Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.63 average. Display Modes
Old 06-21-2013, 12:53 AM   #381
Llink78
My Ride: 2002 330i
Originally Posted by indoafro View Post
ol, so maybe here's some list i need to get it done
rebuilt exhaust (make x pipe, 3 inch/ any suggestion ?)
M54B30 intake manifold
and header ?
about the header, can anybody tell me what is the best header ? (i live in nashville, TN, i want upgrade the header, but can u tell me the best header that still can pass the emision test )
to pass emissions and do headers its not worth it. If your inspection does not hook up to a sniffer, then get catless headers and install O2 sims. If you have a sniff test in TN then dont bother. The Cats are what restricts the exhaust and creates back pressure. If you dont want to deal with that. Start with the intake manifold and get a BMW performance or GruupM intake and open up the exhaust more.
Llink78 is offline   Reply With Quote
Old 07-03-2013, 05:15 PM   #382
indoafro
My Ride: 325ci
E46 Dyno Thread
for bump this thread, i have some question
i read several thread about intake manifold swap from M54B25 to m54b30 manifold,
should i put the m54b30 TB or just run my m54b25 tb ? because i bought the manifold include the TB too...
indoafro is offline   Reply With Quote
Old 07-03-2013, 05:29 PM   #383
Llink78
My Ride: 2002 330i
I never had to do the swap bc I have a 330 but I'm 90% sure you need a 330i TB, and air box as the piping is all larger.
Old 07-03-2013, 05:36 PM   #384
indoafro
My Ride: 325ci
E46 Dyno Thread
i've read a lot of thread about the swap, but they swap just the manifold, not the tb
i already bought the manifold include the disa and the TB.. it was pretty good deal, thats why i bought it..it was parting out car from 330..
i know about the piping, the seller include the piping from the tb to the mad sensor..all i need is just an adaptor to the map sensor...
what do u think guys ? shoul i use the m54b30 tb or use my m54b25 tb ?
Old 07-03-2013, 06:23 PM   #385
indoafro
My Ride: 325ci
E46 Dyno Thread
anyway, just dyno my car
325ci 2001
custom cai (long tube)
muffler delete
iridium ngk spark plugs
VERY DISSAPOINTED...................
any ideas to break 200HP ?????
Old 07-03-2013, 06:52 PM   #386
tachi1247
My Ride: '04 330i
Re: E46 Dyno Thread
At the wheels?? Pray lol. It can't be done without forced induction. Your not gaining 25% more power with bolt ons
tachi1247 is offline   Reply With Quote
Old 07-03-2013, 07:10 PM   #387
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
325ci 2001
muffler delete
Attachment 514433
Well you could hit 200 plus WHP on your 2.5L, but it would be reasonably expensive to do it. I could give you the list you'd need to push past the 200 plus WHP mark, but it sure would be much easier to go with either Nitrous or a Supercharger.
BTW, there's nothing wrong with 161WHP from a 2.5L.
SUMMIT POINT WV 1:24:229 SCCA
Old 07-03-2013, 07:43 PM   #388
indoafro
My Ride: 325ci
E46 Dyno Thread
could u list it ?
well supercharger is my longterm project..i want to hit 200 HP first...or atleast 175..
i will be put 330manifold and 330 TB...after that, im gonna do some x pipe on the exhaust..
need to tune the dme..if somebody can teach me, i will be so happy..because its really hard to find someone that can tune the dme/flash the ecu in here (nashville,TN)
i know header will totaly pull the hp, but i still dont want to messing up with header, because i want to find some header that can fit the cat and o2 sensor so i can pass the emition test every year...
any idea about camshaft ?
Old 07-03-2013, 08:23 PM   #389
Rob43
Rob43's Avatar
^ from your response I can easily tell you're not ready.
So for now, no list.
Keep in mind this is not a "Magic" list, all this info is here in this sub forum already; search for it, you'll gain some knowledge.
Good luck.
