Sponsored by BimmerWorld
Old 07-01-2010, 12:40 PM   #1
lllSupra
My Ride: E46 330i
Recommended Koni Yellow Setting?
I just ordered some Koni Yellows to replace my blown oem shocks and I am currently running H&R Sports. I hear you have to remove the rear shocks to adjust the damper on them? Anyway I want it to be right upon my install so I don't have to mess with the rear. What would be the best street setup for handling? Full stiff? I don't mind a rough ride.
Also how much of an improvement in handling will I have compared to my blown oems? I've had blown shocks for so long I forgot what its like...
lllSupra is offline   Reply With Quote
Old 07-01-2010, 01:35 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I wouldn't recommend adjusting it to full stiffness, running the shocks at the extremes can put excessive wear on the valving and cause them to fail prematurely. I typically recommend a middle setting but if you like it stiffer, then go with 3/4.
Old 07-01-2010, 02:12 PM   #3
lllSupra
My Ride: E46 330i
ok, thanks
Old 07-12-2010, 01:08 AM   #4
CokMinusTheS54
My Ride: '01 TiAg 325Ci 5mt
Hey, Brian right? Did you get them in yet? I've got a set of rears coming in the mail. What did you end up setting them at and how is the ride? Their website said they have about 5 full turns of adjustability, or maybe it was 5 half turns
CokMinusTheS54 is offline   Reply With Quote
Old 07-12-2010, 01:17 AM   #5
D-Rock
My Ride: 1988 325is m50
should be 5 full turns well mine are.
Image Hosted by ImageShack.us
D-Rock is offline   Reply With Quote
Old 07-12-2010, 02:12 AM   #6
CokMinusTheS54
^whatdo you have yours set at? What springs are you running and how is the ride?
Old 07-12-2010, 02:15 AM   #7
joneperry
My Ride: e46 + S60 + Z
ohh so how many shocks of yours were blown? did you drive around alot with blown shocks? and did a blown shock result in the car being lower on that wheel?
..reason im asking i noticed the right rear side being noticeably lower on my oem sport package suspension so im wondering if its a blown shock or broken spring
joneperry is offline   Reply With Quote
Old 07-12-2010, 02:24 AM   #8
CokMinusTheS54
^ 3 of mine are blown and no the car isn't sittng at different heights, but idk maybe yours are F'd
now back to my setting question??
Old 07-12-2010, 02:50 AM   #9
lllSupra
My Ride: E46 330i
Yo its Ryan, and no I haven't gotten them in yet... as far as the ride height being off that really shouldn't have anything to do with the shocks, sounds like a spring problem or something. Usually when shocks are blown the ride just gets horribly bouncy and ****.
Old 07-12-2010, 03:15 AM   #10
CokMinusTheS54
Ah my bad, close though. Where did you order yours from? Tirerack? I ordered mine from ECS, their website said they had them in stock but I only ordered rears. I'll start with a half turn and see how that feels I guess then go from there
~Christian
Old 10-16-2010, 04:29 PM   #11
Another BM
My Ride: 330ci
i think i blew my struts.. i had them at full stick and now it feels like i blew them... only had them 8 or 10 weeks
Another BM is offline   Reply With Quote
Old 10-17-2010, 07:15 PM   #12
lllSupra
My Ride: E46 330i
I have them in the middle setting front and rear, its a little stiffer in the front than the rear. Its perfect, it probably has to do with my stiff spring rates as well.
