Old 10-24-2012, 10:35 AM   #21
joegr
My Ride: 2002 325i
Originally Posted by sunsetcoast View Post
Is our sedan the only car in North America that doesn't have that button? If so, how difficult is it to retrofit?
What do you mean? My 325i has the button, although it could be in a better location.
joegr is offline   Reply With Quote
Old 10-24-2012, 12:08 PM   #22
sunsetcoast
My Ride: '99 323i & '00 323iT
I mean that, where our Touring has a button (above the hood release lever), our '99 323i has a smooth piece of plastic. No button. Power everthing else, but no remote trunk opening unless you use a key.
sunsetcoast is offline   Reply With Quote
Old 10-24-2012, 12:15 PM   #23
Brinkley
My Ride: 99 328i, 07 z4 3.0
That's odd. Perhaps you could simply install the release button, if it's prewired.
Brinkley is offline   Reply With Quote
Old 10-24-2012, 04:15 PM   #24
flickinswitches
My Ride: 2000 318i Executive
So to diagnose the problem which is the fuse for the trunk release ?
flickinswitches is offline   Reply With Quote
Old 10-24-2012, 04:37 PM   #25
WDE46
My Ride: '13 128i, '04 330Ci
Look at the cheat sheet that is in the fuse box.
Old 10-24-2012, 04:38 PM   #26
WDE46
Originally Posted by Brinkley View Post
Huh?
haha i provided no context. There was just some kid up there who posted his age. I thought it was funny.
Old 10-24-2012, 05:00 PM   #27
Wolrab
My Ride: 330Ci MT, 545i SMG
Originally Posted by WDE46 View Post
The only people who mention their age are all younger than 18.
I'm 58. And I'm not living with my mother.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 10-24-2012, 05:08 PM   #28
flickinswitches
None of them give any indication they relate to anything to do with the trunk release?
Old 10-24-2012, 08:56 PM   #29
RangerDave
My Ride: '00 328i ZSP w/ 214k
I would GUESS that it's the same fuse as for the door locks. Take that one out and see if your trunk still opens.
BMW - Suzuki - Jeep
RangerDave is offline   Reply With Quote
Old 10-24-2012, 11:38 PM   #30
cityjohn
My Ride: 2001 M3
Yes. I would start with #52, then try #49 and #60.
And to those retrofitting the switch by the hood release: Why not just use the touchpad switch above the license plate? The switch by the driver is redundant anyway. The only time I think the button is useful is with some passengers, it's easier to just "pop the trunk" for them to get in than explain how they need to press the pad below the trunk handle. They just stand back there looking at it...
cityjohn is offline   Reply With Quote
Old 10-25-2012, 09:20 AM   #31
Brinkley
I know. Just trollin for some lols. This board needs some.
Old 10-25-2012, 05:31 PM   #32
sunsetcoast
Sort of like power windows on a coupe. Or remote locks when there is a place for a physical key. It is more convenient.
Old 03-21-2014, 05:35 PM   #33
topdown
My Ride: 323ci
So, my trunk button, soft trunk pad, or key fob (for anything) will not work - only the key will open the trunk.... and as we already know from the door, the locks will fail.
Input? and where is this wire you speak of that my be the culprit?
Thanks!
[2000 323ci conv]
topdown is offline   Reply With Quote
Old 03-21-2014, 06:41 PM   #34
wildirish317
My Ride: 2004 325Ci vert
First, check the position of your glove box lock. You have a convertible (deduced by your username). One position of the glove box lock will disable the trunk lock. It's called the valet position, and is a feature that has driven vert owners nuts for over 10 years.
Originally Posted by Bentley
In Convertible models, the glove
compartment lock is integrated into
central locking functions. An additional
lock actuator is positioned above the
glove compartment lock, locking it
whenever central locking is activated.
A microswitch on the glove compartment
lock cylinder signals the GM V to lock
the trunk electrically. This is the
equivalent of valet key position. The
trunk can only be opened with either the
remote (FZV) key or the wallet key.
Also, the trunk is locked whenever the
top storage compartment is unlocked
while the top is raised or lowered. The
top storage cover motor Hall sensor
signals the GM V whenever the cover is
unlocked.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-21-2014, 06:49 PM   #35
beeemerdude
Banned User
My Ride: Cabrio. Stick.
Originally Posted by Lusticles View Post
She was checking your trunk for drugs, and whatever else you crazy kids do these days.
also lookin for possible 3 dead hookers? (like that car trunk decal)
beeemerdude is offline   Reply With Quote
Old 11-28-2015, 04:33 AM   #36
qaseemax
My Ride: 318i Convertible
worked like a charm.
Originally Posted by AlbertW 16 View Post
Convertible key holes are always horizontal. The valet mode is engaged by locking the glove box, not by turning the lock to vertical. You need to make sure your glove box and doors are unlocked. If that doesn't work inspect the wires in the sleeve between the trunk lid and the body for breaks.
The unlocking the glove box tip worked. It funny how these little things aka features can get us grinding.
I had already unscrewed the lock in the trunk when a I thought of checking the fuse and ran into your post.
Thanks.
qaseemax is offline   Reply With Quote
Old 11-28-2015, 12:03 PM   #37
topdown
My Ride: 323ci
Glove box is open. I was able to put trunk In valet, so it hasn't been. That harness had been pinched in the trunk lid and the whole thing Fixed/redone. Key worked doors but not trunk. rear view mirror has the wires to communicate with the key. Fuses were checked. I can clean mirror contacts again.... Otherwise out of options.
Old 02-11-2016, 02:38 PM   #38
topdown
My Ride: 323ci
Exact same with mine- any solution? And guys we know valet, and counter clockwise.... We need actual solutionsz
Old 02-12-2016, 06:53 AM   #39
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You redid the loom in the trunk? Depending on how you did that, that could still be the issue. After one wire fails, eventually many of them will. I did redo my entire loom from body to trunk lid...see my thread entitled "elephant trunk."
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-22-2017, 11:04 AM   #40
topdown
My Ride: 323ci
All of the wiring in the trunk harness were re-done, still no fix for the trunk fob or interior latch. The tumblers are getting soft, and I fear the worst. It is a convertible, I do know what valet means, so please don't post another condescending statement about that. Perhaps a real solution.
BTW: if the key fob will not open the doors on the convertible, make sure all the wires in the "rear view mirror" are plugged in, that is where the brains are in this model.
button, dash, trunk, working
