Old 06-05-2010, 09:39 AM   #1
TroyNVIE
My Ride: Mercedes & Lotus
Perfect Rear Off-set for 19" Staggered Set Up (non-M)
All,
I recently purchased a set of 19" wheels for my 2001 BMW 330Ci Convertible with sport suspension, and have had some serious rubbing issues in the rear (details below) . They are 19x8.5 with +35 offset in the front and 19x9.5 with +38 offset in the rear. I am currently running Kuhmo Ecsta SPT 235/35/19 tires in the front and 255/30/19 in the rear.
After having my fenders rolled, the problem persisted. I have been suggested by a few that have seen the car that the offset was too "aggressive". The wheel company has offered to re-manufacturer rears for me with +41 offset instead, in an effort to alleviate/solve the problem. The most frequent rubbing appear to be on the highway when the road "dips down" and then back up, as well as going around turns that are uneven, and anytime there is more than 15lbs of weight in the trunk.
How much will this help? Is there a more "perfect" rear offset - I did notice that VMR rears (on both the the V715 - similar design to my wheels, and the CSL reps) have a +45, but then I've seen other posts suggesting +45 can be too much, and require spacers?
Additionally, some have suggested my shocks/springs may be worn (77k miles) and that may be the cause of it, though I had a shop look at my shocks/springs very recently and tell me that they are fine and changing them (was thinking Koni Yellows and H&R Sport springs) would not really help my situation.
Any insight/thoughts/opinions would be much appreciated!
TroyNVIE is offline   Reply With Quote
Old 06-05-2010, 10:23 AM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
go with a narrower tire in the back... try a 245/40 and roll your fenders... should fit fine.
im running 18x10s at ET38 on my sedan with 255/35... and rolled fenders, barely any rub, only with 4 people on hard turns. and i think it rubs inside more than outside.
coupes have more room too, so u can def run these. DO NOT MACHINE your wheels.
a lil fender rolling and tire stretching they will fit perfectly.
yes, im lowered too.
additionally, when my rtabs were shot, i rubbed pretty bad with 18x8.5 et38 before with 255/35 tires. then ones i changed them and got an alignment, it never rubbed.
so if your suspension alignment, particularly the toe is way off, u will rub. i suspect if you fix that, most if not all the rubbing should go away... then the fender roll shoul dfix the rest.
Do you ride a sportbike?
Old 06-05-2010, 11:52 AM   #3
SLO Town
SLO Town's Avatar
My Ride: 2003 330Ci
OP:
2003 330Ci Coupe here. I'm running BBS CH 19x8.5 35 offest 235/35 fronts and 19x9.5 38 offset 245/35 rears. I have zero problems with tire/fender interference. Also, I'm running PS2s and H&R springs with Bilstein Sport struts/shocks.
Your problem is the 255 rear tire you're running. It's too wide. The fender lip clearance with my 245 rears is less than 2mm, maybe a bit less.
Scott
Original Owner 2003 330Ci ZSP, 3145 lbs, 5-spd, leather, Alcantara wheel, 19x8.5" BBS, RE-11s, ZHP FCAs/diff cover/weighted knob, M3 eng + trans mounts/outer RCABs/RCABs with Turner limiters, Group N inner RCABs, Bilstein Sports (E36 M3 rears), Eibach P-K, H&R bars, BMW Performance Rotors, Turner caliper bushings, StopTech lines, Borla, RE pullies/RSM, Stewart WP, M-Technic Trunk Spoiler, Mason pedal/strut bar/end links, B&M shifter, UUC DSSR
SLO Town is offline   Reply With Quote
Old 06-05-2010, 12:15 PM   #4
bmw4red
My Ride: BMW 33OI ZHP
Narrower tires/ add some bumpstops/ use the search button.
SOLD
bmw4red is offline   Reply With Quote
Old 06-05-2010, 12:38 PM   #5
TroyNVIE
Thank you for the responses so far. It seems the narrower tire suggestion is popular, but I am concerned that it won't be much help, and here is why:
My wheels (which may be unique) have a lip that sort of goes beyond the tire, which is the source for a bit of the rubbing (please see pictures below of the evident abrasion). Because the lip actually sticks out further than the tire, I'm not sure a narrower tire would help.
Again, I appreciate all of the advice so far..
ID:	362767   Click image for larger version
Name:	From Rear (2).jpg
ID:	362768   Click image for larger version
Name:	From Side (1).jpg
Old 06-05-2010, 01:05 PM   #6
SweTurbo
Big Pimpin'
My Ride: 323i -98
I have 265/30-18 ET45 on a set of 9.5" VMR V710 et45 , i have like 1mm to sparer between the tire/rim and the body of the car.
