Thread Tools Search this Thread Rating: Thread Rating: 102 votes, 4.88 average. Display Modes
Old 01-02-2012, 03:59 PM   #101
CrisB02
My Ride: 330I
Send a message via AIM to CrisB02
I cant find the obd.ini file. I keep getting the error that needs the obd.ini file. Any help would be greatly appreciated.
CrisB02 is offline   Reply With Quote
Old 01-03-2012, 03:59 AM   #102
Arty
My Ride: 1999 328i
Have you deleted obd.ini?
If so here is a copy to replace it with rename obd.pdf obd.ini.
Put it in
C:\EDIABAS\Bin\obd.ini
C:\WINDOWS\obd.ini
Code:
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
MODE=NORMAL
;MODE=KBUS
UBAT=OFF
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0    = Funktionsaufruf
; Bit 1    = io Ergebnis
; Bit 2    = nio Ergebnis
; Bit 3    = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
Arty is offline   Reply With Quote
Old 01-04-2012, 11:01 AM   #103
hsverma
My Ride: 2004 M3 Coupe
Hi Guys,
I read this thread and I am still confused: I have a 2004 M3 and wanted to get this setup working for it. I looked under the hood and did not see any round 20 pin connectors there. The only thing I see is the rectangle OBDII connector in the cabin near the driver foot. What cable do I need to get for this? Will this cable suffice: http://www.amazon.com/OBD2-Diagnosti...5627499&sr=1-1
hsverma is offline   Reply With Quote
Old 01-05-2012, 07:12 AM   #104
test123123
My Ride: x5
After I connect my cable to the car.
Do I need to start the engine? OR leave car off? OR turn on power on without start engine?
test123123 is offline   Reply With Quote
Old 01-05-2012, 08:31 AM   #105
Arty
My Ride: 1999 328i
Ignition must be on. Engine can be on or off, depending on what jobs you wish to attend to. Be aware that a prolonged session (40+minutes) can flatten the vehicle battery. Do not reset the Adaptations with the engine running.
Old 01-17-2012, 07:00 PM   #106
The_Don
My Ride: 2001, 325Ci
Has anyone with MS.43 DME used the any software packages/cables to open DSC pump valves for brake bleeding? I have been reading a ton of information on various sites, and this information still proves to be alluding me. I just ordered a USB to OBDII cable and realize that I will need to do a pin mod in order to access both k-lines, but I am unsure as to whether the ABS/DSC module will be available for bleeding out the air (yes I let my brake fluid get too low while changing brake lines and rebuilding calipers ) Any insight would be greatly appreciated.
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 01-17-2012, 07:03 PM   #107
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
yes, it's available via INPA.
SL Blak Soldier is offline   Reply With Quote
Old 01-17-2012, 07:14 PM   #108
The_Don
Awesome! Thank you!
- M3 Motor Mounts -
For Sale
Old 03-11-2012, 04:05 AM   #109
Alpine 7even
My Ride: 01 DINAN7, 00 e46
How car I add the e46 profile to my inpa software?
Alpine 7even is offline   Reply With Quote
Old 07-05-2012, 05:16 PM   #110
CroVlado
My Ride: 2004 MB BMW M3
a bit of a revival.... but since were on INPA topic...
how do you go thru and tell the SMG trans to re-adapt itself for clutch wear..? any quick tut or something?
I've heard when you do this the SMG starts doing some funky noised for a minute or so and then it stops and ur good to good with much smoother shifts etc...
how often is it recommended for this to be done?
TIA!!
CroVlado is offline   Reply With Quote
Old 07-05-2012, 05:51 PM   #111
Arty
My Ride: 1999 328i
TIA!!
I never looked at a car with SMG, but this sort of function usually is kept under the ACTIVATE button.
Old 07-05-2012, 06:19 PM   #112
CroVlado
ill try to glance at it.. see if i find it.
Old 02-06-2013, 09:47 PM   #113
putyoursoxon
My Ride: 03 M3
How to you pull up the E46 profile in INPA my INPA screen shows models E60 and up, and it isnt under the older model screem either. Any help?
putyoursoxon is offline   Reply With Quote
Old 02-06-2013, 09:59 PM   #114
putyoursoxon
My Ride: 03 M3
Figured it out to get the E46 to show
Edit the file 'C:\EC-APPS\INPA\CFGDAT\INPA.INI' in Notepad, locate the section that starts with '//F3', remove the slashes at the beginning of the three lines of text, and amend any instance of 'F10' to 'E46'.
Old 07-18-2013, 02:55 PM   #115
toffa
My Ride: 320ci
Send a message via MSN to toffa
hello guys: which are the steps do I should follow for clear the airbag light (passenger side)? Thanks!
toffa is offline   Reply With Quote
Old 07-18-2013, 03:10 PM   #116
GreatFrog
My Ride: 03' 330i ZHP, 07' Z4
I think you need to choose multi-restraint system, in the dialog window where you have Engine, Chassis, etc to choose from. Or maybe it is buried under some other category, can't remember... And then choose error, there you will be able to read/clean the code.
GreatFrog is offline   Reply With Quote
Old 07-24-2013, 03:34 PM   #117
toffa
My Ride: 320ci
anyone had found this issue?
https://www.youtube.com/watch?featur...&v=-6OMM0HIsOk
Old 09-13-2013, 08:59 AM   #118
invisible132
My Ride: E46
Hello. I've tried to connect my e46 to inpa, but i get error ifh-0003 data transmission to interface disturbed. I haven't set latency to 1, because there is no option to do that.
invisible132 is offline   Reply With Quote
Old 09-13-2013, 05:00 PM   #119
skull
My Ride: 2002 330i, 2006 325i
I would like info on this as well. Just got the S/W
PM Sent.
Have the cable and the software but hardly know how to use it.
skull is offline   Reply With Quote
Old 09-13-2013, 05:05 PM   #120
GreatFrog
I know it is beyond the scope but it INPA doesn't work for you, you can try DIS, which has better compatibility I believe. I might have cleaned my airbag code using DIS, but I am not 100% sure. It can be done.
