Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.63 average. Display Modes
Old 05-04-2013, 08:28 PM   #341
reggid
My Ride: .
Originally Posted by xixixi View Post
fvck numbers, line em up
if you want to compare cars goto a dyno day, same machine, same conditions, same operator, same strapdown technique and process used then you are about as close to being able to make comparisons as it gets.
lining them up doesn't compare engines, it compares engines, gearing and weight.
reggid is offline   Reply With Quote
Old 05-04-2013, 11:46 PM   #342
Steven747
My Ride: 05 330ci
E46 Dyno Thread
Also compares drivers when head to head
Old 05-05-2013, 12:33 AM   #343
reggid
My Ride: .
good point especially from a dead stop
Old 05-05-2013, 08:13 AM   #344
mko9
My Ride: '04 330i ZHP
numbers mean nothing, lol.
VIR - 2:28.3
Summit Point Main - 1:34.6
How about those numbers?
Mike
'04 BMW 330i ZHP
'11 BMW 535i
'13 Land Rover LR4
mko9 is offline   Reply With Quote
Old 05-07-2013, 03:13 AM   #345
reggid
My Ride: .
Originally Posted by mko9 View Post
VIR - 2:28.3
yes, certainly means nothing to me
Old 05-07-2013, 06:02 PM   #346
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Vehicle is a 2002 325Ci.
Dyno'd around 4 years ago bone stock with only a K&N panel filter @ 161whp on a mustang dyno (i think).
Current performance mods are a custom after axle Y-pipe into a 3" Vibrant muffler, K&N Typhoon intake, UUC pulleys, Besian Systems Vanos Seals, 3.46 auto diff swap, and regular maintenance. The car currently has 112k miles. It managed to put down 165whp.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 05-12-2013, 05:52 PM   #347
Iceman00
Banned User
My Ride: E90 6MT
Car/Engine: E46 M54B30
Mods: ESS Twin Screw stage II+ 8.5psi supercharger kit, Schrick 248/256/10.8 forced induction camshaft set , Technik Gen2 ceramic-coated headers, SuperSprint free-flow race cats, SuperSprint free-flow middle muffler, Eisenmann race end muffler, OEM "modified" airbox, Snow Performance MPG-MAX water/meth kit
Dyno type: Dynojet
Peak numbers: 310whp/278WTQ
Graph
Old 05-14-2013, 03:50 PM   #348
vaio76109
My Ride: Race Cars
This is a customer's E46 M3 race car(sub 2600lbs dry):
BW Carbon airbox
EPIC Alpha N tune
SS V1 headers with Swaintech coating
BW 3.5" race exhaust
Mild Schrick cams
Pullies
Stock internals
vaio76109 is offline   Reply With Quote
Old 05-14-2013, 06:16 PM   #349
Iceman00
Banned User
My Ride: E90 6MT
Old 05-14-2013, 10:53 PM   #350
SK330ci
My Ride: 02 330ci w/ 3 Pedals
My question is this, what does a stock E46 M3 make (average) for WHP and WTQ on a Dynojet when the CF is set to SAE?
EDIT: Read the entire thread, I have my answer.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-15-2013, 06:50 AM   #351
Twin_Turbo_S54
My Ride: M3
I just saw this thread.
E46 M3
3500 cc stroker
Twin Turbo
Nitrous
9200 rpm limiter
990 whp dyno Dynamics in shoot out mode (= zero correctio)
This equals to 1180 whp dyno jet.
Holding the fastest 60-130 mph WORLD RECORD for E46 M3
This is my E46 M3 TT.
I work on a E46 Sedan X Drive. Put another 3500 cc S54 stroked engine into E46 Sedan X Drive. Twin Turbo....
Goal is to make over 1300 whp and go 60-130 mph in less than 3 seconds
Link to my XM3 Twin Turbo
http://forum.e46fanatics.com/showthread.php?t=969776
La ilahe illallah = God is one and only
Twin_Turbo_S54 is online now   Reply With Quote
Old 05-15-2013, 10:31 AM   #352
SK330ci
E46 M3
3500 cc stroker
Twin Turbo
Nitrous
9200 rpm limiter......................
I was going to ask you some questions, but i see you deleted everything out of your own thread; the thread you have a link too.
So i don't care, i have no questions now.
Old 05-15-2013, 02:40 PM   #353
murph1379
My Ride: 2006 M3
Well I finally got the car to a dyno, and have something to share of my own...
M54B30 ZHP
E36 S52 headers to a hacked up dowpipe/merge, to 3" high-flow cat and 3" exhaust
AFe intake
AA Tune (before the headers, I did this dyno to help inform an update)
Rogue pulleys
DynoJet dyno
217hp/206tq
We'll see if this changes much after AA adjusts the tune for the new headers.
murph1379 is offline   Reply With Quote
Old 05-15-2013, 09:21 PM   #354
SK330ci
Exclamation
SOME GUY JUST POSTED UP FOR SALE A SET OF BRAND NEW SCHRICK 264/248 CAMS. SOMEONE SHOULD MOVE ON THIS QUICK !
http://forum.e46fanatics.com/showthread.php?t=987372
EDIT: They got SOLD.
Old 05-15-2013, 10:33 PM   #355
Iceman00
Banned User
My Ride: E90 6MT
Murphy, something is just not right with that dyno - the low end is VERY soft. I would have active take a strong look at the Vanos curves, the A/F ratio is spot on however.
For comparison, see page 1 of this thread.
(it may be that it just isn't the tune, it could be the exhaust side - a bad merger could cut exhaust velocity and cause a drop at low end, or the headers themselves might not be ideal?)
Old 05-16-2013, 02:59 PM   #356
murph1379
My Ride: 2006 M3
Yeah, the headers themselves are pretty craptastic, due to needing to comply with SCCA ST category rules. The E36 OBD2 headers I'm using have a 2" output, bolted to a 2.25" tube, using a crappy merge to a 3" cat.
Here is a picture of the headers:
And a picture of the downpipe, bolted to the shorty headers that I couldn't use:
And a picture of the merge/cat:
So you can see, this is far from ideal. I'm hoping at this point that this is at least better than the stock headers once the tune is updated!
Old 05-16-2013, 06:26 PM   #357
Iceman00
Banned User
My Ride: E90 6MT
It probably will be...but I would have personally done the CAT a bit past the merger as opposed to the middle of it. Otherwise, it doesn't look bad. if your tune works, it would put you within range of similarly modded cars are putting down - and be emissions compliant.
Old 05-23-2013, 01:37 PM   #358
Marek555
My Ride: E46 328i 174kW
Car/Engine: E46 M52TUB28
Mods: M54B30 intake manifold, DME remapped, Remus Rallye DTM muffler, K&N drop-in airfilter, new VANOS seals
Dyno type: Dynojet
Peak numbers: 193whp/192wtq
Some videos also:
Marek555 is offline   Reply With Quote
Old 05-23-2013, 07:55 PM   #359
Hornung418
My Ride: '04 MB ZHP
Re: E46 Dyno Thread
Great numbers!
Hornung418 is offline   Reply With Quote
Old 05-24-2013, 06:03 AM   #360
daniel_f.
My Ride: 330iC
Mods: DME remapped
Dyno type: Dynojet
Peak numbers: 236PS/311Nm
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
dyno, dynoed
