Help front brake locks up then releases while driving. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 07-09-2010, 09:21 AM   #1
kayzrx8
My Ride: 2003 325 sedan
Exclamation Help front brake locks up then releases while driving.
Hey guys im new to the forum. Ive been having an issue with my brakes. Im not sure whats going on. I took my 03 325 sedan to a mechanic to fix the rear diff bushing. all was fine till one day as i was driving then the front passenger brake applied itself momentarilly. locking up the wheel for a few m/s then releasing. that was 3 month ago. now eveytime i drive the car within the first mile of driving the same issue witht he front passenger brake will happen and the yellow "brake" light and the light with the triangle and circle in the middle of the dashboard will light up. What could be going on? Someone suggested a wheel speed sensor going bad. Any suggestions would help im planning on taking the car to get codes pulled. Thanks
kayzrx8 is offline   Reply With Quote
Old 07-09-2010, 03:01 PM   #2
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
For the front brake issues. You got a sticky caliper. You will need to clean the guide bushings and the pins. I would lightly grease the pin before reassemble to help the caliper move to it's original spot. If the bushing are in terrible condition you will have to rebuild the caliper.
For the triangle light problem. That would he the wheel speed sensor. I would check and clean the speed sensor and then go from there.
Keep us posted on what happen
Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 07-11-2010, 12:46 AM   #3
kayzrx8
Hey thanks for the response man. Im pretty sure the caliper isnt sticking cause the front end on my cars practically new. I just put new calipers, rotors, brakes, and suspension arms. The abs unit , dsc or something is applying the front passenger brake. i can hear the unit make a noise to apply the brake when t happens. it does it like after 5 mins of driving and only for a quick second then releases. After it releases the lights will come on. I will look at the wheel speed sensor. Do you think it just needs cleaning or need to be replaces? Is this a common problem that happens when the wheel speed sensors fail?
Old 11-14-2010, 07:08 PM   #4
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
I'm having the same issue with the front brakes.For less than a second the front applies braking on its own.This started right after I got a shop to flush the lines for me.It does it @ any speed.
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
Old 11-15-2010, 12:50 PM   #5
kayzrx8
Exclamation Bad Wheel Speed Sensor
I managed to fix the problem it turned out to be that wheels speed sensor. Try cleaning it. If that does not work replace it. That thing almost got me into a wreck. It locked the front wheel for a second while i was doing a turn on an exit ramp.
Old 03-22-2017, 09:25 AM   #6
de_no
My Ride: '01 325ci
Did you ever find out what causes your front right brake to lock up? My '01 325ci is having the same problem, with the same two lights on the dash
de_no is offline   Reply With Quote
abs, brake, brakes, lock, releasing
