tend to notice my car feels the fastest in the spring and fall when temps are cooler and I'm not using winter gas.
Old 11-27-2012, 05:01 PM   #316
Andy2108
Yeah I was thinking something along the lines of this.
Old 11-29-2012, 12:44 PM   #317
stosh1
My Ride: M3
What's up everybody!? Alright, thought we'd give it one more go on the dyno just for good measure...before I tear it back down again. We pulled a little more fuel up top and played around w/the timing a little bit too, and well...I think the results speak for themselves!?!? We managed to eek out a few more ponies, and torque is now up to 275ft lbs. The car is making 300HP by around 6,000ish rpms and then hitting 360+HP @ 7,700rpms and holding it all the way to 8,500rpms. The car is running very, very well!
'04 AW/IR Not Stock
stosh1 is offline   Reply With Quote
Old 11-29-2012, 06:54 PM   #318
Hornung418
My Ride: '04 MB ZHP
Holy S hit! Those numbers are fantastic for a N/A M3!
Hornung418 is offline   Reply With Quote
Old 11-29-2012, 07:34 PM   #319
Stinger9
My Ride: '04 330Ci
Tempted to follow?
Old 11-30-2012, 08:52 AM   #320
stosh1
My Ride: M3
Thank you sir!
Originally Posted by Stinger9 View Post
Tempted to follow?
Do it, no regrets!
'04 AW/IR Not Stock
dyno, dynoed
