Old 08-20-2010, 02:08 PM   #201
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Send a message via AIM to 2000_328CI Send a message via MSN to 2000_328CI
So jeff in the above is that referring to an iPhone4 or are there still no documented cases of iPhone4s either jb or not getting video to work with they dynavin through the built in cable
Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244
Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM
Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI
Old 08-20-2010, 05:18 PM   #202
jeffb325@DynavinSystems
J&T Distributing
jeffb325@DynavinSystems's Avatar
My Ride: BMW
Hey Chase, I think it is something different with the iphone 4.....I hooked up my 3GS to a dynavin V4 yesterday and it worked exactly the same as my older dynavin (in other words....it worked) Now I know for a fact that Apple broke some functionalities with iOS4 and the iphone 4. Another product I sell, the iSimple audio gateways....we actually are going to have to take them out of the car, open the case, remove a cirucit board, and replace it with a new one that is iOS4 compatible........As you can imagine, some customers are pissed, they bought an ipod interface, and it worked fine, they upgrade to iOS4 and now they have to take it to an installer and pay for parts and labor to get it working again!?.....
EDIT: So I go to PACs website to get a link showing you what I am talking about in the above post....and now the circuit board fix is even gone and it just says "not compatible with iOS4".....http://pac-audio.com/productDetails....&CategoryID=36
aaaaaarrrrrrrrgggggggggghhhhhhhhhhh...............
jeffb325@DynavinSystems is offline   Reply With Quote
Old 08-20-2010, 05:24 PM   #203
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
If I am Following you guys, the video is the issue with the iphone4 right? Playing the iPod from the iphone4 isn't a problem correct?
TRBOVNM is offline   Reply With Quote
Old 08-20-2010, 05:34 PM   #204
J&T Distributing
My Ride: BMW
correct, it does not seem to like to output video through the dynavins ipod cord, you can of course still feed video into the AUX in but is seems that the iphone 3G and 3GS behave differently than the 4.
Old 08-20-2010, 06:20 PM   #205
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
Right, the audio works fine through the ipod video (old school) and my iphone 4. It's just the video that is fail... i'm running RCA cables to resolve the issue and hope that they come out with a solution going forward.
Jeff, just to double check, this means that, even if I downgraded to the old os for dynavin it still wouldn't work with ios4 right?
Old 08-20-2010, 06:39 PM   #206
J&T Distributing
My Ride: BMW
Correct, dont bother changing the firmware as i have now tried my iphone with both the older and the newer and the results are identical. Im almost positive at this point that your iphone4 is rejecting the dynavin. Keep in mind with your old school ipod, i have not seen confirmation that a regular ipod has ever displayed video on the dynavin, i have only seen it work with iphones and ipod touch.
Old 08-21-2010, 05:01 PM   #207
J&T Distributing
My Ride: BMW
Well guys, good news and bad news......Good news is your response to this new business venture has been phenomenal!
Bad news is....the next shipment, expected in september, is now sold out too!
At this point I can't take any more new reservations as I will not be able to guarantee delivery beyond the existing reservations that I have already taken.
If you would like, I can still take your name and email address to keep you up on developments, and you would be first in line in case of cancellations, also the first to hear when I do start taking reservations again, but for awhile at least, no new reservations.
Thanks for making this such a success and I hope to have more dynavin available soon, I will post when I open up reservations again.
Old 08-21-2010, 08:37 PM   #208
TRBOVNM
well, definitely glad I got on the sept list. unfortunate for the ones that didn't, but hopefully dynavin will be able to work on getting the supply increased.
Old 08-21-2010, 09:19 PM   #209
Mulatto325
My Ride: 325ci convertible
Damn Jeff ur good should be a multi millionaire by now,Your cs is off the charts. I have been reading and reading the only thing i can say is your the best, I'm so happy i bought Ur actually unit, BTW did u jump the pink wire on my unit for the dvd play? sorry a little buzzed right now to much gray goose I'm sure you got the navi just right on my unit cant wait to get it. One more thing i need to run speaker wire my my 4 crossovers to my 4 channel amp the trunk http://forum.e46fanatics.com/showthr...721&highlight= I know Ur busy but if you had some insight it would be greatly appreciated. I have been doing the whole car audio thing since before i could drive and not sure what to do, So pissed at the shop that did my install. If you want to do it right got to do ti yourself. I know ur busy but any help would be appreciated. Thanks again Jeff, I was not ready to buy yet but when ur deal came a long i could not pass it up. I so happy now and i did not even get my unit yet. When I'm finished its going to look so EM and sound so aftermarket. IF I GET IT ALL DONE I MIGHT ENTER SOME SHOWS NEXT YEAR.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 08-22-2010, 09:41 AM   #210
J&T Distributing
My Ride: BMW
thanks man,
I sent you a new wire harness so you will need to ground the park wire, the one from my car was all chopped up from all the different stuff I have done in my car.
