Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 07-08-2010, 09:15 PM   #1
meteoriteSilverE46
My Ride: 2003 E46
TURBO PROJECT E46 325I 10-15 lbs
have a 03 325 about to put a rear mounted garrett M27 AR .51 turbo thinking of running around 10-15 lbs of boost...trying to hit at least 400 hp..Got the idea and floor plans from a friend of mind..u might know..he's the producer of the show "Pinks all out"..im just tried to the ricers here in dallas pulling along side of me on the freeway! next time i'll have a surprize for them
any idea what upgrades they have out there to beef up the tranny and rear end?
meteoriteSilverE46 is offline   Reply With Quote
Old 07-08-2010, 11:08 PM   #2
E46 S54B32
My Ride: 323ci
sooo whos tuning it? (bet u didnt think of that)
ohh and 10 psi (if you get it tuned) maybe....14 your funny
sorry just the truth
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 07-08-2010, 11:10 PM   #3
lllSupra
My Ride: E46 330i
14 with a 10mm turbo will work.. hehe
SEDAN SUPREMACY!
E46 for life
lllSupra is offline   Reply With Quote
Old 07-08-2010, 11:26 PM   #4
meteoriteSilverE46
My Ride: 2003 E46
have a local guy here in dallas that a turbo gunkie..hes gonna tunning and install everything except the piping...for as the boost..12 lbs on a rear mounted turbo should have me close to 400 hp..rear mounted turbos produce more hp per pound of boost then anyother turbo on the market..just check out STS turbo systems they breaking all type of records..i dont go off of here say..only true stats..and dyno results and STS blows them all away..im just worried about the tranny and rear end.
Old 07-09-2010, 12:38 AM   #5
E46 S54B32
My Ride: 323ci
dude honestly he might be a turbo junkie but you have to remember a e46 isnt a honda...theres a reason that its now 10 yrs later that the 1st turbo kit for the e46 non m has come out...
let see what happens to your stock head with 12 psi on a crappy tune...
ill give you 6 psi max running rich/lean on a "tune"
if you have a 5 spd your good for 400+ whp
even if you dont go thru with this reinforce your subframe bc more than likely yours is cracked
im not trying to be rude or an a$$hole im just giving you the heads up
Old 07-09-2010, 12:51 AM   #6
meteoriteSilverE46
My Ride: 2003 E46
most likely gonna do some up grades on the heads..port and polish..high performance springs new valve seeds and a thicker gasket to decrease compression..its a project..thats why im posting..two things can happen,,come out fine or kaboom!!! with tunning u live and die with the unknown..just posting to see if anyone out there turboed a 325i..and what was the outcome and results..that all im trying to figure out..avoiding a problem that someone else already ran across and eliminated.
Old 07-09-2010, 12:56 AM   #7
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
i rather get the turbo kit that is tuned for our cars to be safe than sorry. it seems you wanna upgrade because other people are walkin on you.
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 07-09-2010, 01:07 AM   #8
E46 S54B32
My Ride: 323ci
honestly your best bet is supercharger or s54
if you want to run the custom turbo get a standalone and with that maybe you can run 10 psi depends how good your friend can tune
upgrade to thicker heade gasket, port and polish, head studs
Old 07-09-2010, 07:08 AM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Guys, the M54 head doesn't need to be touched.
Even ported N54 heads flow less than a stock M54...and look at the numbers they are pumping out.
Old 07-09-2010, 08:06 AM   #10
tinkwithanr
My Ride: '00 323i + '75 2002
Any idea how the m52 head compares to the m54 head in terms of flow? (Completely ignoring the other differences between the engines).
Sig
^^Mica_____________________________Fiona^^
tinkwithanr is offline   Reply With Quote
Old 07-09-2010, 08:54 AM   #11
E46 S54B32
My Ride: 323ci
port and polish isnt necessary but if your already there might as well do it....im pretty sure for 12-14 psi thicker head gasket and studs are needed....i would even throw in lower compression pistons but thats probably out of your budget....
