Old 06-16-2010, 03:33 PM   #1
ChasCan
My Ride: 2001 330xi
M3 Fuel Tank Baffle
To those of you that replied to my thread of my 330xi starving for fuel on the race track during severe right hand corners at 3/8 tank, I wish to extend my gratitude for your responses. Some were pro for the baffle, & some were not so positive. I guess it depends on the car. For my car the M3 baffle worked perfectly. I ran the fuel level to about 1/8 tank & never had any starvation issues. The little tricks I've lerned on this forum are invaluable. Thanks again to all. Chas
ChasCan is offline   Reply With Quote
Old 06-16-2010, 04:05 PM   #2
AL330CI
My Ride: 330Ci
Did you have to modify the baffle or is it a direct drop in?
AL330CI is offline   Reply With Quote
Old 06-16-2010, 04:55 PM   #3
drivrswntd
My Ride: 330ci
Told ya Dude!!!!!!!!!!
Jay
Boston BMWCCA chapter
drivrswntd is offline   Reply With Quote
Old 06-16-2010, 06:51 PM   #4
ChasCan
My Ride: 2001 330xi
Yeah, ya told me & I listened. Thanks for the advice. Chas
Old 06-16-2010, 06:53 PM   #5
ChasCan
My Ride: 2001 330xi
No Al. It is a direct drop in. Should take 1/2 hr or less. Unless you have the rear seat clips bust your ball$ like mine did. Chas.
Old 06-16-2010, 08:15 PM   #6
e46techtuner
My Ride: 2000 328i
Sounds like a good and easy mod.
e46techtuner is offline   Reply With Quote
Old 06-16-2010, 10:05 PM   #7
AL330CI
My Ride: 330Ci
Am seriously considering it now. I had intermitten fuel starvation at my last autocross event.
Old 06-21-2010, 06:56 AM   #8
ChasCan
My Ride: 2001 330xi
I can attest to the fuel starvation issue in my 330xi being solved at the track. It worked on my car. Ran it down to 1/8th of a tank & had 0 fuel starvation. It's definitly inexpensive enough & takes only about 1/2 hr to install. Hell, it surely can't hurt. Chas
Old 06-21-2010, 01:39 PM   #9
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
does anyone have a part number for this? is this something you ordered from tischer?
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 06-21-2010, 05:31 PM   #10
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You can order it from Tischer...I plan to do this and an M3 fuel pump at the same time.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-22-2010, 03:54 AM   #11
azzy989
azzy989's Avatar
My Ride: 325i
is the m3 pump a higher flowing pump? any benefits to running it?
i'm definitely interested in this baffle though. we've been hitting fuel cut in my car during autox'es... hard right hand turns with less than half a tank of gas...
if anyone knows the part number let me know. i am having a hard time finding it on the etk sites
Old 06-22-2010, 05:44 AM   #12
TerraPhantm
My Ride: M3 & ZHP
Any disadvantages to doing this? I haven't tracked my car yet, but I'd like to eventually. I also do drive some pretty intense roads over here occasionally (they're used for hill climbs at some points throughout the year)
Old 06-22-2010, 06:42 AM   #13
bigjae1976
bigjae1976's Avatar
http://forum.e46fanatics.com/showthread.php?t=704377
should answer all of your questions...
Old 06-22-2010, 06:55 AM   #14
ChasCan
My Ride: 2001 330xi
azzy, bigjae's link will answer all your questions. Chas
Old 06-22-2010, 07:24 AM   #15
TxZHP04
My Ride: ESS TS2+ ZHP
Yes, the M3 pump flows more than the standard 3 series pump. In theory, there should be no advantage to running this with a stock motor. Start with the baffle, if you continue to have problems let us know and we'll re-evaluate your situation.
Old 06-22-2010, 11:16 AM   #16
azzy989
azzy989's Avatar
My Ride: 325i
thanks guys... it never occurred to me to search on the forum
i will do this soon and report back after an event.. thanks again
Old 07-24-2010, 06:17 PM   #17
AL330CI
My Ride: 330Ci
Just finished installing the baffle. It took a bit longer than I'd thought. Upon putting everything back together, tt was a b*tch to press down on the pump & lock ring assembly hard enough to get the lock ring to engage the thread. After I was done, my fingers are raw.
One tip: The baffle has the part number sticker on it when purchased. Peel as much off as possible. Whats left can easily be wipe off with a piece of paper towel soak with little bit of gasoline from the tank.