I'm gonna buy a 5mm spacer to be sure... might need fender-rolling :/
Old 06-05-2010, 01:10 PM   #7
Snik
Snik's Avatar
the 255 tire is not the problem.
Old 06-05-2010, 01:13 PM   #8
Snik
Snik's Avatar
picture angles are not good, they dont show the relationship of the fender with the tire.
trust me dude. u can put 245s on and hope that solves it, but with a could, u should be able to run a 265 on a 9.5 depending on offset.
i dont care how unique ur rims are, im running the same offset with the same size tire on a narrower sedan with a wider rim. its not the tire.
sometimes different tires are more square than others.
what brand tire is it?
Old 06-05-2010, 02:07 PM   #9
p0tpie
My Ride: '06 M3
im running a 10" with a 38 offset. I use a 245 not a 255 so that may be your problem
edit: i am rolled but your wheel is half an inch less wide with the same offset so it should still clear
p0tpie is offline   Reply With Quote
Old 06-05-2010, 02:08 PM   #10
Snik
Snik's Avatar
Originally Posted by p0tpie View Post
im running a 10" with a 38 offset. I use a 245 not a 235 so that may be your problem
same width, same offset, 255/35, no problems.
Old 06-05-2010, 03:06 PM   #11
TroyNVIE
Thanks again for the feedback -- just to highlight some points from my original post -- I have Kumho Ecsta SPT tires, and I have already rolled the fenders.
Attached are some additional pictures as I try to search for some more helpful angles ...
Name:	19 Wheels (without Caps) 009.jpg
ID:	362777   Click image for larger version
Name:	19 Wheels (without Caps) 006.jpg
ID:	362778   Click image for larger version
Old 06-05-2010, 03:06 PM   #12
Joeysauce
My Ride: E46 330ci
I have your same set up. I use 45 on the rear and no rubbing. a little more rim is sticking out than I would like, but it's fine.
2001 330CI
MODS: H&R sport springs, 19" staggard M6 wheels, halo's, Cosmo CAI, Rouge IKON exhaust, M3 rep front bumper, Hamann side skirts, ACS rear add-on, M3 rear deck spoiler, clear signals, 6000k xenon and matching fogs, Meyle HD FCA/FCB, 20% window tint, LED rear tail lights.
-Un-decided possible Mods-
Matt-black kidney grills.
Joeysauce is offline   Reply With Quote
Old 06-05-2010, 03:08 PM   #13
Snik
Snik's Avatar
if u have a coupe, and fenders rolled, and rub with 255s i swear to u. youre toe is off.
and my car sites lower than yours, and coupes have a lil more room.
trust me dude.
Old 06-05-2010, 05:39 PM   #14
AL330CI
My Ride: 330Ci
I had 19x8.5 et35 (w/ 235/35/19) front; 19x9.5 et40 (w/ 265/30/19). There was no rubbing at alll after replacing the RTAB. See this old FS thread for some pictures: http://www.bimmerfest.com/forums/sho...112&highlight=
You issue seems to be the offset of just 38mm. You may need >40mm to bring the wheels further in.
AL330CI is offline   Reply With Quote
Old 06-05-2010, 07:18 PM   #15
Snik
Snik's Avatar
^ I really don't think 2mm more poke with a tire 10mm narrower is the issue. Its exactly what I told him and what u said. Rtabs are shot and toe setting is jacked up. I'd put money on it.
Old 06-17-2010, 12:08 AM   #16
Snik
Snik's Avatar
need wheel offset and width
Old 06-17-2010, 01:33 AM   #17
bmw01346
My Ride: bmw 325i 2001
hi,
what can i do to run the same tires.. i cant get new rims just got brand new tires...
bmw01346 is offline   Reply With Quote
Old 06-17-2010, 01:48 AM   #18
AL330CI
My Ride: 330Ci
Originally Posted by bmw01346 View Post
hi,
You question was answered by Eddy from APEX here already: http://forum.e46fanatics.com/showthread.php?t=761100
Old 06-17-2010, 04:08 AM   #19
royceyokono
My Ride: 2005 325ci
lower your car. the added negative camber might help. dont do outrageous camber though.
royceyokono is offline   Reply With Quote
Old 06-17-2010, 07:12 AM   #20
CokMinusTheS54
My Ride: '01 TiAg 325Ci 5mt
^^ what's considered outrageous camber?
CokMinusTheS54 is offline   Reply With Quote
offset, staggered, suspension, wheel size, wheel tire setup
