///M3 Forum
Old 06-30-2010, 08:44 PM   #1
vodoojak
My Ride: 2003 topaz blue M3
clunk sound while shifting
When i am just putting around town my rear end makes a clunk sound when shifting, but while under hard acceleration it feels solid and i dont hear any noise. Is this normal?
vodoojak is offline   Reply With Quote
Old 06-30-2010, 08:57 PM   #2
2filthy3
My Ride: e46 m3
Shift mode, total miles?
Could be rear sub-frame mounting bushes.
2filthy3 is offline   Reply With Quote
Old 06-30-2010, 09:02 PM   #3
DeanMachine
My Ride: 99 540-6
I would check the rear differential mounts.
DeanMachine is offline   Reply With Quote
Old 06-30-2010, 09:04 PM   #4
jsinclair_325ci
My Ride: 325ci
mine does that too unfortunately...but i adjusted my shifting to avoid the clunk. but id like to know who or what fixes this
jsinclair_325ci is offline   Reply With Quote
Old 06-30-2010, 09:20 PM   #5
SNORCE
My Ride: 2005 ///M3
subframe bushing. mine was the same. changed all seven bushing and now its fine. here is a diy. what the first video and ull know why it makes that thump noice
http://forum.e46fanatics.com/showthr...t=subframe+diy
SNORCE is offline   Reply With Quote
Old 07-01-2010, 08:18 AM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The ///M limited slip differential is know for a grinding noise during low speed cornering. When the rear wheel speed differential varies during tight cornering, a slip stick effect is created on the lining and steel discs incorporated in the differential locking clutch, causing the grinding noise.
This is the new fluid described by BMW to cure this problem (TSB# 33 01 02)
Often overlooked, scheduled rear differential service is very important. Over time gear lube breaks down causing bearings and internal components fail. Regular maintenance will keep your vehicle running properly for years to come.
ECS rear differential service kit includes:
* Three bottle of Genuine BMW Limited Slip Gear Lube
* Two New Genuine BMW Drain/Fill plugs
* Drain plug O-ring
Click HERE to order or for more information.
However depending on your millage it could also be your Guibo...
Best,
Joe
800.924.5172
clunk, clutch, rear end, sound, tranny
