Old 06-03-2010, 06:36 PM   #1
strelnikoff
My Ride: 2002 325i
rubber gasket around windshield is shot.
Does anybody know if it is possible to replace rubber gasket that goes AROUND the windshield without replacing the whole windshield. It appears to be the case for 5 series (there are numerous threads on bimmerfest). Texas sun has cooked mine and i I can literally peel away pieces of the rubber gasket by hand
strelnikoff is offline   Reply With Quote
Old 06-03-2010, 06:38 PM   #2
dstreet6
My Ride: 99 323i
I just ordered a new windshield this morning and they gave me a price of windshield, labor with OEM trim. I would imagine you could and would just have to pay for labor plus the cost of the new OEM rubber trims.
dstreet6 is offline   Reply With Quote
Old 06-03-2010, 07:05 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, I'm sure you can replace it yourself. The windshield is glued on from beneath the glass...this 'seal' is decorative...doesn't seal per se...and 'clips' into some groove or the like IIRC. I've seen it done a few times...and I know it's done after the glass is already on...it's been a while, but I'm 99% certain I'm right.
Let's check realoem and see if we can find it for you!
Here it is (I'm pretty sure) for my car...so you search yours...and $30 later, you're in business.
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 06-03-2010, 07:08 PM   #4
strelnikoff
My Ride: 2002 325i
From what I understand, the gasket does not hold the windshield in place, it is there for esthetical reasons. The windshield is held by an adhesive. Numerous e39 5 series owners were able to remove the gasket themselves and install a new one without actually removing the windshield and disturbing the adhesive. On realoem the gasket design of e39 looks identical to e46. Need somebody to confirm that this is doable before I peel mine off.
Old 06-03-2010, 07:11 PM   #5
strelnikoff
My Ride: 2002 325i
dmax, i was typing while you posted.
Old 06-03-2010, 07:15 PM   #6
dmax
dmax's Avatar
That's funny...I was doing the same!
Anyway, they sell the part...it's not brain surgery...give you good odds it's doable...but, if it was me...I'd search prices and if dealer isn't more than $10 more or so...go down, either pick up part or look at it. It'd help you figure best way to get it off by seeing what it is...sure it's a push in until firm and get the corners lined up well.
Mangofy your E46!
deteriorated, gasket, replace, rubber, windshield