Old 07-09-2010, 09:02 AM   #12
2005M3Driver
My Ride: Boosted 2005 M3
I would like to know what shop you are taking your car to. I hope its not a shop that is known for screwing things up in the Plano area.
IMG_3726 by 2005M3Driver, on Flickr
Sponsors:
Mothers® Polishes·Waxes·Cleaners
Mishimoto
2005M3Driver is offline   Reply With Quote
Old 07-09-2010, 10:16 AM   #13
MachRc
"Have some candy!!"
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Originally Posted by meteoriteSilverE46 View Post
im just [tired] [of] the ricers here in dallas pulling along side of me on the freeway!
this was the reason why it got deleted the first time around and you repost it with same crap? You sound 17.
Bimmerfest 2013 Photos here!!!
"The road was miles ahead..It fell away, now I'm at thee end... Just a sky, the fall, and you..I got holes in my para~chute......
Then-you-say,' never gonna find all the answers~ answers will find you..Don't know how I'll feel tomorrow~
Don't know the truth. But we can lie,.. lie.., lie.., lie here together..lie..,lie..,lie..,lie here together..'"
MachRc is offline   Reply With Quote
Old 07-09-2010, 10:42 AM   #14
jacobs323i
My Ride: blown 323i
this is a cool project i was wondering how those sts rear mounts would work on our cars!
jacobs323i is offline   Reply With Quote
Old 07-09-2010, 10:45 AM   #15
MachRc
"Have some candy!!"
MachRc's Avatar
And I really believe that any non-m kit especially the 3-4 out there outside of Technique Tuning's non-m kits are kits that seem like they are not sorted out and in ways detrimental to the motor.
ritos has already done the work you decribe on a 3.0. with somewhat fuzzy results and lots of blowback.
http://forum.e46fanatics.com/showthr...702&highlight=
http://forum.e46fanatics.com/showthr...452&highlight=
ritos has alot of experience maybe you should pm him
Old 07-09-2010, 02:39 PM   #16
meteoriteSilverE46
My Ride: 2003 E46
Just gather some info..guys..not here to a chic fight..I was into SBC my whole life..this straight six is a nightmare..bu the way I am not 17..maybe 20 yrs ago..so helpful. Info is great...and money not a problem
Old 07-09-2010, 02:42 PM   #17
mvrk10256
My Ride: E30 325i
what shop is doing the work?
Old 07-09-2010, 03:33 PM   #18
WTBE46TOURING
My Ride: 4.8is,S/C E30,S/C M3
I have some custom turbo cams that should help ya... pm me
Parting out E46 M3 Dinan S3-R!
Turbo E30
Roadkill OBDI BASE Tune
S50/ .140 Cometic, ARP's
Bavarian Solutions Cylinder Head
Schricks
GT4088r
Otis' tubular T4 manifold
503whp/434wtq
1/8 mile: 7.61@106.48
1/4 mile: 11.58@136.94
WTBE46TOURING is offline   Reply With Quote
Old 07-09-2010, 03:47 PM   #19
xi325xi02
My Ride: 325xi
Why do I get the feeling here that there are multiple people in this thread that are completely new to e46's and are attempting/ supporting the near impossible. Yeah its been done already, so why not look at what has been safely and effectively accomplished and think, well sh!t- I think ill go that route.
I get why people do custom work but in this instance the op isnt in it for the project. Hes in it for the results. So lets be really honest op. You want power yeah? Why go through the months of headaches and nightmares only to piece together a project that will most likely fail ending up in a lot of wasted cash. Check out the superchargers that are available. If you don't feel that, go to techniquetuning.com and look around for a while see if you can work out a deal. If that doesnt work buy a turbo and the components and piece those together then get your "expert tuner" to work on it.
Why reinvent the wheel in your case? All you want is power. There are much easier ways sir.
Originally Posted by onebad328i View Post
you want ladys damm, get a punchin hard ass sound system
I HATE CVT'S
xi325xi02 is offline   Reply With Quote
Old 07-09-2010, 04:33 PM   #20
///TRNSPRTR
My Ride: 07 Tundra, 02 M3
I disagree...
///TRNSPRTR is online now   Reply With Quote
