Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 4.75 average. Display Modes
Old 03-04-2011, 11:08 PM   #461
geargrinder
My Ride: E46M3Cic6M E39540iT
Yep. I'd say it this way -
Loud definitely does not always = more power
but
Power almost always requires more loud, at least at WoT.
That said, the very best, well designed, well constructed, performance exhaust systems are those that are pretty quiet under most "normal" conditions and only really blast more than OEM under WoT conditions. Those are truly the best systems worth paying for and are what any smart enthusiast wants (instead of fart-can systems that are just blatting loud all the time and even probably not really that high performance).
This is usually done AFAIK with proper resonator/muffler design - both part choice and placement. This is why getting custom one-off muffler shop systems done can be hit or miss in terms of optimizing the loud vs. power ratio (aka vs. an engineered exhaust package)... Unless they have figured out a proper "system" for an exact chassis/motor, the resonance issue is a guess and 'random' as to if it will be successfully quiet at less than WoT. On the other hand if you do have a shop that's done a system for your car and you can see and hear it work (or if you know someone with a system 'recipe' - aka 'use an XYZ muffler here and an ABC resonator here in these sizes'), it's often a fraction of the cost of a fancy tuners system...
Originally Posted by mvrk10256 View Post
building it right - basically you need to up the diameter but put certain elements in the way (aero resonators) and a good muffler to quite it down, but in many cases sound = power. if you try to stiffle it you are also hurting the flow and decreasing power, I would suggest you stay with the stock exhaust if you are unwilling to work with a louder one.
2003 M3CicM6 TiAg
1995.5 Audi S6 Avant (utility/winter turbobattlewagen)
2006 Audi A3 2.0T DSG (hers)
geargrinder is offline   Reply With Quote
Old 03-09-2011, 06:55 PM   #462
lkstaack
My Ride: 04 330iZHP, 05 325iT
Originally Posted by Anthony@BimmerBrakes View Post
*Updated*
Ending of May. Then it will be 2-3 weeks before I receive any new headers.
-Anthony@BimmerBrakes
Anthony: am I to understand then that you will not have any headers for sale until the middle of June?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 03-09-2011, 08:33 PM   #463
spngr311
My Ride: 2001 M5
Just wanted to say that the headers fit perfectly. Installed very smoothly. Unfortunately, my straight pipes with glass packs that sounded great before sound terrible now. The exhaust is for sale now, since I have a Magnaflow kit coming now.
The only thing that sucks is that the O2 sim isn't working. It worked for like 250 miles, then the CEL came on.
spngr311 is offline   Reply With Quote
Old 03-09-2011, 08:38 PM   #464
mvrk10256
My Ride: E30 325i
the Sims have issue on the highway because the car does a lean cat check after about 40-50 miles of straight highway cruising. in the city it wont pop on, but if you do a lot of highway crusiing it will. just wipe it and leave it till the next time it pops on. the sims really are there to get rid of the light nothing else.
Old 03-09-2011, 10:52 PM   #465
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
I only have a few left. Still able to buy some but not at GB Pricing.
BimmerBrakes is offline   Reply With Quote
Old 03-10-2011, 09:09 AM   #466
spngr311
My Ride: 2001 M5
That's wierd, because my sims stayed off for the 200 mile trip from Satellite Beach to Clearwater, pretty much all highway driving. It didn't turn on until my return trip, while I was leaving Clearwater the next day; and that was when I was going maybe 35-40 in town. I cleared the code, but it has been coming back all week, and that is on my non-highway commute. While I know it's not a real problem, it is annoying to still have the light coming on and having to clear it every day or so. It's behaving as if the sims aren't there at all.
Old 03-14-2011, 07:19 PM   #467
spngr311
My Ride: 2001 M5
Anyone have a suggestion for the sims? Could they be bad?
Old 03-15-2011, 12:46 AM   #468
boehm330
My Ride: 01 330Ci / 07 Z4MC
Anthony, can you give me a tracking number for the O2 sims?