Old 07-07-2013, 04:22 PM   #390
Iceman00
Banned User
My Ride: E90 6MT
Hoveringuy
E30/M54B30
Custom Intake, S50B32 headers, custom exhaust, ZHP cams, Megasquirt (MAF removal)
Old 07-13-2013, 09:54 PM   #391
SoloII///M
My Ride: Many
Here's my plot from the dyno tuning session today. We did about four hours of WOT tuning on the dyno (35 runs) and another 4-5 of part-throttle to get the car running right. We were getting a lot of heat soak (I need to make a shield for my intake pipe). I suspect if we had let the car cool we would have seen higher peak numbers, but I don't really care about the absolute numbers.
Peaks of 230whp / 228 wtq
Mods:
M54B30, 0.030" over, ZHP cams, running Megasquirt and E85 (flex-fuel)
Technik V3 headers into Burns megaphone collector to 3" pipe, two mufflers and a dump before the diff
Decked head
Mild head port blending
M50 throttle body bored to 68mm
Long-tube 3.5" intake, filter in driver's brake duct
There is probably a little to be had between 2,500 and 3,000 RPM but the car is never used down there so we didn't bother spending a lot of time on it.
Name:	E46 DSP Dyno.jpg
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is online now   Reply With Quote
Old 07-13-2013, 10:59 PM   #392
Rob43
Rob43's Avatar
John,
Very solid,.......very solid indeed !
EDIT: Which Bimmer is this, I don't want to assume ?
Old 07-13-2013, 11:52 PM   #393
murph1379
My Ride: 2006 M3
E46 Dyno Thread
Wow, very smooth!
Wish I could go mega squirt, giving some thought to a piggyback, but it's not likely to be worth the cost in STX...
murph1379 is offline   Reply With Quote
Old 07-14-2013, 06:28 AM   #394
SoloII///M
My Ride: Many
E46 Dyno Thread
This is the 02 330Ci
John V
Old 07-14-2013, 06:30 AM   #395
SoloII///M
My Ride: Many
E46 Dyno Thread
Best part... No more nonlinear electronic throttle! The M50 linkage is so progressive....
John V
Old 07-15-2013, 01:45 PM   #396
jared_wiesner
My Ride: 1999 328i (M54b30)
Originally Posted by Iceman00 View Post
Hoveringuy
E30/M54B30
Wait just caught this, Does this mean our intake track is severely restricted at the MAF or that the engine responds really well to a solid state tune where MAF reading fluctuations are eliminated?
jared_wiesner is offline   Reply With Quote
Old 07-15-2013, 01:53 PM   #397
SoloII///M
My Ride: Many
What do you mean by a "solid state tune?"
If you're asking why the difference between the blue line and the red line, the answer is not because he removed the MAF.
Megasquirt is speed density based, not MAF based, so he didn't need the MAF. I left the MAF in on my Megasquirt setup (though it's not used) and made a little more power than hoveringuy. It's not a restriction.
John V
Old 07-15-2013, 02:39 PM   #398
jared_wiesner
Fair enough.
Old 07-26-2013, 05:06 PM   #399
powbmps
My Ride: 2002 330CiC
Car/Engine: 2002 330CiC
Mods: eBay headers, K&N CAI, canned Epic tune
Peak numbers: 211whp/218wtq
Dyno type: Dynojet
79 degrees and 60% humidity. Third run was the best. No stock runs to compare it to, but seems pretty good to me. Running rich (extra safe) though. Maybe some slight gains to be had by leaning it out up top, or not worth the hassle/risk?
powbmps is offline   Reply With Quote
Old 10-05-2013, 08:35 PM   #400
Marek555
My Ride: E46 328i 174kW
First time when I did dyno test, DISA valve and purge valve plugs were accidentally swapped, so I did new dyno run and here are results:
Car/Engine: E46 M52TUB28
Mods: M54B30 intake manifold, DME remapped, Remus Rallye DTM muffler, new VANOS seals
Dyno type: Dynojet
Peak numbers: 198whp/200,5wtq
Marek555 is offline   Reply With Quote
dyno, dynoed
