BMW and INPA success - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 102 votes, 4.88 average. Display Modes
Old 08-11-2011, 03:32 PM   #41
El Polo
My Ride: 99 black 328i
I will take a screenshot tonight. Yeah I don't think my anti-theft system is from bmw. But could it change the SRS module behavior?
Sorry if this post doesn't make sense. I am writing on a cell phone.
El Polo is offline   Reply With Quote
Old 08-14-2011, 09:36 PM   #42
JSanders
My Ride: Breaks too often
This is awesome! Can't wait to try it out.
JSanders is offline   Reply With Quote
Old 09-22-2011, 04:49 PM   #43
Ripwinder
My Ride: BMW 328ci
Help
Hi Guys,
I have a 16 pin to usb cable. I have managed to get INPA working and can speak to the engine and auto box plus view real-time stats but can't seem to connect to any of the other modules in the car. My car is a 99 328ci. Do I need to purchase a 16 to 20 pin adapter and connect via the 20 pin?
I also can connect to the car with DIS SSS but both fail to read the actual data from the car.
Cheers,
Liam.
Ripwinder is offline   Reply With Quote
Old 09-23-2011, 02:23 AM   #44
Arty
My Ride: 1999 328i
If you have a 20 pin socket, you MUST use it to read all modules. That's the rule.
Arty is offline   Reply With Quote
Old 10-14-2011, 11:51 AM   #45
markob
My Ride: Z3Q
Hello,
i have bmw scanner 1.36 with interface and Ediabus with interface(inpa compatible), USB to serial adapter cable and obdII and 20pin cable for newer cars.
I need ADS interface for my Z3 with 20pin connector, so can i modify any of mentioned two interfaces to be like ADS interface as i saw on the internet they have interfaces with knob witch is use to choose between OBDII or ADS mode so i assume that inside of interface it can select betwen different pins or something similar?
I use this two interfaces for e46 and other but i would be glad if i can use it also on e36 and older. For e36 i ned kkl, so i just conect with extra wire a 16# pin form 20 pin conector and 1# pin at the obdII 16 pin conector, this is for batt+? I read that this 16# pin is only for autodetect that without INPA still work, on the other side i also read that without 16#pin INPA wont start the readings.
So i wire this two pins between obdII and 20pin conector and with obdII ediabas interface INPA will work for e36 cars and older?
So i have
-BMW scanner 1.3.6 with interface
-OBDII Ediabas (it says "inpa compatible")
-USB to serial cable (virtual COM port)
-ADS (20 pin)connector on one side and on the other side is male 16pin connector that connect to ediabas obdII female connector and obdII ediabas conect to USB to serial cable and than trough USB to computer.
Please if someone has DIY link with pictures that i can use to build/modify this two interfaces i allready have.
On this picture is my tools that you can see inside what they look like
In EDIABAS interface a see that pin 15 is not conected to PCB
markob is offline   Reply With Quote
Old 10-16-2011, 08:29 PM   #46
darksideracer69
My Ride: 01 325ci
do i need the 20 pin connector to align the egs?
With progman?
IMAG02051
Old 10-16-2011, 08:46 PM   #47
darksideracer69
My Ride: 01 325ci
Damn
Sent from my SGH-T959V using Bimmer
IMAG02051
Old 10-17-2011, 02:14 AM   #48
Arty
My Ride: 1999 328i
With progman?
The DME and EGS are available from the 16 pin connector always.
Some modules (DME, EGS) are on the 16 pin socket.
Old 10-17-2011, 02:19 AM   #49
Arty
My Ride: 1999 328i
I don't think you can do that. Read this to understand what an ADS hardware interface does.
http://www.bimmerforums.co.uk/forum/...rfaces-t85191/
Old 10-17-2011, 09:48 AM   #50
darksideracer69
My Ride: 01 325ci
Well I tried getting in there with progman and it wouldn't let me. But then I go to my 01 e46 that just has the 16 pin obd2, and i can use progman fine. Is there another way to align the stuff without using progman,or dis? I gotta do a little searching.
