Old 06-09-2010, 05:24 PM   #1
n3rd
My Ride: E39
Lots of white smoke from exhaust, but no coolant in the oil.
my 01 z3 M54 is blowing a lot of white smoke- Initially i thought it'd be a head gasket, however at the starting to tare the engine apart we found a puddle of oil at the bottom of the intake tube and on the throttle body. The oil is clean on the throttle body, and when checked via the dipstick. The coolant is clean as well. Anyone have any ideas? CCV?
Tomorrow I'm going to run a compression check to see whats going on with the car.
Can anyone also post a picture of where the CCV is?
n3rd is offline   Reply With Quote
Old 06-09-2010, 05:27 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Coolant is BLUE smoke.
Old 06-10-2010, 12:12 AM   #3
White_Knuckles
My Ride: 2003 325xi
The CCV (crankcase ventilation) is your "PVC" system and has been reported to fail where vacuum can draw oil into the intake and burn it creating exhaust smoke. It is quite a bit of plumbing and lives under the intake manifold. It can only be inspected with dis-assembly. The plastic pipes can be brittle where you should have a replacement kit handy.
Burning oil has a unique smell and usually a blueish color. White is water from condensation or a dreaded coolant leak normally the head gasket.
Good luck, hope it's something minor.
Old 06-10-2010, 08:45 AM   #4
Oz Striker
My Ride: '00 330Ci, '07 350Z
You could always send off a sample of oil to Blackstone labs to look for coolant to exclude it once and for all. I often had a blueish tinge to my esxhaust fumes on a cold start. Compression check came back fine as did oil analysis. Could it possibly be the begiinning of a head gasket failure ie the coolant is being boiled off cause there isnt too much of a leak? You only need a small amount of coolant to get a some whiteish smoke. But certainly if you're having lots of white smoke best to have it checked.
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 06-10-2010, 08:51 AM   #5
nk_zhp
My Ride: ZHP / E30 M3
I don't think so bug.. blue is classic oil.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 06-10-2010, 10:30 AM   #6
rowdy lee
My Ride: 2000 323ci
ya...
well, due whatevr youe need too but a comp test is good inffo to hayv anyhow. Cnna due a leekdown tess to for informattn.
Get the CVV kitt an repl it all fer a hunnert fiffy buks.
Can anyone understand it 'cause I had a hell of a time with yours!
Better 1. stay in school or, 2. didn't learn much there so forget about it. 3. go back to school and try again instead of partying so hard.
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
Old 06-10-2010, 10:33 AM   #7
808ZHP
My Ride: '03 330i ZHP
it's just too cold outside
SG 330i ZHP Alcantara 6MT Rogue LED V1
808ZHP is offline   Reply With Quote
Old 06-10-2010, 02:02 PM   #8
n3rd
My Ride: E39
Troll.
Old 06-10-2010, 04:49 PM   #9
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
IS this the spelling and grammer they are teaching school now. Or are YOU just a retard?
Truly, I'm curious...
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 06-10-2010, 08:55 PM   #10
White_Knuckles
My Ride: 2003 325xi
I don't think Rowdy is a troll, perhaps both hands are in casts and he's adapting to typing with his feet?
Jgoood L:uckku to ya Roudcy (foot input)
Old 12-01-2010, 12:33 PM   #11
huskerick
My Ride: 325i/C6/928/951
yepper. blue = oil. white = water/coolant.
appears the head is cracked or bad gasket. it's not getting into the oil pan because the leakage is being burned in the combustion chamber - hence the white smoke.
huskerick is offline   Reply With Quote
Old 12-01-2010, 12:44 PM   #12
slammin_330
My Ride: is no ZHP.
The white isn't really smoke, as much as it is steam. Water (coolant) doesn't smoke.
Do something, waft the exhaust. Don't directly inhale, and if you do and die I am not responsible. If it smells sweet you're screwed. This equals coolant in combustion chamber.
Try a leakdown test, or compression test all 6 cyl. Either will tell you something isn't right.
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
Old 12-01-2010, 12:47 PM   #13
My Ride: Lexus
There's no 'e" in grammar.
Old 12-01-2010, 02:04 PM   #14
steveninchicago
My Ride: 2003 325i
steveninchicago is offline   Reply With Quote
Old 12-01-2010, 02:13 PM   #15
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
this thread is full of fail
/_________\
O==[][]==O
Old 12-01-2010, 04:20 PM   #16
xavi330i
My Ride: 2004 330i smg
I'm tired of repeating myself. Every week I have to say this: it is your CCV that has failed. Remove the CCV vacuum port runners on top of your intake manifold. If you have oil dripping out of the 6 ports, your CCV failed. Oil can only get into your intake manifold though the CCV vacuum rail on top of the intake manifold. Looking forward to next week's repeat.
xavi330i is offline   Reply With Quote