Still haven't got them yet, and I really wanna install these headers
Welcome to the Boom Boom Room
boehm330 is offline   Reply With Quote
Old 03-15-2011, 01:31 AM   #469
BimmerBrakes
The Brake Newbie!
Give me a Few Mins. I will answer both of your question ASAP!
Old 03-15-2011, 08:55 AM   #470
adame46man
My Ride: 2005 330i ZHP
Same here got headers so sim ....
Sent from my Droid using Bimmer App
Bimmerbrakes Headers, Magnaflow Catback Exhaust, Rogue Power Pulleys,Active Autowerke Software, Clear corners, side and tail lights, APEX ARC-8 wheels
adame46man is offline   Reply With Quote
Old 03-15-2011, 07:26 PM   #471
spngr311
My Ride: 2001 M5
Any update?
Edit: I'm getting two CEL's:
After Cat O2 Sensor Heater Circuit Cyl #1-3
After Cat O2 Sensor Heater Circuit Cyl #4-6
I did some research and it looks like it may be a break in the heater circuit (not necessarily related to the sims), looks like I have to trace the wires back to the harness...
Old 03-16-2011, 08:29 PM   #472
sc330
My Ride: 330i ZHP
Anthony;
I ordered a set of headers and O2 sims through your website last Wednesday but never got a tracking number and haven't received them yet. My order number is 178 if that helps. If you could please get me an update and tracking number, or estimated ship date that would be great!
Originally Posted by xixixi View Post
The 3 keeps getting worse... e36 was perfect. e46 reminded us perfection could be made better.... From e46 on they remind us of why we like the previous models so much better
sc330 is offline   Reply With Quote
Old 03-16-2011, 09:26 PM   #473
mvrk10256
My Ride: E30 325i
Any update?
heater circuit has nothing to do with the o2sims.
did you use the original o2 sensors or are you using a resister for the heater sim. they are the white wires.
Old 03-17-2011, 09:34 AM   #474
spngr311
My Ride: 2001 M5
Yeah, that's the same conclusion I'm reaching. I used the O2 sensors. I left the white wires intact and powered the sim off of the red/white wire in the loom in front of the filter housing above the engine. I'm going to measure the resistance of the sensors by this weekend to make sure they didn't break. I only have them zip-tied in the drug bin, didn't have the nut to bolt them to the junction box I put in (nuts should be here today or tomorrow). If the sensors are good, I'll look at the harness and make sure I didn't tug too hard on it or have any breaks in the wires. Since everything worked for a few hundred miles with the sims and the code I am getting is related to the heaters, I'm beginning to think they may have rattled and broke.
Old 03-18-2011, 01:42 PM   #475
adame46man
Got my sim today. Wont be installing headers for a couple weeks though.
Old 03-21-2011, 11:42 AM   #476
boehm330
Anthony any update on the O2 sims?
Old 03-21-2011, 08:53 PM   #477
BimmerBrakes
The Brake Newbie!
Shipping out a new one
Old 03-23-2011, 10:16 PM   #478
rictrd
My Ride: 330i E46 & DC5-R
My 330i after headers got a little worst fuel consumption than before headers, the indicator before headers was 13.5 lt/100km (about 17mpg) now is 14.3 lt/100km (about 16mpg) in the city theoretically should have better fuel consumption with the headers
BMW Performance Intake-Stett Performance Intake Boot Kit-Bimmerbrakes SS Header
rictrd is offline   Reply With Quote
Old 03-23-2011, 11:46 PM   #479
darksideracer69
My Ride: 01 325ci
I am sure you are not driving the same, how could you.
IMAG02051
Old 03-24-2011, 09:46 AM   #480
mvrk10256
My Ride: E30 325i
ya you put on those headers and all of a sudden you start driving a lot harder.
the headers themselves do not hurt fuel economy.
