Old 06-06-2010, 03:03 AM   #1
dh0licious
My Ride: '00 325i
Leaking diff, what do I need?
Hi all,
I noticed an oil leak on my garage floor where my diff is, so I drove the car back in and it aligns pretty well with where the diff is. Obviously it's leaking, so I am wondering what I will need to do the change and prevent the leak.
It'd hard searching with my iPhone so if you could point me in the direction of a DIY that would be great. I've already got a bottle of redline diff fluid, but what additional bolts, washers etc will I need? Part no's would be great.
I plan to have my Indy take care of this tomorrow/Tuesday but is there any chance of major damage?
Regards, Sameer
dh0licious is offline   Reply With Quote
Old 06-06-2010, 03:39 AM   #2
Greek Dinan
My Ride: Dinan 330Ci
You need to know whether its a shaft seal or just the cover leaking. Not sure on part no.s for the seals, but if its just the diff cover, then all you need is a sealer. I think RTV will work just fine. BMW discontinued the diff cover gaskets.
Greek Dinan is offline   Reply With Quote
Old 06-06-2010, 12:17 PM   #3
lkstaack
My Ride: 04 330iZHP, 05 325iT
Yes, it could be the input or one of the two output shaft seals, the cover, or the drain plug washer. I recommend that you clean the diff and then re-inspect it for leaks after driving it for a while. Replacing the drain plug washer will be the easiest leak to fix, but not necessarily the most likely.
You will have to drop the diff to replace seals; you might be able to fix a cover leak without dropping it. It is true that BMW no longer uses cover gaskets, but RTV is not a long term solution. RTV will not hold up to sustained contact with oil over time. There is a hard to find Loctite product designed for this application; BMW sells it (about $50 a tube), but it is also available online.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
