From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 07-01-2010, 05:50 PM   #1
mousee
My Ride: BMW 325Ci SMG
Chassis difference
Is there any difference between an M chassis and non-M? If yes, what are their differences?
mousee is offline   Reply With Quote
Old 07-02-2010, 02:28 AM   #2
e46techtuner
My Ride: 2000 328i
Chassis or Unibody is pretty much the same. The drivetrain and cosmetic features is what is different from regular e46s and M e46s.
e46techtuner is offline   Reply With Quote
Old 07-03-2010, 05:09 AM   #3
mousee
which means I can turn my 325 into an M with a subframe to subframe swap! thanks!
Old 07-03-2010, 08:35 AM   #4
FTWeisse
My Ride: has no hip-hop rimz
Yup - the chassis are identical
Old 07-03-2010, 08:41 AM   #5
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
So does that mean e46 M3 are more prone to subframe failure because of the extra torque?
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 07-03-2010, 09:00 AM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
There is a very distinct difference in the rear between the Sedan, Coupe, and M3.
The sedan has the narrowest rear fenderwell, followed by the Coupe which about 10mm wider, and the M3 which is about 20mm wider yet.
Old 07-04-2010, 04:27 AM   #7
mousee
which is the fenderwell? Is it just to accommodate the wheels? Is it a removeable panel that I can replace to make everything match?
Old 07-06-2010, 09:35 AM   #8
tinkwithanr
My Ride: '00 323i + '75 2002
Can it be done? - Yes, but it requires extensive body work. If you look at the rear fenders of your car it's not like the front where you can just unbolt the non-m and then bolt up the M fenders. You'll actually have to cut out the old and weld in the new. Search for Jeppe's non-m to M sedan conversion if you haven't seen that tread yet. He went through the process of doing that along with everything else needed to make his non-M sedan into an M.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 07-06-2010, 03:47 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
It's really a beautiful build.
Old 07-07-2010, 08:58 AM   #10
m1356guy
My Ride: is worth $5k
^ and now he's supercharging it
m1356guy is offline   Reply With Quote
