Old 06-08-2010, 06:36 PM   #1
kgsd
My Ride: 2002 320i
Rev Problems - HELP!
I have a 2002 320i with a mechanical/technical problem that has yet to be properly diagnosed (despite significant effort). Symptoms are as follows:
- While driving with RPM between approximately 1500 and 2500 the tachometer will bounce up and down between approximately 1200 and 2000 RPM. This usually happens when the car is traveling at a constant rate of speed and has to slightly increase RPM to maintain that speed (e.g. when climbing a small hill). Also seems to happen when the car should upshift into a higher gear.
- While at highway speed when I push my foot on the accelerator the RPMs will go up slightly but will then dip dramatically. Once the dip happens the car will sometimes gradually gain RPM and speed and return to a normal driving dynamic; other times the RPM jumping as noted in my first point will occur until I either ease off on the gas, or floor the pedal and push the RPMs much higher.
- While accelerating at highway speeds the RPMs are inconsistent - the tachometer wavers and moves up and down. This is especially noticeable when climbing steep hills and maintaining speeds of 100+ km/h.
- When accelerating from a complete stop I can sometimes here a rattle or pinging sound coming from under the hood. I have been told that this pinging is actually the fuel injector trying to send fuel to the engine but that it is not in sync for some reason. I am wondering if this may be a sign of what is causing my other symptoms.
To me it seems like the problem has less to do with shifting gears, and more to do with what happens when the car is in a particular gear. This seems to occur most frequently when the car is in 5th. The problem also occurs much less frequently when I have the car in sport mode, and less frequently still when I manually shift gears.
Any advise guidance would be greatly appreciated.
Thanks!
kgsd is offline   Reply With Quote
Old 03-18-2011, 09:11 PM   #2
shazam-2k
My Ride: 2004 320i
I am having the same problem. The revs go down and I get a vibration. Did you find the problem? Weird no one responded? Isn't this what the forum is for?
shazam-2k is offline   Reply With Quote
Old 03-18-2011, 09:13 PM   #3
JordanBMW
My Ride: 320i 2002 steel blue
Send a message via MSN to JordanBMW Send a message via Skype™ to JordanBMW
Shazam I have a 320i aswell and when the rpms dip I hear a loud rub then it goes up dips again and rubs. It may possibly be the torque converter which is a expensive fix.
JordanBMW is offline   Reply With Quote
Old 03-18-2011, 11:28 PM   #4
shazam-2k
My Ride: 2004 320i
I saw on Youtube a video of the same problem and they found it was the knock sensor. I had a misfire code on 2 cylinders maybe thats why? also read it could be the MAF sensor.
Old 03-22-2011, 10:13 AM   #5
kgsd
My Ride: 2002 320i
Thanks for the responses. About 2 months ago drove over a big rough patch in some road construction (at night; not marked; very annoying), blew my two passenger side tires which activated my airbag sensor deploying my two side airbags. Insurance company wrote the car off and now have an 05 325i sans rev issues (touch wood
To address a couple of the above comments -
I had the misfire problem as well. With my car the misfire issue made it drive worse but fixing it just better isolated the rev jumping issue. I replaced all spark plugs and coils twice during the time I had the rev jumping issue. I averaged about 60000kms/year with this car - the problem started at about 110 000 kms and persisted through to 270 000.
Torque converter was one of the possibilities I had narrowed down to as well.
I had this specific problem diagnosed in BMW service departments both in California and British Columbia. They both said issue was computer programming so had the car's computers reprogrammed - did not help anything. After this step failed, I had the Canadian BMW service centre spend a few hours trying other random fixes - again no help at all. The problem persisted for about 150 000 kms and did not ever affect the car's ability to drive; no error codes ever showed. I had various other mechanics look at it and I found that the one's who did not understand BMW's always said the transmission was failing. I never thought this was true because to me the car never had issues changing gears, the issue was what happened within a given gear.
Other things I replaced trying to narrow down/fix the rev jumping issue- belts, water pump, battery (could have been problem with lack of power)
Other possibilities that I narrowed down to - Oxygen Sensor, Exhaust Sensors, fuel pump (possibly just needing cleaning).
Hope this helps. Please post if anyone finds out what the real problem is - I'm still really curious.
Old 03-22-2011, 10:16 AM   #6
kgsd
My Ride: 2002 320i
I found this video on YouTube a while back. My car's revs tended to jump when the revs were a bit higher (~1500-2500) but this appears to be a very similar problem:
Old 03-22-2011, 01:37 PM   #7
shazam-2k
My Ride: 2004 320i
You would think with the frequency of this problem, someone would know how to fix it?!
Old 04-07-2011, 06:39 PM   #8
JordanBMW
Change tranny fluid I had same problem
Old 04-07-2011, 07:47 PM   #9
DDwr450f
My Ride: 2004 325i M-Sport
Hi, im new here and im having the exact same problems. My 2004 325i is doing the same, it is in for its 100k service at the moment
and they also believe it may be a transmision problem...
DDwr450f is offline   Reply With Quote
Old 04-07-2011, 07:54 PM   #10
shazam-2k
My Ride: 2004 320i
did it fix the problem?
Old 04-07-2011, 08:15 PM   #11
DDwr450f
I have also just had the tramsmission fluid changed during the major service, i will let u know
if it helped my reving issues.
Old 05-14-2011, 08:21 AM   #12
325CI Man
My Ride: 2001 325CI
i am also having the same prob with my 01 325ci but it is not as dramatic as the one in the video if any one has a solution it would be much appreciated. im going to try changing the fuel filter to see if it has any effect.
01 325CI, 19inch Zenetti Wheels, intake, Surge chip, M3 front bumper with Carbon Fiber lip(painted), carbon fiber spoiler, Carbon Fiber Vis Racing Hood, Red Underglows, DVD head unit, 2 12" Jensen Subs in a Bandpass enclosure.
325CI Man is offline   Reply With Quote
Old 05-14-2011, 05:56 PM   #13
DDwr450f
My cars still having revving dramas, it's when I'm trying to hold a constant speed, 50, 70, 90, or 110km/h. It fluctuates approx 400rpm in any transmission mode! When the speed is under 60km/h and the revs drop, I
also get what seems like a vibration!
I'm getting my transmission flushed out tomorrow, there hooking it up to a machine which cleans it out. Hopefully it may sort out my revving dramas!
Sorry I do have a video I took on my iPhone but I'm not sure how to upload it!!
Old 05-17-2011, 03:21 AM   #14
DDwr450f
Hi all, better late than never!!
I had my transmission serviced today, they hooked it up to the machine which thoroughly flushes & cleans out ALL the old fluid.
As I drove it home there was NO fluctuating revs, none at all!! It certainly changed gears smoother & took off from a standing start a lot smoother also!!
I should mention that I did not get any service record with the vehicle when I bought it. In saying that it seems that there are a few other BMW owners with this problem!
Hope this helps out!
Dan
rev, rpm, sensor, tachometer, transmission
