Thread Tools Search this Thread Rating: Thread Rating: 36 votes, 5.00 average. Display Modes
Old 09-24-2010, 10:07 AM   #41
daedalus34r
My Ride: 2004 BMW 330i
Hmmm... so i think im officially tired with the sub-par cutoffs from my depo p46. Your diy shows a massive overhaul going from halogen ~> FXR. How difficult is the swap if im just going from P46 Projectors ~> FXR . Will the FXR fit nicely in the P46 projector housing? Or are the cutoffs something you can fix separately.
daedalus34r is offline   Reply With Quote
Old 09-24-2010, 11:38 AM   #42
TerraPhantm
My Ride: M3 & ZHP
They went from halogen to fx-r, but they used P46s as the housing to mount the FX-Rs in. Cutoff on the P46 is probably impossible to fix without replacing the projector w/ something like the FX-R, since the projector itself just is not designed with very good optics.
If you had OEM AL projectors, it's pretty easy to mod them to have a much sharper and more colorful cuttoff. You also get a good bit more light. If you can get your hands on a set of those cheaply, it might be worth it...
Cutoff of modded AL projector
Modded projector left, stock right. Note that both projectors have the same bulb in them. Only difference in the projectors is that the driverside has a clear lens, and the shield was bent backwards very slightly (slight enough that the bixenon functionality works fine).
Old 09-27-2010, 09:28 AM   #43
FocusXi
My Ride: 325i
I still wanna know how it's done in an M3
2003 Bmw M3 DD
BMW 2001 325XI sold
1993 Toyota Supra sold
Ferrari F40 sold
Ferrari F50 sold
Ferrari Enzo sold
Saleen S7 sold
Bugatti Veyron sold
Koenigsegg CCX sold
Maserati MC12 sold
Pagani Zonda sold
Mercedes McLaren SLR sold
FocusXi is offline   Reply With Quote
Old 09-29-2010, 11:16 PM   #44
FocusXi
My Ride: 325i
Bump for an answer -_-
2003 Bmw M3 DD
BMW 2001 325XI sold
Ferrari F40 sold
Ferrari F50 sold
Ferrari Enzo sold
Saleen S7 sold
Bugatti Veyron sold
Koenigsegg CCX sold
Maserati MC12 sold
Pagani Zonda sold
Old 09-30-2010, 11:32 PM   #45
haurelio
My Ride: 2001 bmw 325i
hmm. i hven't seen any retrofit for the m3 but try hidplanet.com they know a lot about this stuff..
Old 10-01-2010, 11:21 AM   #46
FocusXi
My Ride: 325i
it's posted right in this thread that they retro'd it into an M3 ... n im curious how as to how
2003 Bmw M3 DD
BMW 2001 325XI sold
Ferrari F40 sold
Ferrari F50 sold
Ferrari Enzo sold
Saleen S7 sold
Bugatti Veyron sold
Koenigsegg CCX sold
Maserati MC12 sold
Pagani Zonda sold
Old 10-17-2010, 03:54 PM   #47
imdbui
My Ride: '03 330i ZHP
Thanks for the great write up! just got mine done
imdbui is offline   Reply With Quote
Old 10-25-2010, 10:08 PM   #48
imdbui
Originally Posted by snowcatxx87 View Post
Update!
They're in an e46 M3 now! Loaded silver with red interior!
After some programming, turning off the corner lights, daytime running light disable, fogs allowed to be on with highbeam, and bixenon + halogen inner (we need this for the quad projector)....
snowcatxx87 how did you do this?!
I've been reading threads for days for a solution and have yet to figure out how I am going to run power to quad projectors + bixenon function with the stalk (push/pulled).
Anyway you could add some detail to this? Right now I have the lows working, and flash to pass turning on the inner project (previously halogen). Bixenon (red wires) not yet wired.
TIA
BMWCCA #: 426134
'03 BMW 330i ZSP/ZPP/ZCW
// 6 MT // Jet Black // Gunmetal 135s + Michelin Pilot Sport A/S Plus // H&R Sport Cup Kit // Depo Clears // P46 + Orion V2 + Quad + FXRs + 6000K // BMW Performance Intake // BMW Performance Strut Brace // Dynavin V5 + iGo Primo // Escort 9500xi //
'88 Civic RT4WD
// Winter beater // E30 Bottle Caps // Yakima Load Warrior //
Old 10-26-2010, 06:21 PM   #49
snowcatxx87
My Ride: 04 330CI
I programmed the LSZ module of the car to allow Fogs/Highs/Bixenon to all come on. It is not that hard and you can brick your car. Search around the internets... or my username.... on a different BMW forum.
snowcatxx87 is offline   Reply With Quote
Old 11-16-2010, 01:09 AM   #50
volksfragen
My Ride: 2008 BMW
To put these in an M3, all I did was take out the original chrome "inner" parts and swap with the modified one I had already retrofit (the plastic piece that the Projectors are mounted to.
I just slid that piece into the OEM housing. Easy peasy!
pedobear FTW!
volksfragen is offline   Reply With Quote
Old 12-24-2010, 06:22 PM   #51
TerraPhantm
My Ride: M3 & ZHP
I'm buying myself an M3 quite soon; am I correct in believing that facelift sedan headlights can be used on prefacelift coupes if you swap the outer lens and inner trim? I've got a friend with failed ZKW headlights, so I'm thinking about selling him my headlights for cheap, and then spending a little more to get Caesar to do the TFX retro on the ZKW housings.
Old 03-01-2011, 10:21 PM   #52
SalM
My Ride: Shhh
Does this retrofit apply to regular halogen head lights? I have halogens since my bimmer is a 2000 328i. And they didnt have xenons/projectors then.
I'm assuming it should be the same thing.
SalMPhotography
SalM is offline   Reply With Quote
Old 03-02-2011, 02:54 PM   #53
SalM
My Ride: Shhh
Answer anybody?
SalMPhotography
Old 03-02-2011, 02:58 PM   #54
infinite012
My Ride: White '08 STI
Retrofit requires you to cut stuff up. So, yes, it should be the same thing.
infinite012 is offline   Reply With Quote
Old 03-02-2011, 11:47 PM   #55
haurelio
essentially the same, but the only difference is that you will have to modify the halogen frames. (make holes so you can fit the projectors)
Old 03-03-2011, 10:59 PM   #56
SalM
My Ride: Shhh
I'll just sell my Headlight then buy P46's and do the retrofit!
SalMPhotography
Old 03-03-2011, 11:16 PM   #57
infinite012
Waste of money. Save yourself the $400 and hassle of selling your headlights and just cut up your halogens. You'll still need to cut up the p46 frames to get the FXR to fit properly.
Old 03-03-2011, 11:18 PM   #58
SalM
My Ride: Shhh
Oh really?^^ Alright then so I guess I'll just do it directly on my oem Halogens.
SalMPhotography
Old 03-04-2011, 12:09 AM   #59
TerraPhantm
My Ride: M3 & ZHP
One thing that's kinda tricky with the halogens is aligning the projector. It's not supposed to sit parallel to the edge (if you end up mounting the projector parallel to the frame, then your output will be angled pretty badly when installed on the car). When doing the retrofit on a car that already has projectors, it's easy enough to just follow the line formed by the screws... there's no such visual guide in the case of the halogens.
Old 03-05-2011, 12:22 AM   #60
SalM
My Ride: Shhh
^^Thanks man!
SalMPhotography
