Thread Tools Search this Thread Rating: Thread Rating: 97 votes, 5.00 average. Display Modes
Old 06-14-2010, 02:17 PM   #1
Scott87
My Ride: 325ci 2001
Exclamation Airbag Occupancy Sensor Bypass Unit DIY (pics)
Well, every time I had a passenger in my car I got the really annoying airbag light on my dash. This is due to the sensors in the passenger seat failing or having failed. The seat has a mat inside it that can detect the presence of a person. Now this has broken the ECU detects that and puts the airbag light on. The bypass units can be bought on ebay very cheaply, mine was 5 delivered. They are basically just a small resistor to imitate the resistance created when a passenger sits in the seat. They are used to control the deployment of the passenger airbags. A crash with no passenger means no passenger airbags deployed saving on repair costs. Now this unit is fitted the airbags will always deploy as it always thinks there is a passenger (better than the other way round). The only downside is now you can't put a baby seat up front due to the airbag deployment. This, however, wasn't an issue for me and is way better than the 480 BMW wanted to fix it.
Any way, on with the DIY!
You will need:
Airbag occupancy sensor bypass unit
Maybe some tape/zip ties
Snips
Okay first up you need to roll the seat forward as far as possible then tilt it forward as much as you can. You don't need to go mad and push it forward there should be enough room if you lay down on the back seats. In this picture my fingers are on the connector unit that you will be working on:
If you look under the seat its right on the back side closest to you, ignore all the cables in the middle underneath. This is the unit you need to find:
At the top of the image above are a blue and white wire. These wires come out of the box (left side as you look at the image) and in to a connector block. The right side of the connector block needs to be unclipped and pull as much slack as you can out. This is the connector hanging down here, excuse the really bad photo:
Here is the connector cut off, leave yourself a couple of inch of wire on it:
Here is the bypass unit I will be connecting:
Mine came with some crimping blocks that needed to simply have each wire inserted and crimped shut. You may need to strip and twist them together then insulate with tape. Either way is fine and should look like this:
Now simply plug the connector back in to the unit and zip tie or tape the wires out of the way. Enjoy no more airbag lights!!
Scott87 is offline   Reply With Quote
Old 06-14-2010, 03:50 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Great DIY. I did this a couple of weeks ago and it works like a charm and its super easy.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-15-2010, 12:28 PM   #3
profor
My Ride: E46 320d 2003
if somebody is little bit more skilled, he can do it himself and not buying things from eBay.
I did some research by measuring the ocupancy sensor which was okay, and figured out which components You need to bypass the sensor if it is broken.
So You need soldering iron, not shaking hands and one 3k3 to 30k resistor and diode 1N4007.
schematic diagram is in the picture
CAUTION:
this is modded bypass modul that was previously posted on some forums, but that "OLD" one caused the airbag light off but the seat was in control unit of airbags NOT OCCUPIED. therefere I did this mod which will make the seat "OCCUPIED" even if nobody is there!!!!!
profor is offline   Reply With Quote
Old 06-15-2010, 12:35 PM   #4
Scott87
My Ride: 325ci 2001
I could have done with knowing the resistors rating before I bought it off ebay... oh well lol. I measured it myself out of curiosity when i got it.
Old 06-15-2010, 04:04 PM   #5
profor
Todays mod - used 4k7 resistor
Old 06-15-2010, 05:23 PM   #6
Scott87
My Ride: 325ci 2001
Cool. So you took the unit out and mounted it internally. Saves having an extra wire kicking about under there. Looks tidy.
Old 06-16-2010, 06:41 AM   #7
profor
Thank You,
yes is tiny, original blue/white cable is wound up inside, so it looks like nothing happened to it, also the sensor is connected.
Not occupied seat
Not okay - happens if the sensor is broken
Occupied - this state will have CU after installing the diode and resistor as i posted here
Old 07-10-2010, 09:49 PM   #8
cbrommer
My Ride: 2004 325i
profor, you do some kick ass work man, are you a electrician ?
innovative concepts :: e46fanatic :: cbrommer
cbrommer is offline   Reply With Quote
Old 07-10-2010, 10:40 PM   #9
taghirap
My Ride: tricycle...
Send a message via Yahoo to taghirap
subscribe. i will do this next week.
taghirap is offline   Reply With Quote
Old 07-11-2010, 04:56 AM   #10
profor
Yes, i am but not in car service, i am just interested in such stuff and i am not afraid to do these things on cars
E46 320d Touring 2003 - Autounlock after key is turned off, seat heating from Skoda OII, Instrument Cluster mods by Scott87, Trippling on turn signal lights, some repairs on GM with broken CL relays
Old 08-04-2010, 06:03 PM   #11
wildcat293
My Ride: 325xi
bookmarked if my seat sensor fails again, thanks!
wildcat293 is offline   Reply With Quote
Old 08-04-2010, 09:39 PM   #12
dakkon
My Ride: e46 330ci/e30 318is
do you guys know how to do this for someone with racing seats in their car? ?
Thanks.
dakkon is offline   Reply With Quote
Old 08-05-2010, 12:02 PM   #13
mvrk10256
My Ride: E30 325i
Thanks.
Would have to pull the electronics out of your stock seat and wire it in. zip it to the underside of your seat. I need to do this as well as mine went out like 6 months ago.
Old 08-16-2010, 08:35 PM   #14
haurelio
My Ride: 2001 bmw 325i
would this work for the seatbealt tensioner faulty code?
Old 08-17-2010, 07:03 PM   #15
profor
No, there You just need to connect, instead of seatbelt tensioner, 4ohm resistor.
Old 10-13-2010, 03:02 PM   #16
bayrischabua
My Ride: 2000 323i
Thumbs Up Great DIY instructions
I just finished installing the bypass unit and it took about 15 minutes. It helped to unbolt the seat to better see underneath.
thanks!
bayrischabua is offline   Reply With Quote
Old 10-13-2010, 03:20 PM   #17
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Where is the link on ebay?
Will the light turn off by itself?
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 10-15-2010, 09:46 AM   #18
Scott87
My Ride: 325ci 2001
My light turned off but some people need to have it reset. This shouldn't cost more than 10 really but expect to pay a little more if they are out to rip you off. It's a 2 minute job to reset.
Old 12-08-2010, 05:50 PM   #19
floorjacker
My Ride: 2000 318ci E46
Hi profor i tried this just now with a "n14002" diode and a 3k3 resistor and the light is still on? can you make any suggestions what i have done wrong?
floorjacker is offline   Reply With Quote
Old 12-08-2010, 06:54 PM   #20
El Polo
My Ride: 99 black 328i
Thank You,
Not occupied seat
ehmm what is that program? how does it work?
El Polo is offline   Reply With Quote