If I were you I wouldnt try to run new speaker wire unless you absolutely have to (I did read your other post as well), there is a good writeup here that should allow you to reconstruct your wiring and figure out what the previous installer did: http://forum.e46fanatics.com/showpos...&postcount=614
I realize this isnt exactly what you are doing but it has all the wire color codes and the wire locations so that you can figure out exactly what you are looking at.
Old 08-24-2010, 06:51 PM   #211
hoseb'sm3
My Ride: 03 AW SC M3
hey jeff, i just got my v3 unit yesterday and i guess i should have asked earlier but are the only changes from v3 to a v4 the knobs and the upgraded software? I have the HK system so do I still need to purchase a line output converter. says on the unit itself it was made 05/2010 so i'm assuming it's a v3. Thanks for any help you can give me.
hoseb'sm3 is offline   Reply With Quote
Old 08-24-2010, 06:57 PM   #212
J&T Distributing
My Ride: BMW
you have me confused man.....i assume you did not order from me?? I have never sold any V3 units but to answer your question, yes, if you have a unit with the old knobs it would be a good idea to use an LOC if you have any noise issues. The newer units come with the LOC. The only difference between the V3 and V4 is the knobs, the software is basically the same.
Old 08-25-2010, 09:10 PM   #213
msaltzman
My Ride: '06 4.4 X5
Hi there,
Im looking to put a dynavin in my X5 when the unit comes out for the 5/X5 series. Can anyone attest to the sound quality when you remove the factory (I assume HK) radio head unit and put the Dynavin in? Like does the sound still sound full and clear and is the CD player in the Dynavin any good? Baisically can anyone who still has stock everything talk a little about the difference between %100 stock audio quality vs Dynavin installed quality.
Thanks!
msaltzman is offline   Reply With Quote
Old 08-26-2010, 09:38 AM   #214
PreppyR6
My Ride: shines like justice
Wanted to show off my Dynavin system. Big thanks to Jeff for best customer service ever. Also thanks to Billy at Bimmer Evolution for setting up with the 3M brushed aluminum trim. Ill get better pics at dusk when the glare is gone.
Das Weena!
PreppyR6 is offline   Reply With Quote
Old 08-26-2010, 12:58 PM   #215
J&T Distributing
My Ride: BMW
Looks great pete! I see you found wolfncu as well!
Old 08-28-2010, 03:45 AM   #216
lfhdez
My Ride: 2004 BMW 325i
Send a message via AIM to lfhdez Send a message via Yahoo to lfhdez
ok ok ok. Jeff, I must say, after reading the whole thread, you certainly seem like you're running a great customer service operation. I would like to get on the list for the soonest possible unit available. Please let me know when you think that might happen. I do want to get my unit sometime this year =)
You can PM me but i'll subscribe here too just in case.
Thanks!
~Lu
Transmitido en espaņol por SAP
lfhdez is offline   Reply With Quote
Old 08-28-2010, 09:31 AM   #217
J&T Distributing
My Ride: BMW
Thanks!
Email me to get on the list
thanks
Old 08-31-2010, 09:35 PM   #218
someguy_99
someguy_99's Avatar
My Ride: E46,335Xi,Lambo,...
my bad, but how much is it again and when are the next shipments happening
someguy_99 is offline   Reply With Quote
Old 09-01-2010, 09:16 AM   #219
J&T Distributing
My Ride: BMW
read the first post of this thread.
Old 09-02-2010, 03:44 PM   #220
J&T Distributing
My Ride: BMW
Hey Guys, just a heads up. Im taking my little girl to Disneyland next week so I will be scarce....ill still be checking my email periodically so you can find me there but I wont be posting any extensive answers or picking up my phone at the office, ill be back next weekend and will try to get caught up then.
And to keep everyone in the loop, dynavin is telling me they will be producing units around September 15-20, so barring delays (like last time) we should see them around the end of the month.
