Sponsored by BimmerWorld
Old 07-02-2010, 02:09 PM   #1
Ineil
My Ride: 2001 M3
Rear end squirrelly with med to hard acceleration
Can not find anything at the rear that seems out of place, loose or missing.....any ideas? I have recently lost my DSC functionality.
2001 M3
M3 sold
New Car
2012 Roush Stage 3 Mustang
Ineil is offline   Reply With Quote
Old 07-02-2010, 03:32 PM   #2
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
Rear trailing arm bushings most likely.
HP Autowerks is offline   Reply With Quote
Old 07-02-2010, 03:50 PM   #3
Ineil
My Ride: 2001 M3
I just replaced with Rogue Engineering RTABs about 5k miles ago, but I will check them.
M3 sold
New Car
Old 07-02-2010, 05:02 PM   #4
Minnoe07
My Ride: 2004 BMW 330Ci
If you recently had your RTAB's replaced, did you go get an alignment? If not, that is the reason why. Your alignment is off and you need to get it realigned. The trailing arms that you remove to replace the RTAB's are what you adjust to correct the alignment. It is precise and if you did not put it back EXACTLY where you pulled it off, your alignment will be off.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 07-02-2010, 06:22 PM   #5
Ineil
My Ride: 2001 M3
That was 5k miles ago, and I got a four wheel alignment when I had new shocks, struts and springs installed about 6 -7 months ago. This issue just started a few weeks ago.
M3 sold
New Car
Old 07-05-2010, 03:25 PM   #6
Ineil
My Ride: 2001 M3
I took a real good look at it this afternoon, and nothing obvious. There does seem to be a little leak where the pasenger side drive axle connects to the differential. Everything seems to be tight and solid. Turning left and breaking makes a strange gringing or scraping noise. Could it be the drive axle? How do I tell?
M3 sold
New Car
Old 07-05-2010, 03:34 PM   #7
Nachos23
My Ride: 2009 335Xi Sedan
Send a message via MSN to Nachos23
Turning left makes grinding from rear? How do CV boots look? Torn, or any signs of leakage around boots....You mention leak @ diff, anywhere else?
Any chance of wheel rubbing?
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
Nachos23 is offline   Reply With Quote
Old 07-05-2010, 03:38 PM   #8
Ineil
My Ride: 2001 M3
I checked the boots, they looked fine, no tears or leakage. It dosn't sound like rubbing, it sounds more like metal.
M3 sold
New Car
Old 07-05-2010, 03:48 PM   #9
Ineil
My Ride: 2001 M3
Could it be the wheel bearing?
M3 sold
New Car
Old 07-07-2010, 08:56 PM   #10
Ineil
My Ride: 2001 M3
I found the noise is coming from the front, I think I have either a loose or cracked break pad. I am more concerned about the loose rear. I am going to check the axle shafts this weekend to see how much movement there is. Checked everything this weekend and everything looks good, wheel bearings were fine, now for the axle shafts.
M3 sold
New Car
Old 07-22-2010, 06:54 PM   #11
Ineil
My Ride: 2001 M3
Well the problem has been found. I am not sure why I did not find it, but Tischer BMW has a free inspection offer and they found the right rear wheel bearing is shot. It is real bad. Thaey want $1,130.00 to replace......too much?
M3 sold
New Car
