Old 07-07-2010, 08:44 PM   #1
jblack03zhp
My Ride: 330i zhp
UUC Stage II flywheel with which clutch?
I'm looking into getting the UUC Stage II Flywheel for my 330i ZHP and I was wondering as to which clutch plate setup to use in conjunction with this:
Stage I performance organic
or
Stage III Multi-puck ceramic
or
OE M5
If there's anyone with any of these combo setups can you please give me a brief insight & opinion.
Also I'm planning to change out my tranny & engine mounts while I'm in there, any preferred brands or are they all about the same?
Thanks for the help guys
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
Old 07-08-2010, 09:54 AM   #2
tinkwithanr
My Ride: '00 323i + '75 2002
I just installed the stage 2 flywheel with the OEM M5 clutch and the car feels great. I can't compare it to a stock setup since I went from a steptronic to the 5-speed with this setup, but the clutch has a very nice weight to it and it drives great. I also can't comment on the Stage 1 performance clutch, but I've heard it's also very nice. The Stage 3 multi-puck will most definitely be overkill unless your planning on racing with it and make a lot more than stock power. It's engagement will be a lot more like an on/off switch, and it will also make a lot of noise.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 07-08-2010, 10:56 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
Don't think the M5 clutch is compatible with the 6-spd flywheel, you'll need to check with UUC about that. Of the options that I know will work, go with the performance organic. Avoid anything multi-puck on a daily street driven car.
As for engine mounts, the ONLY aftermarket mounts I can recommend for street duty are the BimmerWorld solid rubber mounts. They will add a little bit of noise and vibration over the stock fluid filled mounts so if that might bother you, just stick with stock. There are a couple of reviews of these and the near identical (except in price) Group N mounts around here that you can search out. For transmission mounts, I like the black neoprene UUC street mounts paired with the enforcer cups. I run the BW motor mounts with UUC transmission mounts and enforcers and they work very well together.
Old 07-10-2010, 10:02 AM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I thought the 6sp UUC flywheels use the OEM E36 clutch?
I have the Vorshlag mounts...they do add some NVH. Not horrible but I could imagine that a lot of people wouldn't like it.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-12-2010, 01:52 PM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
or
or
OE M5
We offer the entire UUC catalog and you can see all of your options below...
Click HERE to order or for more information.
*Photos for reference only*
I am personally running the Stage2 with the M5 cluch kit and love it! It's been on for several years now with out any trouble!
Best,
Joe
Old 07-12-2010, 02:03 PM   #6
TxZHP04
Best,
Joe
Your web site doesn't indicate the M5 clutch kit applicability. If the pics are accurate, then the M5 clutch will not work with the OP's 6-spd transmission. The 6-spd transmission uses a 22 spline disc, not the 10 spline pictured.
Old 07-12-2010, 04:02 PM   #7
tinkwithanr
^^ The 6-speed transmissions require at minimum the Performance Organic Clutches from UUC.
Old 07-12-2010, 06:00 PM   #8
jblack03zhp
My Ride: 330i zhp
If the M5 clutch will not work with my 6spd tranny, should I go with the stage I organic? I should I look elsewhere for the clutch plate?
Old 07-12-2010, 06:07 PM   #9
bigjae1976
bigjae1976's Avatar
From UUC's website...
This aluminum flywheel boasts the same great features as our first-generation flywheel, but is designed to use the pressure plate from the E36 M3 and UUC's custom sprung-hub clutch disk with a choice of various performance facings.
Again, 6sp does not use the M5 clutch.
Old 07-12-2010, 06:36 PM   #10
cnotesdip
My Ride: 330ci
does the m5 clutch work on the m3 6 speed?
cnotesdip is offline   Reply With Quote
