Need help with fixing camber - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 06-16-2010, 02:55 PM   #1
Ashhong
My Ride: 2002 325i
Hey guys, so I just installed 18" VB3 rims and lowered my car with Eibach ProKit springs. Bought a lifetime alignment service with firestone also. I went and got the service done yesterday, but the guy told me after that they dont have the BMW tool to fix the front camber I believe it was. He said it was about 1 degree out of spec or something.
I called multiple other firestones to see if they have the tool, and one told me that they aren't supposed to offer alignment services to BMWs and to go to a dealer? So I then called a small BMW shop and he said the front are not adjustable at all...so I'm very confused.
I dont want to ruin my brand new tires here...is 1 degree out of spec terrible? Do I need to buy a camber kit or something? I'm very new to suspension things, my first rim and spring purchase Thanks for any help
Ashhong is offline   Reply With Quote
Old 06-16-2010, 04:59 PM   #2
hummer
My Ride: 2001 330CI
No camber adjustment is BS! I don't know of any tool required to adjust front camber. There is a factory setting pin that must be knocked out of the strut mount. However, there is limited adjustment. So, if you went too low then yes you may need a camber kit. Someone with the same setup may chime in. What is the camber now -1, -2, -?
Old 06-16-2010, 05:37 PM   #3
Ashhong
My Ride: 2002 325i
I left the paper somewhere, and will report back with what it is. I got Eibach Pro Kits, which are like the smallest drop out of any springs...factory pin eh, he probably didn't know about that or something.
Old 06-16-2010, 05:40 PM   #4
ChasCan
My Ride: 2001 330xi
YES. Camber is adjustable within a certain limit. All you need is someone who knows their sh1t!. Very simple adjustment! No special tool required. Chas.
ChasCan is offline   Reply With Quote
Old 06-16-2010, 07:09 PM   #5
Ashhong
My Ride: 2002 325i
Stupid firestone. So is this pin something that needs to be put back or anything after adjustment? Can I take it out beforehand and then take it in or should I tell them about the pin and have them take it out? Any more info about this pin?
Old 06-16-2010, 07:15 PM   #6
ChasCan
My Ride: 2001 330xi
Just chisel off the top of the pin head. The strut top plates are slotted & will then allow you to make small camber adjustments. If more camber is needed, then the 3 top plate holes will have to be elongated with a file or a drill bit to gain the additional camber necessary. However, very few alignment shops will do this extra procedure. And if they do, be prepared to pay extra. Chas
Old 06-16-2010, 07:32 PM   #7
hummer
My Ride: 2001 330CI
Look under the hood at the strut mount. There are three nuts that fix the mount the the fender tower. Next to one of the nuts is a pin. I just took a punch and drove it out. This pin is to make assembly at the factory go quicker. It must be removed to adjust camber. It will never be needed again!
Old 06-16-2010, 07:58 PM   #8
Ashhong
My Ride: 2002 325i
Thanks, I will take a look. So I can just punch it out myself, and then take it to an alignment shop and they can adjust the camber just like any normal car? Like, would I even need to tell them that I took this out or anything? Found my alignment paper, the numbers in red are....
Front Left Camber
Actual: -1 degree 04'
Before: -1 degree 04'
Front Left Toe
Actual (green): .15 degrees
Before: .17 degrees (I am assuming that they fix this and that its fine right?)
Front Right Camber
Actual: -1 degree 09'
Before: -1 degree 11'
Front Right Caster
Actual: 4 degrees 45'
Before: 4 degrees 45'
So yea...these are all foreign concepts to me. Seem fixable though?
Old 06-16-2010, 08:26 PM   #9
Itzed
My Ride: 2004 325xi
I wouldn't trust a Firestone dealer to put air in my tires.
Itzed is offline   Reply With Quote
Old 06-16-2010, 09:15 PM   #10
BMW_Matt
My Ride: 135
This.
BMW_Matt is offline   Reply With Quote
Old 06-17-2010, 02:11 AM   #11
Ashhong
My Ride: 2002 325i
Well I wanted lifetime alignment. I even contacted a BMW specialist, bullet motorwerks in OC, and he basically said the same thing. I will take a look for the pin later today. Once that is out they can align like normal right?
Old 06-17-2010, 11:05 AM   #12
hummer
My Ride: 2001 330CI
What were they trying to change it to? If your at -1 in front, it should be ok as is. I had mine set at -.8 to get better tire wear. Rears are at -1.5. I'm slightly lowered on H&R sports and Bilstein sports.
Old 06-17-2010, 02:23 PM   #13
Ashhong
My Ride: 2002 325i
well it says "Specified Range" for the front is -0 degrees 40' 0 degrees 00'
btw, how am i supposed to read the last 2 numbers with ' at the end? its not equal to -0.40 degrees..
Old 06-17-2010, 06:32 PM   #14
Ashhong
My Ride: 2002 325i
alright, just took it out. i am going to assume that now any alignment shop can fix the camber without special tools? will take it back to firestone
Old 07-13-2010, 09:01 AM   #15
electric130
My Ride: 2002 330i
did you get it fixed?
J.R.
electric130 is offline   Reply With Quote
