Thread Tools Search this Thread Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Old 07-31-2010, 09:52 PM   #61
slammin_330
My Ride: is no ZHP.
Just for clarification for me and others possibly:
I take it that the O2 Sim one would want would be the "Univeral Dual Output" from O2simulator.com?
http://www.o2simulator.com/index.php...products_id=10
Just wanted to clear this up for those who want to go that route.
Thx!
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
Old 07-31-2010, 09:55 PM   #62
slammin_330
My Ride: is no ZHP.
BTW, awesome writeup! I'm gathering parts as we speak! Already read it through probably 5 times, along with the linked threads/sites.
Thanks and mad props!
1974 Jensen Healey
1988 524Tds/5
2003 330i/5
Old 07-31-2010, 10:00 PM   #63
mvrk10256
My Ride: E30 325i
I would recommend holding off on this. Cause I definitly got one from them and it would only work with a siemens and not bosch sensor. So don't order from them. Also their customer service is non existant. I am getting one from anthony at bimmer brakes and will report back if it works. So hold off for a few days.
Thx!
Old 07-31-2010, 10:15 PM   #64
slammin_330
My Ride: is no ZHP.
Awesome, thanks! I'll stay tuned for an update. I can live with the CLE for a while. I take it the install will be the same with the one from Bimmerbrakes? So I can get everything preped and ready? I'm planning on installing it as per this thread:
http://forum.e46fanatics.com/showthread.php?t=689863
with a few personal touches.
1974 Jensen Healey
1988 524Tds/5
2003 330i/5
Old 07-31-2010, 10:22 PM   #65
mvrk10256
My Ride: E30 325i
yes the install will be basically the same....
I am so angry right now. It was supposed to be delivered today, and the tracking number shows it was delivered but it is definitly not in my box. ...... OMFG i hate the USPS.
Old 07-31-2010, 10:29 PM   #66
slammin_330
My Ride: is no ZHP.
I hear you on that one, although they did deliver the M30B35 oilpan for my M30 E30 swap a day ahead of time.
Good luck!
1974 Jensen Healey
1988 524Tds/5
2003 330i/5
Old 08-01-2010, 07:53 PM   #67
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Subbed for OP updates
phamine is offline   Reply With Quote
Old 08-01-2010, 11:44 PM   #68
mvrk10256
My Ride: E30 325i
thanks. after i do the front suspension tomorrow (i got new control arms, poly fcabs, tie rods, and end links ) I am gonna goto the post office and be angry until they give me my sim so i can hook it up. Hopefully it works.
Unfortunatly my car is making crazy loud rattleing noises. I believe it is the upper timing chain tensioner. hopefully get that resolved tmrw as well.
Old 08-02-2010, 08:30 PM   #69
mvrk10256
My Ride: E30 325i
those fools at USPS are still investigating. hopefully i will find myo2 sim by tomorrow morning. if not I am sure that Anthony @ BB and I can come to some sort of agreement ok with both of us since we share the shipping risk. also the bearing on my water pump is giving up. great more money out the door. will let you guys know as soon as i have some answers regarding the sim.
Old 08-04-2010, 01:33 AM   #70
mvrk10256
My Ride: E30 325i
So i got my sim from Anthony today, finally. Installed. We will see over the next couple hundred miles if the computer stays happy.
Old 08-04-2010, 09:41 PM   #71
phamine
Questions about removal:
1. I've unbolted the passenger motor mount. I don't have enough room to lift it out. How high can I jack the engine up to remove it?
2. How are you jacking up the engine? The jacking point I'm using is the oil pan with 2x4s. Is there a better location?
3. What tools did you use to remove the manifold nuts? Everyone mentions using a racheting wrench, but I don't see how to get one in there since the heat shield is in the way.
Old 08-04-2010, 10:34 PM   #72
dakkon
My Ride: e46 330ci/e30 318is
Q1) you can jack the motor up, until the motor starts to lift the car up from the drivers side mount..... so you have a way to go...
Q2) a 2X4 to spread the load,under the oil pan with a 20 ton bottle jack. or any type of bottle jack really
Q3) you can get a wrench in there, its a tight fit, and a HUGE pain in the ass, but it can be done... this is why the header job takes close to 8 hrs.... if the motor was out of the car, you could do headers in like 10 min.... but since there is almost no room, some of the nuts, are one click at a time, on a ratcheting wrench. you might also want to get some S wrenches, or at least one that is the size of the nuts... we had to use one on mak's car, on his rear header, rear most bottom bolt. if you pull the windshield washer tank out, and the secondary air pump out, that will make things easier as well.
this is an S wrench
http://www.google.com/imgres?imgurl=...ed=0CDgQ9QEwBA
if you have a harbor freight near you, you can get a set from them for cheep, they wont be ratcheting like the one in the picture though.
dakkon is offline   Reply With Quote
Old 08-04-2010, 10:52 PM   #73
mvrk10256
My Ride: E30 325i
I would also like to add to the third question. They are really pretty easy to get to as far as removal is converned. pull out the header closest to the front of the car first, and then take the shorter one out. remember what I said about pulling the windshield wiper tank and the pump. it all comes down to just doing it. no amount of tools will make it simple but a decent set of ratcheting wrenchs (both S and straight) as well as a 1/4 driver ratchet and a 3" extension can make it easier. but in the end you just have to get your hands in there.
Old 08-05-2010, 10:43 PM   #74
phamine
Alright. Going to use the tips for removal tomorrow.
Didn't think it would be such a PITA, all the bolts are not in your view so your working blind.
Old 08-05-2010, 11:05 PM   #75
mvrk10256
My Ride: E30 325i
Use your fingers. if you cant feel out the nut on a bolt, this may not be something you were cut out to do. It jsut takes determination. believe me. a guy like you really wont have any problems. but if you do PM me it be way faster.
Old 08-05-2010, 11:39 PM   #76
mvrk10256
My Ride: E30 325i
it definitly tricks the CEL and the o2 sensors but whether it will pass inspections i another thing entirely. time to do some more research. This is Anthony@BimmerBrakes o2 sim. I have found him to be a much better vender than o2sim.com.
Sorry for stupid big image.
Old 08-07-2010, 12:20 AM   #77
phamine
How many miles did you log? I don't think you can have more than 2 incompletes and pass inspection, in NY anyway.
Old 08-07-2010, 12:40 AM   #78
mvrk10256
My Ride: E30 325i
about 200. cleared the codes and then 200. i am not sure about the incompletes....
Old 08-08-2010, 06:45 PM   #79
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Maksim,
Looks goods. Work as they suppose too If you need anything LMK...
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 08-09-2010, 12:40 AM   #80
mvrk10256
My Ride: E30 325i
Originally Posted by Anthony@BimmerBrakes View Post
Maksim,
for ballin sponser. This is the guy to talk to about sims.
diy, e46, ebay, headers
