Old 06-30-2010, 04:40 AM   #41
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
Originally Posted by bigjae1976 View Post
I've heard some people complain that the Quaifes are noisy. Otherwise, I've seen nothing but good reviews.
I have a Metric Mechanic 3.15 3 disc LSD. I've been pretty happy with it, DSC comes on a lot less often. It does make my rear end a little more "lively".
Quaife is noise free. If anyone is saying Quaife is noisy, I want to know about it. I have not had anyone with a properly installed Quaife complain about a noise issue.
Quaife is what 99% of you need for your street/HPDE/Track Day car. Leave the clutch/plate type of LSD for a track only car unless you are ready to deal with added noise, frequent fluid changes and rebuilds.
Harold
HP Autowerks is offline   Reply With Quote
Old 06-30-2010, 04:55 AM   #42
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I have to correct my earlier statement...its the Kaaz diffs some complained were noisy. Not the Quaifes.
Harold
I made a boo-boo...I meant Kaaz.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-30-2010, 08:07 AM   #43
TxZHP04
My Ride: ESS TS2+ ZHP
A well built clutch type isn't the nightmare you seem to imply. I have absolutely zero complaints about mine after 2.5 years and 40k miles of use and wouldn't hesitate to recommend this type of diff to others.
Old 07-06-2010, 09:10 AM   #44
blablac
My Ride: 240sx
how often do you need to change the fluid ?
blablac is offline   Reply With Quote
Old 07-06-2010, 11:10 AM   #45
TxZHP04
In street use, I change the fluid every 10k miles... same as I did with the stock open diff.
Old 07-08-2010, 09:00 AM   #46
blablac
My Ride: 240sx
Just got an email from WAVETRAC they will be releasing a 330i version of their LSD in August of this year.
Old 07-08-2010, 09:47 AM   #47
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
Originally Posted by McSpeed View Post
Frustrating. I wonder if you'd be breaking halfshafts if there was a smoother diff dishing the power out*
*I'm not saying Quaife necessarily - but something less brutal than the Kaaz maybe
well, the first set of breakages was mid-drift. Traction wasn't present, so the diff was just locked, there was no rough engagement at the time. The second breakage, the diff was also being smooth, it was straight line acceleration. The diff is harsh, no question, but in a straight line, there's no other diff I'd want. In a straight line, this one is silent and smooth. It's when angle is added with the steering wheel that the harshness comes.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 07-08-2010, 09:48 AM   #48
bluejeansonfire
ninja editor
My Ride: m5xual
Originally Posted by lkstaack View Post
Performance Gearing told me that "The Kaaz units will always make noise by design, because both the discs and plates are made of steel alloy, with no coating on either, and (PG units) don't chatter because the discs are ceramic coated".
I think it's just because lockup is beyond 95%... I've heard from some Kaaz owners in the JDM scene that when lockup is turned down, below 80%, it becomes pretty bearable.
