Old 06-14-2010, 09:29 PM   #1
dolph1354
My Ride: 2001 330i
Stalls when stopping
Please help. 2001 330i, manual. Started stalling, engine light came on. found tear in small boot to idle control valve, replaced all boots. No more fault codes. But, when engine gets warm still loses idle when I release clutch at higher rpms(e.g. depress clutch pedal at 3000 rpm). Tachometer drops to 500 range or lower, sometimes recovers, sometimes stalls.
Have removed and cleaned MAF, idle control valve, and Intake Manifold Actuator (and sealed around the Intake Manifold Actuator gasket).
Help on what I should try next. These are expensive parts. Final point...inadvertently left the MAF unplugged, ran fine, no stall.
dolph1354 is offline   Reply With Quote
Old 06-14-2010, 10:19 PM   #2
Placey85
My Ride: BMW
Placey85 is offline   Reply With Quote
Old 06-14-2010, 10:20 PM   #3
jeffb325
My Ride: 325ci
Edit
jeffb325 is offline   Reply With Quote
Old 06-14-2010, 10:55 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
and what code was it?
Old 06-14-2010, 11:06 PM   #5
dolph1354
My Ride: 2001 330i
76, throttle position sensor 1, plausible range and E3, O2 sensor adaptation limit cyl 1-3.
Old 06-15-2010, 05:56 PM   #6
dolph1354
My Ride: 2001 330i
Still need some help if anyone has experienced similar.
Old 06-15-2010, 06:29 PM   #7
Scott87
My Ride: 325ci 2001
If you disconnect the MAF and it solves the problem then that is the problem. Without the MAF connected the car runs on some predetermined stock settings i believe. These should be enough to make the car function normally. With the MAF connected the car is getting erroneous readings which sounds like they are causing breathing issues.
Scott87 is offline   Reply With Quote
Old 06-20-2010, 03:45 PM   #8
NicB.
My Ride: 2000 BMW 328i
Check out my thread, I'm trying to compile all this stuff in one-spot. I will say that you have a 330i, so you may benefit from an ECU update.
http://forum.e46fanatics.com/showthread.php?t=755501
NicB. is offline   Reply With Quote
Old 06-20-2010, 04:32 PM   #9
Arty
My Ride: 1999 328i
This could be caused by the common problem of the Cam position sensor or crank position sensor failures. No fault code will be thrown when these fail. The MAF could be either the problem or a red herring.
Arty is offline   Reply With Quote
Old 06-21-2010, 08:20 PM   #10
JohnnyV
My Ride: 330i
Dolph1354, I too have that problem. I have a 2001 330i 5-spd manual, production date 07/2000. My symptoms are just like yours. It's generally only when the car is warmed up, and I have the AC on. Whenever I have rpm's over say 1500/2000, and depress the clutch the rpm's drop, sometimes the rpms bounce until it recovers and comes to idle, but sometimes it just stalls. This really only happens when I have my AC on though.
I've been dealing with this for a while. I've had the car since it was new and don't recall this being an issue when I got it. I had my alternator replaced at one point, and I'm starting to suspect that as my cause. Given that the AC puts a burden on the electrical system. I haven't had a chance, but in the next week or so, I'm going to put a meter on my battery while running first w/o AC on, then with AC on and see if I'm maintaining the voltage, or if there's a drop. If there is, it may be that the refurbished alternator I had put in has a faulty voltage regulator.
That's just my guess right now. Let me know if you find your issue. I'll post back if I find mine.
JohnnyV is offline   Reply With Quote
Old 07-05-2010, 08:58 PM   #11
dolph1354
My Ride: 2001 330i
Continuing saga. The MAF sensor was not the problem-same issues with a new sensor - as Arty said a red herring. From others' posts, I suspected and now I know. JohnnyV be interested to see what you find in your test. I am thinking it is either one of the sensors (cam or crank position) beginning to fail when hot-but doing so inconsistently, or the ECU needs an update. Seems like the ECU problem would result in a more consistent fail/symptoms than a sensor starting to fail-but would like to hear what others think???
NicB thanks for the link-I searched a fair amount before my first post. I'll go thru your post-more to follow.
Old 07-05-2010, 09:18 PM   #12
dolph1354
My Ride: 2001 330i
NicB - doubt it is your MAF -I swapped mine and it did not solve the problem. Weird difference thought is that mine ran better with MAF unplugged, but was clearly running very rich -burned significantly more gas on my regular commute than typical.
Old 07-05-2010, 10:30 PM   #13
hawk99
My Ride: 323ci
Intake Cam Position Sensor. Mine was doing the same.
hawk99 is offline   Reply With Quote
Old 07-06-2010, 01:16 AM   #14
snitzl3
My Ride: e60 LCI
Send a message via AIM to snitzl3
same here..
snitzl3 is offline   Reply With Quote
Old 07-06-2010, 08:44 AM   #15
NicB.
Yea, I'm doubting it is my MAF as well, I think you and I are experiencing the same issue.
Originally Posted by snitzl3 View Post
same here..
I've replaced both CPS with OEM parts, this didn't fix the problem for me. I do wonder if maybe it is the throttle position sensor (TPS) at times.
Old 07-06-2010, 09:41 PM   #16
dolph1354
My Ride: 2001 330i
I plan to try the intake cam position sensor next. Worrisome Nic B that this did not fix your problem.
Old 07-07-2010, 08:52 AM   #17
NicB.
I threw a code when the exhaust side went bad, didn't affect the way the car ran at all. I replaced the intake side pre-emptively, didn't change anything either. But, I do think it is good preventitive maintenance to perform, and if you are throwing a code, a must to replace.
Good luck and keep us posted.
NicB.
Old 07-17-2010, 02:37 PM   #18
hey808
My Ride: '01 325ci/'92 S13-sr
Any luck with this concern? I have a '01 325 that does the same thing. I cleaned the MAF last weekend and it seemed to help when the a/c is off, but while running the car today with the a/c on it stalled while I was creaping forward at a stop sign after I pushed the clutch in. I have a new idle valve, intake cam sensor, and no fault codes. I'll post if I find a solution
hey808 is offline   Reply With Quote
Old 07-18-2010, 01:18 PM   #19
JohnnyV
My Ride: 330i
Nope, nothing yet. I'll let you know.
Old 08-30-2010, 02:09 PM   #20
Daemonix
My Ride: '99 328i
Send a message via AIM to Daemonix
When the AC is on, the compressor puts extra load on the engine, which can make an issue like this happen more often. As my bearings in the AC pump are toast, I don't run the compressor, but will eventually replace it with the $250 one at rockauto.
Daemonix is offline   Reply With Quote
icv, idle, stalls
