Old 07-07-2010, 12:58 AM   #1
SalM
My Ride: Shhh
Water Pump & Pulleys Help!
Sup Guys I'm looking to Buy a New High Performance Water Pump and new Pulleys
They Only Brand I seem to see good and noticeable improvements is with the Uuc Underdrive Pulleys And The High Performance Water Pump On their Webstite and Both For $450 Shipped After Tax
But Before I pull the trigger
What Company has better Pulleys And Waterpumps that Show/Feel a more signifigant Gain in power
In general with a new High performance water pump is there or I should say do you feel more power while driving?
Same Question As Above Except Involving The Pulleys?
SalMPhotography
SalM is offline   Reply With Quote
Old 07-07-2010, 01:40 AM   #2
i0kr1sol
My Ride: 330ci
You wont gain power with a 'high performance' water pump.
There are two sides in every story, search about underdrive pulleys. Some say the difference is negligible, some even say their dangerous.
And a lot of people go for the Stewart Water Pump for upgrading their water pumps.
i0kr1sol is offline   Reply With Quote
Old 07-07-2010, 01:45 AM   #3
SalM
My Ride: Shhh
Im not looking to gain like Hp power out of the pump Just Power in general would car feel like it has more power since the water flow is increased by almost 35%
SalMPhotography
Old 07-07-2010, 05:30 PM   #4
msb046
My Ride: 2001 330xi
Increased water flow has nothing to do with how the car "feels," but only how well the engine is cooled. It would just be better than the OEM pump at preventing the car from overheating. I'm not really sure what you mean by "would the car feel more powerful" while not referring to the HP.
However, if the high performance pump has a better flow-design resulting in less resistance, then you could technically get less parasitic drain on the engine and maybe an extremely small power increase. Most likely you wouldn't be able to feel the power gain, though.
If you underdrive the water pump (literally slowing down your water pump by using a larger pulley,) you would decrease the load on the engine (at the expense of decreasing the effectiveness of your cooling system.) Some say doing this has noticeable power gains, others say it doesn't.
IMO don't mess with underdriving cooling system. It's not something you want failing on you at any point, because the cost will outweigh the benefits.
If you do decide to underdrive the water pump, then replacing the pump with the high performance stewart pump could help counteract the decreased cooling effectiveness.
msb046 is offline   Reply With Quote
Old 07-07-2010, 11:18 PM   #5
SalM
My Ride: Shhh
Thanks for the Input guys!
SalMPhotography
Old 07-09-2010, 07:10 PM   #6
SalM
My Ride: Shhh
Bump!
SalMPhotography
Old 07-09-2010, 07:50 PM   #7
Jackcat559
My Ride: 2003 530
I've got the Stewart pump. No real noticeable difference. It's just a better pump.
Find a way of eliminating the mechanical fan (ie Zionsville) and you will notice a better throttle response
Jackcat559 is offline   Reply With Quote
Old 07-09-2010, 08:45 PM   #8
SalM
My Ride: Shhh
Please Explain more.... About this Mechanical fan elimination u speak of
SalMPhotography
Old 07-09-2010, 11:45 PM   #9
xi_ter
My Ride: 2003 325xi
This thread explains swapping an electrical fan in.
http://forum.e46fanatics.com/showthread.php?t=744994
Old 07-10-2010, 01:32 AM   #10
///Mine
My Ride: '05 325i
its really only dangerous if you underdrive the alternator when you have a system in your car.
///Mine is offline   Reply With Quote
Old 07-10-2010, 10:03 AM   #11
SalM
My Ride: Shhh
How come?
SalMPhotography
Old 07-10-2010, 10:08 AM   #12
Jackcat559
My Ride: 2003 530
Loose a battery charge I would guess
Old 07-10-2010, 04:53 PM   #13
SalM
My Ride: Shhh
Ok So far the pricing is
Stuarts WaterPump - $195
Uuc Pulleys - $199
Electrical Fan - $253
But I have a quick question I have a Manual Does The Electrical Fan still need to be replace or I should say does manual have an electical fan or its mechanical aswell...
SalMPhotography
Old 07-10-2010, 05:00 PM   #14
Jackcat559
My Ride: 2003 530
Stuarts Water Pump - $195
Uuc Pulleys - $199
The priority should be
1- fan
2- pump
3- pulley
Old 07-10-2010, 05:04 PM   #15
SalM
My Ride: Shhh
Oh yeah That I know thats just how I wrote it....
SalMPhotography
Old 07-10-2010, 05:06 PM   #16
shanneba
My Ride: 2003 330Ci
BMP design has the Stewart water pump for 165.96. You can get another 10% off if you are BMWCCA member.
They also have aluminum water pump and power steering pulleys, standard size not under drive. They are about $33.00 each.
Join BMWCCA
Old 07-10-2010, 05:08 PM   #17
SalM
My Ride: Shhh
Oh wow Bmp Has good prices... I actually just saw that while Searching up the Water Pump on Google
And Im looking at the underdrive Pulleys from Uuc Motorwerks....
So Far Pricing.....
1. Electrical Fan - $253
2. Water Pump - $165
3. Underdrive Pulleys - $199
SalMPhotography
Old 07-11-2010, 09:20 AM   #18
SalM
My Ride: Shhh
Any More Opinions On Underdrive Pulleys?
SalMPhotography
Old 07-12-2010, 08:15 PM   #19
SalM
My Ride: Shhh
More opinions?
SalMPhotography
