Sponsored by BimmerWorld
Old 07-10-2010, 11:08 AM   #1
Young Gun
My Ride: 05 330ci
Thinking about Coilovers... supporting suspension components needed?
Hey guys,
I was contemplating coilovers for the car.
In the past when lowering vehicles I have always had issues with swaybar links & bushings wearing out much quicker.
I do know that I am not going for the slammed look but just a 1 inch drop MAXXX. The roards here in Ontario are definately not slammed-friendly.
My questions is for those already running coilovers, have you guys changed any suspension components since?
Cheers!
Young Gun is offline   Reply With Quote
Old 07-10-2010, 11:08 AM   #2
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Rogue Shock Mounts
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 07-10-2010, 05:57 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You definitely want rear shock mounts, I would also upgrade your control arm bushings as those tend to fail prematurely on stock suspension.
Old 07-10-2010, 10:56 PM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
1. RTABs
2. RSM
3. FCAB
4. Control arms
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-10-2010, 11:02 PM   #5
woopaul5
My Ride: 2005 M3
Send a message via AIM to woopaul5
I put about 12,000 miles on my KW v1's on my old 330Ci. There were no issues with any linkage or shock mounts and car was driven fairly hard. The kit came with new front sway bar links and I upgraded to H&R sways front and back with no issues. I'd go with KW or Bilstein. They're good set ups and seems to be the favorites on here.
woopaul5 is offline   Reply With Quote
Old 07-11-2010, 03:07 PM   #6
BMW_Matt
My Ride: 135
1 inch max drop? That's about the minimum drop some brands drop. Others drop more then 1"
You won't need endlinks for the rear, but RSM's are recommended.
BMW_Matt is offline   Reply With Quote
Old 07-11-2010, 03:35 PM   #7
Young Gun
My Ride: 05 330ci
Thanks for the inputs guys!!!!
Old 07-11-2010, 03:50 PM   #8
bigjae1976
bigjae1976's Avatar
I don't know of a coilover that won't drop more than 1". Why coilovers? H&R cup kit?
I'd have to recommend Bilstein Sports and springs for a modelst drop.
Old 07-11-2010, 04:57 PM   #9
mrx733
My Ride: E46, W201
Send a message via AIM to mrx733
who wants a 1" drop at max? anyway bushings and endlinks go bad, you should be inspecting/replacing them regularly, rougher driving conditions=quicker wear of those things. coilovers might increase the wear, but big wheels take like half the life off of bushings.
mrx733 is offline   Reply With Quote
Old 07-11-2010, 05:06 PM   #10
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
front strut tower reinforcement plates
Chris
dreamdrivedrift is offline   Reply With Quote
Old 07-12-2010, 12:17 PM   #11
david @ eas
Past Site Sponsor
My Ride: E46 M3
Originally Posted by bigjae1976 View Post
1. RTABs
2. RSM
3. FCAB
4. Control arms
+1
Even if you don't do all these things right when you do your suspension, more than likely it will come soon as they usually need to be replaced around 75k miles or so.
david @ eas is offline   Reply With Quote
Old 07-12-2010, 11:42 PM   #12
glovesoff
My Ride: 1999 328i
2 Front Strut Mounts
2 Heavy Duty Rear Strut Mounts
2 Shock Mount Gaskets
2 Z3 Reinforcement Plates
You will want to get those parts to install the coilovers. then on top of that, it would be a very good time to do control arms/bushings and or rear trailing arm bushings.
glovesoff is offline   Reply With Quote
