Sponsored by BAVSOUND
Old 04-12-2003, 08:56 AM   #1
325ciDanger
My Ride: 2002 Ti Silver 325ci
need help hooking up amp
i'm in the process of hooking up my amp as we speak....from what i've read on here, the white wire from the HK amp on the rear left side is the amp trigger wire, but there are 2 plain white wires both look identical in size...can someone tell me which one to tap? also the speaker wire from the HK amp on the rear deck to tap into for the line level converter, there are 2 gray and two green...which do i tap? one of each? which is positive and which is negative?
PLEASE HELP!!
thank you
325ciDanger is offline   Reply With Quote
Old 04-12-2003, 01:38 PM   #2
kartele
My Ride: 2000 323ci SOLD!
you have to meter the white wire to test for 12 volts when your radio is turned on
as for the level converter you can't hook it up at the speakers you have to grab the input wires to the amp unless you have a level converter made for amplified systems
there should be a yellow and a yellow/brown wire inter twined i think they are 14 guage wire
kartele is offline   Reply With Quote
Old 04-13-2003, 11:26 PM   #3
rome5982
My Ride: 99 323i
Here is a link that shows a very detailed wiring diagram of our system. If anything, it can help you with the wire colors. http://forum.e46fanatics.com/showthr...threadid=46021
18"ASA AR1/H&R CupKit/ECIS CAI/Stromung Exhaust/Zimmerman Rotors/Aluminum Interior Trim & Face Gauges/G2 Calipers/Clear Corners/Autometer Gauges/Mtech Front Bumper/Chrome Grill/UUC Shift Knob/OEM Rear Spoiler/Painted Moldings/Silver Gauge Rings/JL Audio 12W3V2 & 6.5 Coax/BA 6.5 ProSeries/Kicker KX600.4
rome5982 is offline   Reply With Quote
