Old 03-07-2011, 02:49 PM   #1
D325i
My Ride: 2004 BMW 325i
Cleaning Headlights?
I have a 04 325i and the headlights are all "foggy". I was wondering if I could remove the headlight and remove the headlight lens to clean it inside and out. Is it possible? What cleaner should i use?
D325i is offline   Reply With Quote
Old 03-07-2011, 02:58 PM   #2
D325i
There halogen headlights.
Old 03-07-2011, 03:00 PM   #3
CalE46xi
My Ride: 3 pedals Xi
Send a message via AIM to CalE46xi
I use Mothers lens restoration kit. Works well. Easy to use powerball application for a cordless drill.
http://www.amazon.com/Mothers-PowerB.../dp/B00341MIAW
CalE46xi is offline   Reply With Quote
Old 03-07-2011, 03:08 PM   #4
D325i
Were you able to clean the inside of the headlights?
Old 03-07-2011, 04:20 PM   #5
Dean | KHOALTY, Inc
Past Site Sponsor
My Ride: BMWs
a good guide for you regardless if you replace or want to take them off for cleaning.. there's a DIY someone did about refinishing them, but most don't get great results as it takes a lot of time and a bit of knowledge, or a buffer
our lens set, direct replacement
Dean | KHOALTY, Inc is offline   Reply With Quote
Old 03-07-2011, 10:12 PM   #6
D325i
Old 03-07-2011, 10:34 PM   #7
infinite012
My Ride: White '08 STI
You won't want to "polish" the inside of your headlight lens. It's easily prone to scratching and will be nearly impossible to fix.
infinite012 is offline   Reply With Quote
