Old 06-28-2010, 07:59 PM   #1
DSpencer18
My Ride: 2005 BMW 330ci (ZHP)
Send a message via AIM to DSpencer18
Question Error after hardwiring V1
I just got done hardwiring my v1 into my dome light and now my traction control is off? I didn't use the DSC button to turn it off but the brake and the traction control light is amber. I am not really sure why it would effect the traction, but does anyone have any ideas? Thanks. Drew.
  • Has: - BSW d210 Subs/Amp - iSimple Ipod Integration - Smoked Side Markers - Smoked Reflectors - LED White Interior Lights - Hoen Xenonmatch Fogs - Hardwired Valentine V1 Radar Detector - AVT Ram Air Scoop - BMW Performance Intake - BMW Performance Short Shifter Kit -
    - Lambda Chi Alpha Zeta Phi 1067 and E46Fanatics.com stickers. -
  • DSpencer18 is offline   Reply With Quote
    Old 06-28-2010, 08:14 PM   #2
    carcus
    My Ride: 2006 BMW M5
    I have never seen that before. Might be unrelated. Try unplugging the battery for 15 minutes and see if everything is good to go. Maybe someone has seen this before, 1st for me. Wish I could be of more help. You have a 2005, are you still under warranty? Not sure if you have the extended one.
    2006 M5 E60, "Lord Vader" Last real NA M series
    German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
    carcus is offline   Reply With Quote
    Old 06-28-2010, 08:25 PM   #3
    Crossfire05
    My Ride: 330ci
    Did you tie into a particular fuse?
    2001 330cic Jet Black
    Crossfire05 is offline   Reply With Quote
    Old 06-28-2010, 10:28 PM   #4
    DSpencer18
    I followed the DIY. I haven't tried unplugging the battery yet. I will try that. If anyone has anything else let me know.
    Old 06-29-2010, 01:53 PM   #5
    DSpencer18
    Problem fixed. I let my car sit overnight and it must have reset. Thanks Guys.
    Old 06-29-2010, 03:29 PM   #6
    Solidjake
    Zero. Leaks.
    Solidjake's Avatar
    My Ride: '02 330i 6MT
    I was going to say, its not related at all
    Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
    Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
    Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
    Old 06-29-2010, 03:47 PM   #7
    tuned325
    My Ride: E46 325Ci
    How did you hardwire your V1?? Did your V1 turn off when you shut off the car??
    tuned325 is offline   Reply With Quote
    Old 06-29-2010, 06:44 PM   #8
    DFC
    My Ride: 2003 330i
    This seems to be a popular link, haven't tried it yet though...
    http://m3.madrussian.net/diy_valentine_v1.shtml
    DFC is offline   Reply With Quote
    Old 06-29-2010, 06:53 PM   #9
    Solidjake
    Zero. Leaks.
    Solidjake's Avatar
    DFC posted the DIY link. You can leave the V1 turned on it will power on/off with the car.
    BTW, I wouldn't leave the V1 out in the sun because the internal components can get messed up.
    Old 06-29-2010, 08:19 PM   #10
    tuned325
    My Ride: E46 325Ci
    cool.. i did mine without the instruction.. it works, but it doesnt turn off when the car turn off...lol.. thank
    Old 06-29-2010, 08:22 PM   #11
    tuned325
    My Ride: E46 325Ci
    i know.. i used to that now im getting lazzy....
    Old 06-29-2010, 08:30 PM   #12
    Solidjake
    Zero. Leaks.
    Solidjake's Avatar
    Taking it down? You should. Heat is a bad thing for any radar detector. In the case of a V1, it will mess up the internal components and it will start to deteriorate in range or eventually lose a band completely. This is why it is recommended to send your V1 every two years or so for a tune up.
    Old 06-29-2010, 10:42 PM   #13
    carcus
    That is what they want you to think. Same with a Rolex watch.....send it in every 3 years for $500 polish and oil. My V1 is old and has no issues, working just fine. Also, depending on the software in the V1, might be cheaper to buy a used one with the update. Valentine really gets you on upgrades...especially if you have an older model. They normally will replace it with a newer model.
    Old 06-29-2010, 11:17 PM   #14
    Solidjake
    Zero. Leaks.
    Solidjake's Avatar
    Isn't it funny that I bought a used V1 and the X and K bands weren't working? I sent it in for a tune up and all is fine.
    Old 06-29-2010, 11:23 PM   #15
    Sansho
    My Ride: 2001 325i
    TThis is why it is recommended to send your V1 every two years or so for a tune up.
    Who recommends that? Sending in your V1 for an upgrade is one thing, but a tuneup? On the V1 site, they say if you have doubts on it's performance, call their techs and they'll determine if you need to send it in.
    Sansho is offline   Reply With Quote
    Old 07-26-2010, 01:58 PM   #16
    DSpencer18
    It is doing it every so often again. I am still under the extended warranty, and am going to get my final oil change/tune when I get about 98000 miles. (currently ~96000). Would this DIY void the warranty?
    Old 07-26-2010, 01:59 PM   #17
    DSpencer18
    The DIY Posted above is the one I used ( http://m3.madrussian.net/diy_valentine_v1.shtml ). And yes my V1 Shuts off with the car and powers on with the car.
    Old 07-26-2010, 02:08 PM   #18
    LittleChrist12
    My Ride: 2003 BMW 325xi
    They might try to give you a hard time if youwere having probelms with the dome light or sunroof, but bnecause the DSC/Traction Control is a completely separate system, there's no way they could blame its problems on your V1.
    2003 BMW 325xi
    2010 BMW M3 Sedan
    LittleChrist12 is offline   Reply With Quote
