Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.63 average. Display Modes
Old 05-01-2011, 07:21 AM   #161
Iceman00
Banned User
My Ride: E90 6MT
Name fusion11 (bimmerforums)
Car/Engine E36/7 M54B30
Mods K&N FIPK, DINAN T/B, PLAT/IR PLUGS, DINAN STAGE 3 SOFTWARE, SUPERSPRINT HEADERS, FULL EISENMANN EXHAUST
Dyno type Dynojet
Peak numbers 221.29whp/214.16wtq
Old 06-23-2011, 01:46 AM   #162
Iceman00
Banned User
My Ride: E90 6MT
Car/Engine:E46 M54B25
Mods: TT Stage 1
Dyno type: Mustang
Peak numbers:279whp/247wtq
Old 06-23-2011, 02:05 AM   #163
Cruzader
My Ride: Alpinweiß facelift
This thread should be stickied if our cars made more power
Cruzader is offline   Reply With Quote
Old 06-25-2011, 03:01 PM   #164
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Car/Engine: E46 M54B30 55k miles
Mods: BMW Performance Intake / BimmerBrakes SS Headers / Magnaflow Catback / Lightened Flywheel / 3.38 Diff
Peak numbers: 199.8whp/194.5wtq
Dyno type: SuperFlow
phamine is offline   Reply With Quote
Old 06-25-2011, 03:06 PM   #165
Iceman00
Banned User
My Ride: E90 6MT
Time for some software.
Old 06-25-2011, 03:14 PM   #166
Iceman00
Banned User
My Ride: E90 6MT
Car/Engine: E46 M52tuB25
Mods: HIOP Racetec 3.0L Stroker Kit, Active Autowerke Supercharger Kit with Rotrex C38-71 stage II, intercooler kit, Dr. Schrick Camshaft, Supersprint Style Header, Magnaflow Race Cat, Eisenmann Race System Dual Exhaust Tips, UUC Short Shifter EVO3 with DSSR, UUC Stage II Aluminum Lightweight Flywheel, AEM Water Injection Kit.
Dyno type:
Peak numbers:248whp
Old 06-25-2011, 03:51 PM   #167
phamine
Not too many SuperFlow dyno maps on here. Anyone know the deltas between different dynos vs Dynojet?
Old 06-25-2011, 03:53 PM   #168
phamine
Sending out DME to AA this week. Will have it redynoed then
Old 06-29-2011, 01:04 PM   #169
Iceman00
Banned User
My Ride: E90 6MT
Name shifty1982
Car/Engine E46 M52tuB25
Mods Intake, SuperSprint header to exhaust system, Shrick 272/256 cams, custom tune. (dyno is before and after tune)
Dyno type Dyno Dynamics
Peak numbers 210whp
The most powerful B25 on here folks, and still some untapped potential.
Old 06-29-2011, 03:35 PM   #170
Hornung418
My Ride: '04 MB ZHP
Damn! It probably doesn't make for a good DD...but holy cow that's some power! 40whp more than me!
Hornung418 is offline   Reply With Quote
Old 07-02-2011, 02:44 AM   #171
TerraPhantm
My Ride: M3 & ZHP
Name shifty1982
Peak numbers 210whp
That's like what... a 60whp gain over what a stock B25 dyno? Practically looks like a B30 crank was swapped in between the runs
Old 07-03-2011, 12:46 PM   #172
southpaw
My Ride: E36 M3 and E36 318ti
Not an E46, but use it as a comparison tool.
1995 BMW M3
09/94 (OBD1)
AA intake. AA chip. AA Track pipe. AA Gen III exhaust. Maintenance. (OBD1)
Weighs about 2900lbs
Dynojet
68.65 degrees. 29.95" Hg. Humidty 27%. SAE 0.97
5th gear.
217.49 rwhp
212.21 rwtq
Max speed = 165.46 mph (3.15 LSD)
Video:
Can't post the dyno sheet at work, but here it is.
http://forums.bimmerforums.com/forum...&postcount=506
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 07-04-2011, 03:09 PM   #173
doshu
My Ride: E46 CI
Send a message via AIM to doshu
Friendly bump, because this trully deserves to be stickied in dme and engine tuning forum..
27,000 views..
doshu is offline   Reply With Quote
Old 07-08-2011, 09:56 PM   #174
Iceman00
Banned User
My Ride: E90 6MT
1995 BMW M3
09/94 (OBD1)
Dynojet
5th gear.
217.49 rwhp
212.21 rwtq
Video:
You're running a bit lean though, you could probably pick up a few more ponies by bringing that A/F ratio down, otherwise it looks good. I'd kill to have that much power. Then again who buys a 2.5 for power, right...
Old 07-09-2011, 03:33 PM   #175
TiAgTouring
My Ride: has a D-Pillar
Originally Posted by doshu View Post
friendly bump, because this trully deserves to be stickied in dme and engine tuning forum..
27,000 views..
+1
sticky this thread!!
TiAgTouring is offline   Reply With Quote
Old 07-14-2011, 11:18 PM   #176
brysterman
My Ride: 2002 330Ci
Here's mine, torque seems a little low. Shop temps were retardedly high, peaking at 108-110.
Car/Engine: e46 M54B30
Mods: AFE drop-in filter, eBay headers, Magnaflow catback, UUC pulleys, LTW5 wheels, stickers (+25 hp).
Peak numbers: 205whp/195wtq
Dyno type: Dynojet
~Bryce
brysterman is offline   Reply With Quote
Old 07-15-2011, 01:01 AM   #177
southpaw
Really? I thought I was running rich?
I get awful gas mileage, my car backfires, and my exhaust tips are filled with soot.
How do I adjust my AFR?
-Brandon
Old 07-15-2011, 01:30 AM   #178
Andy2108
My Ride: SpecE46 & E46 M3
14.7:1 is the ideal air:fuel ratio for (effectively) lower emissions, however NA cars tend to make the best power between 12.5-13.5:1, depending on the engine.
The lower the first number, the less air you get for a given amount of fuel, so more rich. 10:1 would be rich, 20:1 would be lean.
Southpaw, on you're dyno graph - on the AFR chart, that red dotted/slashed line is a general idea of where you want to be. You're running a little lean, but good for emmissions and therefore you're cats (if you still have them).
The most common way to correct the AFR's is to get an aftermarket tune.
De gustibus non est disputandum.
Old 07-15-2011, 01:53 AM   #179
southpaw
I have an AA track pipe which deletes the cats.
Oh yea? That's different from an ECU chip, right? I have an AA stage 5 chip.
-Brandon
Old 07-15-2011, 01:55 AM   #180
Andy2108
Your AFR's are fine. If you want perfect ones for racing or something then you'll need alot more than just an "off the shelf" ecu chip/tune.
dyno, dynoed
