DIY: End All be All Thread on How to Fit Push-In Corner Lights - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-26-2009, 02:34 PM   #1
I*do*Werke
My Ride: E46 --> E30
Cool DIY: End All be All Thread on How to Fit Push-In Corner Lights
Who hates it when you buy a set of corners and they dont fit? I do and I know all of you guys do too. I have spent about 5 hours comparing the stock lights to the aftermarket ones and trying different things that could possibly make them fit. Then I finnaly found the reason why they didnt fit. I bought a set of smoked lighting upgrades from DEPO. I have a pre-facelift coupe and im sure this diy will work for all push-in(clip-in) type corners made by depo, and maybe even the cheap ebay ones.
This will take about 10 min of your time and you will need
~An exacto knife
~scissors
~dremel tool or sand paper
~(helpful, but not needed - a flashlight and superglue)
Im going to assume you already have the stock lights out and that you are having trouble with aftermarket ones. The reason why most of us have problems with fitment on these corners is because there is too much rubber trim around the edge of the light. Look at the comparison of the stock and depo lights.
(by the way, it might help to cut of a bit of the plastic as i did in ^ picture)
1. first you need to unscrew the 2 screws at the top of the headlight fixture and take off the black trim piece that keeps out water (it is held in place by clips, just pry them out)
2. take your depo corners and slide them in about halfway, MAKE SURE YOU HAVE THE CLIPS SLIDING IN THE CORRECT RUNNERS. examine how there is a little metal piece that is sticking out of the body work. This piece is what is stopping the corner from sliding in.
3. now take out the corner and get your exacto knife. You are going to have to cut off all the rubber that will touch the metal piece. If you want to be safe, like i was, put some super glue or sealant in the spot where you cut out the rubber.
4.Cut about 1cm off along the entire rubber trim piece as seen in this picture. Then sand it down with the dremel or sand paper.
(kinda sloppy, but it wont be seen)
5. (You can skip this step if you want, but it helped me out alot.) Take your scissors and cut off about half an inch off the top plastic prong thingy. It gets in your way of seeing if the clip has clipped in yet.
6. Slide in the corner as far as it goes (be careful) and then pull the headlight fixture towards the front of the car while pushing the corner in. It might take a little bit of force to get everything to click, but You should hear the amazing clicking sound and get a large grin on your face.
7. step back and admire the amazing look your car now has. I would say go get a beer and enjoy it, but im underage.
I*do*Werke is offline   Reply With Quote
Old 06-29-2009, 09:00 PM   #2
bhb7654321
My Ride: 2001 323ci
Great post thank you!
bhb7654321 is offline   Reply With Quote
Old 06-29-2009, 10:14 PM   #3
I*do*Werke
finally! someone took a look at my diy. I have a 323Ci and it worked great for me. hope it helps you
^M52B28 Swapped E30^
Old 07-07-2009, 10:23 PM   #4
andrewboi
My Ride: PY M3
Tried this DIY and it was fantastic. I did not get a "click" sound, but it definitely sits a lot closer to the OEM fitment than before!
Thanks for taking time to post this DIY
andrewboi is offline   Reply With Quote
Old 07-07-2009, 10:27 PM   #5
I*do*Werke
the click isnt that loud or noticeable, but you will know when its clicked in because you cant pull it out and it looks flush
Old 08-08-2009, 06:06 PM   #6
brodaiga
My Ride: 330ci
just did this, worked great
brodaiga is offline   Reply With Quote
Old 09-14-2009, 11:37 PM   #7
Stanimal
My Ride: '01 330ci
Thumbs Up
I struggled with this for at least an hr and just could not get
them to fit right
Thank god I found this thread, after reading, took maybe 15 mins
and fit perfectly flush.
Before and after (sorry for crappy phone pic, all I have at the
moment... oh and got rid of those crome pos rims too)
ID:	331475   Click image for larger version
Stanimal is offline   Reply With Quote
Old 05-08-2011, 01:48 AM   #8
I*do*Werke
Im surprised this hasn't helped more people. I see threads of people complaining of this exact problem all the time...
Old 05-08-2011, 02:09 AM   #9
sillieidiot
My Ride: '06 AW 330ci
wow i didn't even know this was a problem lol
Old 05-08-2011, 02:10 AM   #10
I*do*Werke
You wanna add it to your list of DIYs in your sig? I give you permission
Old 05-08-2011, 02:14 AM   #11
sillieidiot
i would if i could. that's all i can add lol i was thinking about making a thread with links to all lighting related DIYs, then putting that link in my sig. that way i can actually have a picture like everyone else
Old 05-08-2011, 09:59 AM   #12
e46rage
My Ride: 330ci 2001
I just got some led turn signals from jlevis and they stick out to much and they look like there about to fall out ima have to try this out !
R.I.P. E46RAGE.
e46rage is offline   Reply With Quote
Old 07-02-2011, 06:18 PM   #13
motoko013
My Ride: 2000 328Ci
this helped me today, thanks! was about to remove the whole headlight assembly i was so frustrated. but after cutting even more rubber and yanking the headlight while pushing the corner it finally clicked.
motoko013 is offline   Reply With Quote
Old 07-24-2011, 02:32 PM   #14
Kris.R
My Ride: 2012 Dodge Charger
Great post!!! Thanks OP.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 07-30-2011, 10:57 PM   #15
ZHud3
My Ride: black 323Ci
I just took the whole headlight assembly out and they went right in with no modification
2000 323Ci
1992 325is Sold ):
1984 325e
ZHud3 is offline   Reply With Quote
