Old 07-05-2010, 08:33 AM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
75w-140 vrs 75w-140NS for LSD
I'm about the change the oil in my rear end which is a metric mechanic clutch type LSD.
Should I use the regular redline 75w-140 or get the "No Slip" oil?
Can I even use the No Slip oil?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-05-2010, 08:50 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
Use the 75w140... the 75w140NS is for gear based diffs (open, Quaife) and doesn't contain the friction modifiers needed for your clutch type diff.
