Old 07-11-2010, 10:03 AM   #1
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Question 325xi, 330xi, 330xd Drivers - From 4WD to 2WD with a Fuse?!
Hello Guys,
i've found a Video from a E46 330xd-Automatic at youtube.de
LOOK @ 1:50
Please have a look, the driver drives with 4WD at the beginning. He removed a 50A-Fuse (DSC, ABS, 4WD :O ) and it's a 2WD Driveline
What is that?! I thought this is'n able becouse its a mechanical thing to deactivate the front wheel drive
I've tested it - IT WORKS!?!?!
Can anyone explain this?
Hageee is offline   Reply With Quote
Old 07-19-2010, 05:18 AM   #2
calibornn1979
My Ride: E46 330Xi, E36 320i
haha here i go again. im on 3si.org. a 3000gt forum. and they claim the same houx for that car too.
calibornn1979 is offline   Reply With Quote
Old 07-19-2010, 09:15 AM   #3
officer140
My Ride: 01 330xi, 99 TLR
Originally Posted by Hageee View Post
Hello Guys,
LOOK @ 1:50
Actually, can someone explain this: If it's a AWD car and a fuse is pulled to make it a 2WD car, then it gets stuck in the snow while in "2WD mode" - why not just pop the fuse back in? Why did it need to get towed/pulled out?
officer140 is offline   Reply With Quote
Old 07-19-2010, 10:30 AM   #4
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
yea that was retarded
i dunn understand how removing the fuse will make it from 4wd to 2wd, can someone please explain this?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 07-19-2010, 11:18 AM   #5
Rocko123
My Ride: E46 M3 , E90 330xi
a pull of a fuse.... common really? (not trying)
- R O C K O 1 2 3 -
Rocko123 is offline   Reply With Quote
Old 07-19-2010, 08:41 PM   #6
mrshelley
My Ride: 2004 330i
I'd just put a switch on the dash. 4WD is up and 2WD is down. If you pull the fuse next to the (2WD/4WD fuse) then you can get 4WD Lo. That is really helpful for when you are trying to pull out a stump with your 325xi.
One other trick, if you push the shifter really hard while in first gear, you'll get a granny low first. That works really well on an oak or redwood stump.
Old 07-12-2012, 05:24 AM   #7
Mitchez22256
My Ride: 330xi 2005
Bmw xi ratio is 32:68? Anyway so if you take out this fuse do you really become 00:100? Or 10:90...... So you can makes some drift or burns with a manual transmission ?
It is very interesting I want To
Know more ..effects on the car?
Mitchez22256 is offline   Reply With Quote
Old 07-12-2012, 08:31 AM   #8
hassmaschine
My Ride: '91 325ix
no, it won't make the car 2WD. the xi has a mechanical transfercase, there's no way to decouple it. the torque split is also not adjustable, it's 100% fixed mechanically.
all it does is disable the ABS system which is what prevents the wheels with the least traction from getting all the torque. basically the E46 xi uses the ABS sytem to provide the transfercase with a bias torque. all you're doing by disabling it is making the transfercase an "open" differential.
hassmaschine is offline   Reply With Quote
Old 07-12-2012, 07:49 PM   #9
SPL15
My Ride: 01 325i Auto :/
^ x2. It's an 'all wheel drive' system, the center differential is not locked like on an actual 4 wheel drive on a truck or older SUV. Without the traction control you have a 1 wheel drive system
E36 M3 :) - RIP :(
E46 325i :/ - Throttle doesn't go down far enough...
SPL15 is offline   Reply With Quote
Old 07-13-2012, 03:41 AM   #10
Mitchez22256
My Ride: 330xi 2005
If you look carefully at the video , only the rwd spins when he is jammed , why , and they are 2 older posts in this tread that one say's he got a switch and another(#1) said that he tried and It works , what happen whit you guys is the car dead? Haha
Old 07-13-2012, 12:10 PM   #11
hassmaschine
My Ride: '91 325ix
the rear wheels are spinning because they have the least amount of traction for the torque they're given. that's all there is to it. if the front wheels were on something slippery, they would spin and the car would go nowhere.
the E46 xi system is already not that great, disabling the only thing that keeps it from total suckage (DSC/ABS) is the worst idea ever.
Old 07-18-2012, 01:08 AM   #12
TerraPhantm
My Ride: M3 & ZHP
The e46xi transfer case is essentially an open diff. So with traction control completely disabled, the axle with the least resistance is the one that will spin. It is a fairly primitive awd system
Old 07-18-2012, 08:35 AM   #13
Pierce1
My Ride: 03 330xi
Yea, no viscous coupled transfer case like the venerable 325ix.
Pierce1 is offline   Reply With Quote
