Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
Rating:
Display Modes |
#61 | |
My Ride: 2004 E60 530i 6speed
Come on Papi, you know Pictures are a thousand words LOL
How is the tuning process coming along, I suppose you will have to wait until after you have finish with the exhaust to tell everyone? Quote:
![]() ![]() ![]() 530i E60 Custom Turbo/Nitrous (PSI_unknown) |
#62 |
whoaaa how did i miss this! Subscribed! I've been trying to do this with a buddy of mine... his company (Neukin dot com) specialize turbo manifolds and turbo kit components. Custom intercoolers, turbo manifolds and integration of blow off valves and wastegates, fabrication of race parts, etc... We just didn't have the time (together) and yet here you are doing it by yourself! Amazing!! I'm excited to see this fully develop!
#63 | |
flange exposed the adapter set that doesn't quite fit all the way this way for topmount, it's too short this is turbocharger properly seated on the manifold flange: not QUITE enough to fit the compressor housing there, i may try grinding it down some: the AC lines near the adapter: space between manifold and the body in the back should be fine for fitting a 2.5" downpipe modification to the tial gate to fit below the manifold next to the AC compressor the main fitting that drives the valve open has to be relocated, so you can see the low profile plug there and a new fitting on the side. i'm going to attempt to grind enough of the compressor housing down before i abandon this idea, as it would be REALLY NICE not to have to **** with the engine mount modification and generally work from the bottom of the car. i'll know by tonight if i'm going to procede with the topmount option. also, i must add, the turbochargingdynamics manifold is a VERY nice piece. i'm not sure how it fits yet in the way it was inteded to fit, but i'm impressed with the casting job so far.
2012 X3 - m-sport - stock
2004 325xi turbo - megasquirt3 for engine, Megashift for auto trans - build thread 1994 supra MKIV - single 72mm - aem v2, 1000CC ID, dual denso pump 2004 SE-R SpecV turbo - megasquirt3 ![]() Last edited by gurov; 08-11-2010 at 10:43 AM. |
#64 |
"Have some candy!!"
My Ride: 2003 Technik S1 M3
This is starting to resemble a e30 turbo build with megasquirt very interesting.
![]() Bimmerfest 2013 Photos here!!! "The road was miles ahead..It fell away, now I'm at thee end... Just a sky, the fall, and you..I got holes in my para~chute...... Then-you-say,' never gonna find all the answers~ answers will find you..Don't know how I'll feel tomorrow~ Don't know the truth. But we can lie,.. lie.., lie.., lie here together..lie..,lie..,lie..,lie here together..'" |
#65 | |
also, looks like i have to go topmount with this or die trying. TCD is meant for e36 it seems with the different angle engine, so on e46, the giant tial wastegate thing hits the body.
2004 325xi turbo - megasquirt3 for engine, Megashift for auto trans - build thread 1994 supra MKIV - single 72mm - aem v2, 1000CC ID, dual denso pump 2004 SE-R SpecV turbo - megasquirt3 ![]() |
#66 |
Any concerns with the extra power damaging the xDrive system? I know it's much simpler with a RWD setup, but you have 2 diffs to worry about as well as the extra compenets in the gearbox to transfer power up front. Also, any modifications to the ABS/DSC system?
2003 BMW 325xi
2010 BMW M3 Sedan ![]() |
#67 | |
there's actually 3 diffs... cause there's a center diff. i'm not sure if the DSC system is still going to be functional with all the control that's been taken away from the ecu. my primary concern is really the gearbox, but hopefully with proper tuning of the transmission controller, i will be able to put some power through it. the gearbox is rated at 390 ft/lb max by GM (as390r <--- the 390 in there). i just ordered a few parts that will hopefully make it painless to install the topmount setup.
#68 |
Thank you so much for the photos, it just adds a whole new life to the thread and conveying your project to others. I am liking your idea of going top mounted and hopes it working out.
As for the DSC just turn it off when you playing with boost or remove the fuse like HPF did on their M3 and see what happens. BTW, with 390rwtq that all wheel drive is going to be insane either way you look at it. 350rwhp and 350rwtq is fast on a all wheel drive car with stock internals etc... Wish you the best and looking forward to the more photos once you have the top mount sorted. Rito
#69 |
Might be a dumb question, but you are gong to cut the manifold around the flange, correct??
Also, do keep in mind with the top mount setup heat will BECOME a problem. You have plug wire, plastic valve cover, etc. there. Many e36 have had problems. I would definitely ceramic coat everything and buy a turbo shield. i would also wrap those plug wires.
This is my signature....
#70 | |
Banned User
#71 |
Looks good... I looked through the pics a couple times and didn't seen any jack stands though. A guy here at work was killed two weeks ago when his jack failed. He had good stuff and a nasty Mustang, but just one of those things. If you were using them and I just didn't see them, then my bad, but still... just sayin.
#72 | |
manifold is a T4 flange, i've got a t3 to t4 adapter, that doesn't raise it quite enough to clear the valvecover. i ordered a T3 to T3 adapter, one of those ones that adds a wastegate flange between the turbo. i will be using that to space the turbo further up. it should clear then, hopefully. the wastegate flange will not be used on the adapter. i also got a wastegate angle adapter to move the wastegate out of the way of the ac compressor below. i will figure something out about the heat. a turbo blanket will def be installed, and the essential wires protected. also, that is 390 ft/lb at the torque converter, so after going through all the gears/differentials it will be less than that.
#73 |
did you check out the manifold and adapters the technique tuning kit uses?
#74 | |
they're the ones with that long tube that goes from the corner of the manifold for the bottom mount to hang the wastegate off, right ? the manifold i got originally was an ebay piece, and the location of the wastegate port on that thing was not like the technique tuning, so i couldn't just buy the adapter, but i guess if ALL else fails miserably, i'll go that route.
#75 | |
BTW, I don't have a AT I have a 6speed manual drive the guy who started the thread however is AT.
#76 |
topmount is a go
![]() ![]() the wastegate barely fits, but it's in. decent amount of space around the turbo for heat insulation. oil feed is done, going to run return tomorrow, keeping the scavenge pump for now until i decide to blow a hole in the oil pan for gravity return. going going to start on the downpipe and hot side intercooler piping tomorrow, should be fairly easy to run ic piping hopefully.
#77 | |
My man still at it. this thing looking good dude and I am glad we have someone like yourself around. Wish i can see this car in person.
I'll be looking forward to your updates. thanks, Quote:
#78 | |
Banned User
OP aren't you worried those coils will get too hot? Last edited by xixixi; 08-22-2010 at 06:30 PM. |
#79 | |
Is the 5spd xi Tranny a direct swap for the OP, I think that would be a great idea if he is interested
#80 |
Banned User
Don't wanna go too far O/T.The 5spd I have should work providing the t cases are the same. If they are different, I have a T case. In fact I have the entire awd system from my car. He would still need a clutch flywheel etc. Great project, great thread! If you need and D/T parts let me know.