IMAG02051
Old 11-04-2011, 03:08 PM   #51
kuksul08
My Ride: M3
Have you heard of anyone using the AutoEnginuity cable and the INPA software?
Also, what kind of sampling rates do you see with INPA on an E46? With AutoEnginuity I see ~100-300ms with one sensor, and upwards of 1000ms when reading multiple sensors. The program is supposed to be capable of 1ms, so I assume it is a limitation of the CAN. Yes/no?
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 11-04-2011, 05:05 PM   #52
Arty
My Ride: 1999 328i
I don't understand the issue you are trying to present.
If you have the 20 pin socket, you must use it to access all modules unless you want to pull the binnacle and add wires.
If you have the 16 pin socket only then short pins 7&8 on your adapter to access all modules.
The baud rate is 9600 and half duplex.
The data comes in hex in up to 32 byte messages. Throughput is a serious limitation.
Later cars (2007+) went to K-CAN at 100kbaud and 500kbaud for faster firmware updates and messaging.
Old 11-04-2011, 07:40 PM   #53
darksideracer69
My Ride: 01 325ci
Thanks for the info. At the time I didn't have the 20 adapter available to me. But i just got it in.
IMAG02051
Old 11-04-2011, 09:33 PM   #54
darksideracer69
My Ride: 01 325ci
Another question. I messed up and ordered the cable the has the serial end, instead of going to the obd2. Attached is a pic of how the inside of the 20pin cable looks. Would it be possible to feed the three wire into the obd2 plug with some pins? And to which pins?
IMAG02051
Old 11-09-2011, 01:46 AM   #55
rossi0112
My Ride: Black 328 CI
Originally Posted by mystert View Post
I have Inpa, DIS, and SSS all running on 64bit Windows 7, if only NCS Expert would run ona 64 bit machine!
Hi I got a cable from eBay an it came with all the software but inpa won't work on my 64bit system. Says an error about not working on 64 bit. Should I download another version ???? I can send screenshot if that's any help.
2000 Black 328 CI (mine)
2002 Blue 325I M Sport (wife's)
2000 Yamaha YZF R1 (mine)
2008 Skyjet SJ125-23 (sons)
2009 Kinroad XT50-18 (sons)
rossi0112 is offline   Reply With Quote
Old 11-09-2011, 05:20 AM   #56
darksideracer69
My Ride: 01 325ci
Try downloading the software from the interwebz. And also running compatibility mode for INPA.
IMAG02051
Old 11-09-2011, 12:19 PM   #57
rossi0112
just thought i would ask and apologise if all ready asked, but is there a one system software that i can get and install just to read fault codes and reset service lights, the ediabas,inpa,sss,tis all seem to be such a challenge to understand and install and different things ot set and enable..i used to have an Audi A6 and had a system called VCDS with a cable, it was simple to use just install and run and connect to car plug, and in reckon a child could easily understand how to use it..now i have a BMW i have trawled through a lot of stuff and am really very confused..
Any help would be appreciated
Old 11-09-2011, 01:06 PM   #58
darksideracer69
My Ride: 01 325ci
How do you find inpa difficult? I think it's easy to use. There are other programs for bmw that are a lot harder to use.
IMAG02051
Old 11-10-2011, 03:10 AM   #59
Arty
My Ride: 1999 328i
Have you got the female OBD2 connector? If so just connect OBD2.7 to TxD and TxD2. EDIT: and hook up the Power and GND too.
You need INPA and EDIABAS as a bare minimum.
INPA is the program that talks to the car.
EDIABAS is a tiny program that shares the COM port out to several programs when needed.
Follow the guide in post #1.
Old 11-10-2011, 01:40 PM   #60
rossi0112
it still copmes up with error when i install inpa and try to run it not compatible with my system i.e 64 bit, i have put it in compatibily mode..maybe i should start it all over..all i want to do is reset my service indicator and read any faults my car has, not bothered about programming and further in depth stuff, thought carsoft was a good idea but having read a few things about it people are saying that it aint worth getting it. i shall perserver a bit more..might take a [ic of the files that came on my cd if i get any more problems installing..
