Sponsored by BimmerWorld
Old 07-09-2010, 10:34 PM   #1
Chadderkdawg
My Ride: 2001 330xi
Sway bars disconnected
So I'm changing my oil tonight, and I notice that neither side of my front sway bars are connected... Not sure about the rear... Is that bad? How bad? Do/how do I fix it?
-Kendall
Chadderkdawg is offline   Reply With Quote
Old 07-09-2010, 10:37 PM   #2
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
Yes...
reynaldo is offline   Reply With Quote
Old 07-10-2010, 12:55 AM   #3
BodyMan
My Ride: 2002 325i
-Kendall
It sure can't be good...........
Are the sway bar end links that go from the strut to the sway bar there? If not you need new ones.
BodyMan is offline   Reply With Quote
Old 07-11-2010, 10:30 PM   #4
Chadderkdawg
My Ride: 2001 330xi
Well the links are there, I think the back side of the bolt isn't there... but I have never worked on sway bars or suspension components before so I'm not too sure how it all works... I'll look into whats there and whats not this week, any help, tips, diagrams, would all be very welcomed.
Kendall
Old 07-12-2010, 11:40 AM   #5
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
If you determine your front swaybar is in fact "disconnected", you will notice a huge difference in steering/handling when it is fixed. Same with the rear.
Old 07-12-2010, 06:25 PM   #6
Chadderkdawg
My Ride: 2001 330xi
Ok, just tore apart the front end, the lower ball joints failed, so it was separated from the joint on both sides, looks like I'll need to purchase entirely new links though correct?
Kendall
Old 07-12-2010, 07:34 PM   #7
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yep. Luckily they're inexpensive and extremely easy to install.
Kendall
Old 07-13-2010, 09:05 AM   #8
Chadderkdawg
My Ride: 2001 330xi
Perfect, 50 bucks shipped from partsgeek.com, done.
