Old 06-03-2010, 10:44 AM   #1
zorin
My Ride: 84 318i / 05 325i
m54b30 head on m54b25
I got a free complete b30 head and I was wondering what else do I need to make it work. I will keep my stock intake manifold and maf. I will be doing it together with my headers.
Founder & President of Executive Edition Executive Club
2005 e46 325i executive edition / 18" Hartge Classic / Vogtland springs / Depo clears / CSL spoiler / CF CAI / 330i front brakes / ACS roof spoiler / full OEM MTECH 2 kit / Clubsport splitters / UUC Sway Barbarians / UUC Underdrive Pulleys / powered ACS replica mirrors / OEM sport driver seat
zorin is offline   Reply With Quote
Old 06-03-2010, 11:30 AM   #2
Iceman00
Banned User
My Ride: E90 6MT
The B30 and B25 heads are the same save for cams (intake side) The manifold is different, and the B30's flows "better"
Old 06-03-2010, 11:37 AM   #3
zorin
I guess I will look for the intake manifold as well.
Old 06-03-2010, 11:47 AM   #4
Michel
My Ride: 330ci
I have stock b30 cams for sale if you need them. I'm also local.
Michel is offline   Reply With Quote
Old 06-03-2010, 03:41 PM   #5
Iceman00
Banned User
My Ride: E90 6MT
Only the intake camshaft is different, as it's 240 degrees of duration and 9.7mm of lift vs 224 degrees and 9mm of lift for M52tu and M54B2X motors. My advice is to grab ZHP cams, Shrick, or have a stock set reground to more aggressive specs. (have to find someone who would do that)
Old 06-03-2010, 05:48 PM   #6
zorin
so stock 330i head is not worth the hassle then
Old 06-03-2010, 05:51 PM   #7
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Unless you have the timing tools to do the head swap, it's not worth what you'll get charged for labor unless you're going with aggressive schrick cams, as Iceman said. If you were to do the entire head swap with schricks, along with the b30 mani and your headers, your car would be quite quick for a b25 though.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 06-03-2010, 07:35 PM   #8
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
IMHO you'd be better off selling the head to someone with a blown up B30, and use the cash for a more direct swap. A complete M54B30 would be better.
This is a common mistake on e30s, people put an M20B25 head onto M20B27 block and get it up and running, only to realize that an M50 swap would bring more power and a chain driven engine instead of dealing with timing belts. The cost/benefit of your proposal is pretty weak as far as I can tell
hi its me alec is offline   Reply With Quote
Old 06-03-2010, 08:45 PM   #9
zorin
Tools and labour are not a problem.
What would be my gain by doing the head swap and keeping the b25 intake manifold ?
I got the head for $50 so it was not a huge investment.
Old 06-03-2010, 08:50 PM   #10
///Orient3
My Ride: can't be defined
Nothing, the head is the exact same unless you are swapping cams, sorry.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 06-03-2010, 08:50 PM   #11
Iceman00
Banned User
My Ride: E90 6MT
Again, the head is the same, the ONLY difference that I know of is the intake camshaft (as well as the valve timing, controlled by the ecu) and the intake manifold, both of which are better than 325 gear, but I'm not sure it's worth the upgrade. If you do decide to go through with this, please do a before and after dyno. I'm willing to bet (with a tune) that those mods alone would close the gap on a 3.0liter, but I'm not sure it would be worth the hassle, compared to say...installing aftermarket cams which would yield more power.
Old 06-03-2010, 09:03 PM   #12
zorin
Thanks guys. I guess the head will be cleaned and used as a garage decoration.
Old 06-04-2010, 02:23 AM   #13
SDKmann
My Ride: 01 Cherokee
Out of curiosity, do the ZHP cams only differ in the intake cam as well? I have access to some parts and damn near free labor and this sounds like it could be well worth it if I could source a cheap B30 head and a set of ZHP cams. Also, how does regrinding cams work? I know the very basics on what a more aggressive cam does for a car but I thought the lobes had to be bigger to be more aggressive.
SDKmann is offline   Reply With Quote
Old 06-04-2010, 02:53 AM   #14
nightrunner20
My Ride: will eat your dust
Send a message via AIM to nightrunner20
for cams and the $$$$ involved I wouldnt beleive its worth the gains.
engine swaps anyone?
nightrunner20 is offline   Reply With Quote
Old 06-04-2010, 02:54 AM   #15
nightrunner20
__
Old 06-04-2010, 01:36 PM   #16
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
If you're going to go to all that trouble, why not slap in the rotating assembly from a 3.0 and have your DME flashed?
